Old 03-25-2013, 04:05 PM
sick645ci sick645ci is offline
Mein Auto: 645Ci
645Ci Valvetronic Intermediate Lever Spring Loose
Hi guys,
First of all a big hello! A great forum that I have used A LOT! Very useful.
I have been working on a E63 645Ci 2004 with 170k miles on it. It has loads of problems that I have been getting through. I basically stripped the engine down- heads off to sort out timing chain guides (with updated guides), crankshaft seal, timing case leaks, alternator bracket oil leak, valve cover leaks, intake manifold gasket leaks, coolant return pipe leak and valley pan leak (I'm sure there's more) all seem common N62 problems.
I have attached some pics for amusement. I will also be adding some more pics for a DIY on the valve cover gasket replacement.
ID:	368127 Click image for larger version
ID:	368128 Click image for larger version
The problem I now have is a constant misfire on cylinder 5 only when warm at idle. Swapped plug, coil and injector. No different. Compression close to 200psi. Engine roughness chart in INPA shows a massive difference for no. 5 (+12! so fault code 2743 misfire detection no. 5). Spray brake cleaner around to check for air leaks. No change in idle. Misfire gets worse as engine warms up. So I dig a little deeper- research on Valvetronic shows as car warms valve lift is reduced. I then unplug eccentric shaft sensors to force Valvetronic into emergency mode (max valve lift). Engine roughness now all around zero for every cylinder including no. 5. Now upon researching Valvetronic problems I get quite depressed!
So I remove the valve cover again and expect eccentric shaft or intermediate lever wear. Although I did not note any wear when inspecting heads- but I obvioulsy did not look close enough-
If you're still with me... How would this happen? This is the retainer spring for the lever has popped out of the holder on both sides! Maybe when handling the heads or removing/installing I caught it. Has the spring broken or can I just pop it back into the holder each side?
Many, many thanks in advance!
Andrew
Old 03-25-2013, 06:51 PM
HerbP HerbP is offline
Talk about jumping in with both feet! With 170k & the heads off, why did you not pull the motor? Sounds like you have reassembled everything, & found a problem. That makes for no fun, but I am sure you know that by now. Tell us your story of how far you went? Also sounds like you might have worked on a BMW before.
Welcome Aboard!
Old 03-26-2013, 04:02 AM
Mein Auto: 645Ci
Welcome Aboard!
Thanks!!!
Yes I was 50/50 about pulling the engine. Had I known all the extra problems I would find I would have been 99/1!
Tip- I managed to pull the heads off with exhaust manifolds still on. This is a two person job though.
Well the engine was stripped down as far as you can see above. The heads were very lightly skimmed just really to remove old gasket remnants.
My car is an E39 535i non-vanos. About ten times as simple! This 645Ci (E64 I think- convertible) belongs to a friend of a friend. I said I'd kindly look at it as I had some free time... Weeks later here we are! I have learned a lot though by taking this on. Many hours of researching the N62 beast.
I have popped the spring back in place and finished re-assembly last night. Will be firing her up this morning so will update with result.
Cheers!
Old 03-26-2013, 05:30 AM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
The engine needs to be at TDC (cylinder #1 compression) before you remove the intake camshafts. If you miss this step, the levers/springs usually pop out during reassembly. Good job with everything though, good luck!
Old 03-26-2013, 06:25 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
Hi, Well thank you for putting some key pictures of your engine strip down, I think this is excellent
With reference to the coolant pipe issue, one of the biggest issues with the N62 engine, your pictures highlight how poorly designed and engineered this engine is !!!!!! The state of the corrosion surrounding that area is appalling, I recognize that the car has done 170K but when you consider how often this is happening at much much lower mileages, it is a disgrace.
I sincerely hope you keep up with the pictures and actions undertaken as many forum members will benefit.
Finally I hope that when all your work is complete that you bring the big girl back to life and enjoy the benefits of all your hard work!!!!
Always said I would go back to a 6 series
Old 03-26-2013, 10:00 AM
Mein Auto: 645Ci
Ah, thanks for that. I did have it at TDC with the camshafts pointing in the correct direction. Maybe I turned the intake camshaft slightly when loosening the bolt. I did have a spanner holding it but wasn't the easiest to do on my own.
Many thanks for the pointer.
Also thanks to wilson009 for his thread that I found very helpful: http://www.bimmerfest.com/forums/sho...d.php?t=417251
N62 Timing[1].pdf
Old 03-26-2013, 10:06 AM
Mein Auto: 645Ci
I just love pictures of engine work! I've got a load of pictures from the valve cover removal that I will edit and upload soon.
The coolant pipe is so silly and I really feel for owners that have this issue as the labour is the killer. I fitted the new OEM pipe with extra sealant around it to prolong it.
