Old 03-24-2013, 12:23 PM
Carter650i Carter650i is offline
Mein Auto: 650i
So many options no clear answer
Ok this subject being covered a 1000x times but I can't seems to find the right answer, I want to do the upgrade for the angel eyes I have a 2009 650i so which is the best out there that is also error free!!! The lux angel eyes are awesome but they don't seems to have anything for the e63/e64 and MTec v3 I don't see anything for the car year. Please help!!!
Old 03-24-2013, 12:39 PM
reytran's Avatar
reytran reytran is offline
Nothing quite like a 6
Mein Auto: 09' 650i Cabrio
Check out bavarian exclusive website. Im on my phone now. I will update for u when I have access to computer. The brightest option you can do is the halo ring ls3 upgrade. Google it. The E9x version for LS3 angel eyes are brilliant.
2009 BMW 650i Cabrio (daily drive)
2011 Audi A4 (groceries, bully, road trip, winter beater, family car)
BMW CCA ID: 473647
Old 03-24-2013, 12:49 PM
roseng's Avatar
roseng roseng is offline
Mein Auto: 2016 528i + 2007 650 Vert
There are many H8 bulbs available. Unfortunately, none of the LEDs will ever be as bright as the new cars. You can get a better color and I'm good with that on my car but it is not as bright looking in the day time.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 03-24-2013, 01:56 PM
Mein Auto: 650i
So which one do you suggest?
Old 03-24-2013, 02:30 PM
reytran's Avatar
Here you are:
For the light bulb option, these are the 2 top of facelifted 6ers LED angel eyes upgrade:
http://www.bavarianx.com/MTEC_Ver_2_...mtec.21.ae.htm
http://store.ijdmtoy.com/360-Degree-...-p/sku-s15.htm
For the brighter rings, you probably have to go with custom halo rings
http://www.bavarianx.com/BMW_LS3_LED...Eyes_s/390.htm
If you check out the SoCal meet picture, you will se zerock car. He did that himself. To make the white ring brighter you should also consider the option paint your housing black, better contrast on the white light. I tried Weisslicht LED, good looking design and bright but the focus isn't really match with the 6 LED rings. As a result if you only do the bulb upgrade, in the day, the larger ring will be barely visible for all the best LED bulb. I tried one from modbargains.com before and the result was totally ... Invisible.
BMW CCA ID: 473647
Old 03-24-2013, 05:50 PM
Mein Auto: 650i
Originally Posted by reytran View Post
Here you are:
If you check out the SoCal meet picture, you will se zerock car. He did that himself. To make the white ring brighter you should also consider the option paint your housing black, better contrast on the white light. I tri Weisslicht LED, good looking design and bright but the focus isn't really match with the 6 LED rings.
Thank you
Old 03-24-2013, 06:33 PM
reytran's Avatar
Oh yeah, btw all of the LED angel eyes I mentioned above, none of them throw error code.
BMW CCA ID: 473647
Old 03-24-2013, 06:48 PM
Mein Auto: 650i
What's the difference between MTec 2.1 and 3.0?
Old 03-24-2013, 06:58 PM
reytran's Avatar
Higher Watt and More expensive I believe. If you look up at the description, they are all made for pre-facelifted. Hence, not really for our cars. I'm going to do the LS3 I mention above. It might be the only choice by now.
BTW, when you upgrade to the extremely high Watt LED bulb, your bigger rings somehow become brighter but your smaller rings will be brighter or same as your low beam. When I use the Weisslicht, there was a time I try driving around at night with lowbeam off and no problem with visibility. 20W is really crazily bright for the smaller rings.
BMW CCA ID: 473647
Old 03-24-2013, 07:01 PM
Mein Auto: 650i
Ok so why would you choose the Ls3 instead and if they not made for our car does that means I would have to cut drill or modify anything g to get any of these to work?
Old 03-24-2013, 08:13 PM
reytran's Avatar
No cut no drill, remove headlight, heat up/bake it by hair dryer , it pop out, there u go.
