Old 03-24-2013, 12:46 PM
cramin9 cramin9 is offline
Mein Auto: 2000 328ci
Strange noise from engine after car turned off..
Hey everyone,
Long time reader, first time posting. I bought a 2010 328i about a week ago, and I've been noticing a strange sound coming from the engine area when the car is off. It's kind of an electronic whirring noise, pretty soft, happens every 15-20 seconds or so.
Anyone have any ideas what this sound is, and what it's coming from?
My previous car was a 2000 328ci, and it didn't do anything like what I'm hearing on this one.
Old 03-24-2013, 01:45 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Possibly the electric water pump.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 03-24-2013, 01:51 PM
Greyfox Greyfox is offline
Mein Auto: BMW
Do you hear it outside the car or from the inside? Also, do you have iDrive?
Old 03-24-2013, 02:36 PM
I hear it outside. I don't have idrive
Old 03-24-2013, 03:32 PM
Joe in Dublin Joe in Dublin is offline
Mein Auto: 335ic
coolant pump
Old 03-24-2013, 05:01 PM
Is it supposed to be making that sound?
Old 03-24-2013, 07:41 PM
Mein Auto: 335ic
it will make some noise
Old 03-24-2013, 10:08 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
The water pump keeps running to continue to cool down the engine after you turn it off if above a certain temp. This helps extend engine life. If you think about a car with a regular water pump driven by the engine and belts, when you turn the car off hot, it stops the cooling process and coolant flow. That is an advantage of the electric pump vs. mechanical. Also, there is less load put on the engine when running and the pump can flow coolant faster if needed when the engine rpm is slower. On the flip side, they are more expensive as a part but may save you big bucks in the long run on head gasket jobs. A lot of newer front wheel drive cars have the water pump built into the engine block which requires a timing chain cover removal to replace...$$$$!
Old 03-25-2013, 12:03 AM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
Isn't it the HFHP de-pressurizing?
Old 03-25-2013, 07:45 AM
Awesome! Thanks for the info!
Old 03-25-2013, 08:56 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
No. For starters, the 328 has no HPFP.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 03-25-2013, 10:01 AM
Ahh, this only applies to cars with turbos right?
Old 03-25-2013, 10:46 AM
Zeichen311's Avatar
It applies to engines that use direct injection rather than port injection. The turbocharger is irrelevant, though offhand I cannot recall a non-turbocharged direct-injected BMW engine. (I know they exist so I'm sure someone will chime in.)
(Edit: The N53 is DI, non-turbo.)
Old 03-25-2013, 08:04 PM
sptt144's Avatar
The 328i also has an electronic waterpump.
Old 03-25-2013, 09:10 PM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
My 2006 325i makes a sound like a decelerating turbine after shut down. Kind of like a little jet engine spooling down.
It only happens once and then stops, but it is winter here in Indiana so maybe it would happen more than once if it was hotter.
Is this what you are describing craming9?
I like the sound. It sounds like the Batmobile after the "Dynamic Duo" park it in the Bat Cave (in the TV series).
Is this the electric water pump or something else?
