Old 03-23-2013, 03:55 PM
billome billome is offline
Mein Auto: 07 black sapphire 335xi
dual exhaust on 07 335xi
I was wondering if anyone knows if you can do anything to keep the dual exhaust open on an 07 335xi? Saw a video about this on youtube regarding a corvette, all you do is pull a fuse and it stays open....
Old 03-23-2013, 04:08 PM
GarySL's Avatar
GarySL GarySL is offline
Mein Auto: '08 335xi (E90)
This, maybe?
http://www.e90post.com/forums/showthread.php?t=80661
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered: March 7, 2008
Built: March 17, 2008
At port: March 19, 2008
Shipped on Graceful Leader: March 21, 2008
Arrived Port Hueneme: April 11, 2008
At dealer's: April 19, 2008
Delivered: April 21, 2008
Old 03-23-2013, 04:51 PM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
It works used to use it
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 03-23-2013, 06:32 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by GarySL View Post
Too much trouble! Just wire tie a crimp in the rubber line at the left pipe.
Easy to re-activate too....snip the crimp.
Tried it, BTW; didn't like it. Low end performance suffers.
The upper crust simply purchases a JB4. Using the chip, the flap can be kept open via software. Very sophisticated, and very urbane - that is what all the best people do.
Old 03-23-2013, 08:01 PM
GarySL's Avatar
Originally Posted by CALWATERBOY View Post
Too much trouble!..
Yeah Cal, pulling a plug has to be the most complicated act imaginable.
I too, disliked the twin pipe condition. Sounded like I had along my washing machine for a ride. The background drone was insufferable.
Old 08-28-2013, 11:30 AM
matt0824 matt0824 is offline
Mein Auto: 08' 335xi / 07' 328xi
I just bought an 08 with dual exhaust. I t seems to have a rattle sound on the driver side pipe. I took a look and there seems to be a nipple hanging down. If I push on it the sound goes away. Actually, after idling for 1 min the sounds goes away and my left pipe opens up (exhaust comes out). What is this all about? Is this the norm? I can record sound if need to.
- 2008 BMW 335xi (sport pkg) MINE
- 2007 BMW 328xi HERS
- 2004 BMW 760Li V12 SOLD
Old 08-28-2013, 11:42 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Photo would help; could be a broken/loose flap.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 08-28-2013, 12:53 PM
Here's the nipple:
Flap looks open car is turned off:
Old 08-28-2013, 12:58 PM
thekurgan's Avatar
Bad Lieutenant
If you tap that thing with your finger or a screwdriver, do you hear the rattle? It's correct, the solenoid closes the flap until idle, cold start and increased rpm, I believe around 2500 rpm, you hear it open.
Ilse
Bruna
BMWCCA #453648
Old 08-28-2013, 05:14 PM
In reverse, it rattles @ start then 1min later it opens. Then it sounds correct. My concern is the rattle upon start up. Is that common? It pans out later and stops the rattle.
FYI, When it rattles I can push the nipple in and it silences.
Old 08-28-2013, 05:18 PM
thekurgan's Avatar
Bad Lieutenant
Sounds like it's operating normally aside from the noise, must just be loose at the plate.
Ilse
Bruna
BMWCCA #453648