Progress.... See next post....
Old 03-26-2013, 10:50 AM
Mein Auto: 645Ci
It now idles like a dream! I'm so happy!
Popped the spring back into place and started it this morning. After warm-up no misfire. I had to adjust the valve lift slightly maybe as it was now running correctly with old values. This was to get the 'actual value stroke' to match up with 'set point stroke' in INPA. Vacuum/intake manifold pressure surging issues now cleared up as well.
Here are some screen shots from INPA live data (I must say the amount of info and data these things give out is amazing) -
ID:	368300 Click image for larger version
ID:	368301 Click image for larger version
ID:	368303 Click image for larger version
ID:	368304 Click image for larger version
Old 08-27-2013, 07:25 AM
sudnut sudnut is offline
Mein Auto: E46 318i
Sick645ci,
Thanks for posting up your repair and pics. I am dealing with the N42 valvetronic 4 cylinder engine and trying to learn about its VVT. Were you able to adjust valve lift through INPA or is it done manually somehow? Did you try using DIS GT1? Cheers.
Old 08-27-2013, 07:44 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
Old 08-27-2013, 04:25 PM
Mein Auto: 645Ci
Originally Posted by sudnut View Post
Sick645ci,
Hi, yes I was able to adjust it in INPA. This is to adjust the minimum valve lift amount at idle. The pic above with a screenshot of 'VVT setting' shows it can be set to extra lift of 0mm to 1mm in increments of about 0.1mm. You will be able to do this with a GT1 as well.
Old 08-27-2013, 04:33 PM
Rahulk Rahulk is offline
Mein Auto: E53 N62; E90 N52
Same exact thing happened to me when I replaced my valve seals... Cylinder 5 lever spring jumped off... I guess we have to be careful that the lever compresses the valve spring evenly when reinstalling. Glad you succeeded!
I hope you changed the water pipe too! That thing leaks between 80k and 200k.
Way cheaper to change it with the lower timing case off.
Did you resurface the heads?
Old 08-27-2013, 04:59 PM
Mein Auto: 645Ci
Hey, yeah thanks. I was so happy when I found it! Well done for finding it too. The heads were skimmed as slightly warped.
Infamous water pipe definitely done! I was shocked at what a state the large bonded o-ring was in.
Old 04-27-2014, 10:56 PM
ROSSBOSS ROSSBOSS is offline
Mein Auto: E70 4.8
Spring out of position
Hello,
First I would like to thank you for posting, you have been very helpful... I too have the same exact rough idle after warm up problem at cylinder 5. After taking my X5 to an indy shop and then to the dealer they could not find the problem. They wanted to take the heads off to do further inspection but once they gave me a quote on what it was going to cost and no guarantee on what they would find I decided to have a look for myself. So long the short, I get the valve cover off and at cylinder 5 for both intermediate lever retainer springs were out of position just exactly like your photo.
I'm not sure how this could have happened. I purchased the truck a few months go, 2007 X5 4.8 it has 90k miles on it. The truck drove fine when I purchased it, no rough idle at all. I think the springs could have popped out from driving too hard, getting the RPMs too high, close to red line.
My question for you is, how is your car running now? After just putting the spring back in it's proper position did you have any problems, anything need to be replaced?
Thanks.
Old 04-28-2014, 06:36 AM
Mein Auto: 645Ci
Originally Posted by ROSSBOSS View Post
Hello,
Thanks.
Attachment 436210
You are most welcome and well done for finding the fault!
One year on and the car has been fine. Nothing had to be replaced. Mine happened during engine work so hard to say about yours. Although your theory of over-revving sounds possible. Hard not to with the V8 though!
Any history of recent engine work?
Fingers crossed for you that it is sorted.
Old 05-01-2014, 07:17 PM
Mein Auto: E70 4.8
The Fix
So after putting the Intermediate Lever Spring back into position the problem has gone away. No more misfire at cylinder 5, running smooth.
These are the steps I took to figure out this problem:
Replaced Spark Plugs
Moved Coils
Moved Injectors
Compression Test
Leak Down Test
Removed Eccentric Shaft Sensor Connector
After removing the Eccentric Shaft Sensor Connector I was able to pin point the problem. By removing this connector the eccentric shaft moves to a default position (this should be done with the vehicle turned off). After turning the engine back on the misfire was no long present which led me to removing the valve cover for inspection.
Old 08-19-2015, 08:19 PM
softx softx is offline
Mein Auto: BMW
Attachment 368300 Attachment 368301 Attachment 368302
Attachment 368303 Attachment 368304 Attachment 368305
Hi.
i have the same problem as you,
how do u adjust it??
