Old 03-25-2013, 07:49 PM
rmerkushen rmerkushen is offline
Mein Auto: E90 330i, E83 X3si
2007 clicking noise
105k miles on my x3.. Started hearing consistent clicking noise coming from the front of the car.. It seems that intervals are pretty consistent, about 10-15 seconds.. Any ideas?
Old 03-26-2013, 07:01 AM
dukedkt442 dukedkt442 is offline
Mein Auto: 08 E83; '86 442; 84 GMC
Does it vary with vehicle speed?
Old 03-26-2013, 08:24 AM
Originally Posted by dukedkt442 View Post
Does it very with vehicle speed?
Not sure, I can only hear it while it is stopped..
Old 03-26-2013, 03:31 PM
If the vehicle is stopped, it at least narrows it down to something engine-related. Could be anything from lifters to fuel injectors to rattling belt tensioners... my E46 had a "ticking/clicking" that I discovered to be a drive belt tensioner mount so loose that it was wobbling against the block.
Old 03-26-2013, 06:10 PM
spokelizard spokelizard is offline
Mein Auto: 2007 X3 MT
This is a long shot, but when I had a clicking sound it turned out it was a defective heater fan, not from the engine compartment at all, just sounded like it was.
Old 03-26-2013, 06:36 PM
Mein Auto: 2004 X3 2.5i
That's what I was thinking too. Haven't had that problem myself, but I think it is often described as a cricket sound.
Another possibility is the engine cooling fan with a bearing going bad or maybe the multi-speed switch module having a dirty contact.
Old 03-26-2013, 07:13 PM
fivepointnine fivepointnine is offline
Mein Auto: BMW X3, Hyundai Genesis
secondary water pump? (heater pump, whatever you want to call it) see if it goes away when you turn off your heater
Old 03-26-2013, 08:06 PM
x3brian x3brian is offline
Mein Auto: X3
Can you hear the sound from outside the vehicle with hood up or just inside?
If outside...An 07 in jersey at this time if year...I would say ticking valve lifters or electric fan.
But if only inside, the heater fan is a great potential source.
Old 03-27-2013, 06:00 AM
timfitz63's Avatar
timfitz63 timfitz63 is offline
MT = Doppler Shifting
Mein Auto: 2007 X3 (MT)
Originally Posted by rmerkushen View Post
... It seems that intervals are pretty consistent, about 10-15 seconds.. Any ideas?
That seems to be too long an interval for engine-related 'ticks' (belt tensioners, lifters, etc.); the chirping/squeaking/ticking for those things happens much more rapidly. I admit I'm not familiar with the sound of the engine fan ticking, though... Or am I misunderstanding what you're saying here about the interval between sounds...?
X3 w/6-speed & Sport Package:
A sports sedan disguised as an SUV...
Old 03-27-2013, 08:10 AM
Its not valve lifters, I know what those sound like. Consistency of it, ticking every 10-15 secounds is what makes me think that it is elctrical. Listening under the car for a few minutes it was more audible in the radiator area... I will check the radiator fan. Could it be water pump?
Old 10-11-2014, 08:07 PM
bmwmsport11 bmwmsport11 is offline
BMW FTW!
Mein Auto: 2006 BMW 330XI
Anybody ever find the solution to this issue yet? Just a few weeks ago my X3 developed the same issue. A clicking(or thumping) noise every 10 seconds, it would send a vibration through the steering wheel. Can only be heard from inside of the car or torwards the firewall under the hood when stopped. The noise goes away if the fan is turned off.
From what I've read on the forums it's all about the blower fan making a whining/cricket noise...so I'm not sure if it's the blower fan or not that's causing this clicking. Really hope this is a simple DIY type of fix, I would really hate for the heater to stop working during the winter...