LS3 is a custom work, it replaces the halo rings that my furthest knowledge. Im going to ask BavarianExclusive to do it for me. My friend has it for 2 years and it still as bright as new. And the outcome is like wow thats beautiful. It only cost ~$300 for everything on my friend E90. Its just almost double the bulb price so I think its worth doing it.
BMW CCA ID: 473647
Old 03-24-2013, 08:32 PM
roseng's Avatar
Rey,
You are making this sound very easy. It is a very long and very complicated process that only a very few members have done themselves.
The cost is not the issue.
No everyone is as adventurous as you are, so I would caution anyone who was going to do this to really understand what is involved.
Read this thread and download the PDF that Zerocks1 made. It will be a great help to you.
Old 03-25-2013, 05:11 AM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
There is a way to get the angel eyes to light up brighter, this is done by increasing the voltage feed. For those of you that have NCS Expert software & are comfortable with coding you edit the nettodata to change the voltage level at the bulb:
http://www.bmwcoding.com/showthread....ighlight=Netto
I have it used this method myself but I thought someone out there might be interested in giving it a go.
Old 03-25-2013, 08:16 AM
roseng's Avatar
You still need to get a newer LED type lamp and the driver for that LED array has a lot to do with it too.
You are correct about the voltage and I've seen that done but frankly, the difference is minimal compared to the brightness of the F series cars that most people want.
Old 03-25-2013, 12:37 PM
reytran's Avatar
Hi,
For the complete conversion plus the blackout, the cost is $700. This also includes bumper/headlight removal as well as the cost of the kit and installation. Turn-around-time if you were to drop off your car/headlights, would be the same day. If you bring it to us in the morning, then it will be available at the end of the business day.
- LS3 v3 LED Kit (Intense White Color)
- Blackout Option (matte black)
- Installation (disassemble/reseal)
- Headlight/Bumper Removal
Best,
Just got a quote from them.
BMW CCA ID: 473647
Old 03-25-2013, 06:23 PM
roseng's Avatar
Who is the quote from? Is this for the AE rings?
Old 03-26-2013, 12:42 AM
reytran's Avatar
They locate in Yorba Linda. Their works for BMW car are milestone. They are well established as LTBMW I believe or maybe even better.
BMW CCA ID: 473647
Old 03-26-2013, 06:14 AM
Maalco Maalco is offline
Mein Auto: 2010 650i Coupe
Similar...I have a 2010 - possible to just buy entire new headlamp assembly from a '12 or '13 and get installed with the new improved angel eyes?
Would they fit?
Old 03-26-2013, 09:06 AM
reytran's Avatar
Would they fit?
Mission Impossible .
BMW CCA ID: 473647
Old 03-26-2013, 09:58 AM
Dang!
Old 03-26-2013, 12:32 PM
roseng's Avatar
looks like a good company but I don't see the Angel Eye light anywhere.
Old 03-26-2013, 12:40 PM
reytran's Avatar
You can try google BavarianX LS3 or check their 3 series section. Its basically similar to what zerock did. With their mtech v.3. It's even brighter than the new angel eyes. My friend has the older LS3 version with mtech v1 he did 2 years ago. Still as bright as the new BMW, just not as thick as the new one.
BMW CCA ID: 473647
Old 03-28-2013, 10:51 AM
reytran's Avatar
I met my friend with the LS3 light (older version) he got it done in June 2011, till now, there is not a single problem with the light. The only thing I'm curious is why everything is more expensive when you drive a 6 LOL. My friend get a quote $350 2years ago to do this and now I'm quoted $700.
P.S:My all broken iPhone 4S camera can't really take good pics.
BMW CCA ID: 473647
Old 03-28-2013, 06:59 PM
Mein Auto: 650i
ok here's the one that I'm getting ready to buy would it be bright? anyone has that same one, and more importantly where can i find it cheaper http://www.mteclightingusa.com/MTEC_...mt-615-e63.htm
Old 03-28-2013, 08:29 PM
roseng's Avatar
He has a 5 series. Much easier to get the lights out.
You have a 6, no comparison.
