The X5 SAV Forum
Old 03-23-2013, 02:07 PM
stevepage7 stevepage7 is offline
Mein Auto: 2001 BMW x5
aftermarket stereo
I have a 2001 x5 with a OEM stereo fitted (satnav/TV) I want to fit a new stereo but the connections at the back x 2 are only small all the harnesses ive seen are for standard fittings - is there anywhere i can get connectors to fit an aftermarket stereo
ID:	367765   Click image for larger version
ID:	367766   Click image for larger version
Old 03-25-2013, 09:56 AM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
That is just the screen, the "Real Radio" is located in the trunk area in front of the battery under the plastic that has BMW embossed on it.
Old 03-25-2013, 11:36 AM
aftermarket stereo
can I get connectors or a harness to fit a aftermarket stereo
Old 03-25-2013, 08:54 PM
Crutchfield.com could answer that question for you. It depends on what head unit you will be buying for your X. There are some headunits made specifically for the X and it's very much plug and play. You should post your question at xoutpost.com.
Here's a thread at xoutpost on the Chinese radio for the X.
http://www.xoutpost.com/bmw-sav-foru...ingan-nav.html
