E34 (1989 - 1995)
Old 03-26-2013, 03:29 AM
aidagreat aidagreat is offline
Mein Auto: 1990 525i
What motor can i pu in my e34 525i
Looking fir motors to drop in it i have a singke cam m20 but i want to go stronger. In need of help..
Sent from my SGH-T759 using Bimmer App
Old 03-26-2013, 05:00 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
I want one with a GM LS platform V8 and six speed manual. Truth is, you can fit just about anything with enough time and money. I have seen Japanese, American and German engined versions of these cars. Probably the biggest questions are your budget and skill level...
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 03-26-2013, 07:45 AM
3star 3star is offline
Mein Auto: 89 E30 Cabrio
Best answer ever but yeah you have alot of options.
The easiest is the m50 or m52its not much more power but the after market support is pretty good.making it a good platform to build on
the m62b44 will work you can find the mounts for this swap online just do a Google search for it. Its also a fairly common swap. And those engines are very affordable.IMHO this is the best swap for these cars.
Other swaps I've seen are the s52 and s54 swaps. Way more work and money, and Toyota 1jz swap. You can also do the ls1 t56 swa. I think the mounts for that swap are also available online.
The m20 is also a good engine it maybe single cam but it does have after market support. Schrick sells cams for it. And there are alot of Turbo builds out there you can follow. Although I'm not much of a Turbo fan
Old 03-27-2013, 01:43 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
put two M20s in there like i did, that will make it get up and go
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 03-27-2013, 05:22 AM
Im trying to waste like 1500-2000 on a motor
Old 03-27-2013, 05:24 AM
What do u mean by put two m20's
Old 03-27-2013, 06:09 AM
The Ornery Old Man
Mein Auto: GTI
The M70 (fitted to Andy's touring) is pretty much two M20's on a common crank.
Go Big or Go Home
Old 03-27-2013, 11:47 AM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
It would be cheaper and more practical to sell your 525 and buy yourself a 540 or 535 , its within reach of your budget
Sent from my Desire HD using Bimmer App
Old 03-27-2013, 07:52 PM
M62b44 swap is the best bang for buck choice and can be done for that much. I've seen them sell as cheap as 500.00 the after market hasn't caught on to their potential. But it makes the most sense, you not only get 280hp but you also lose weight upfront. The m62 is a very lightweight engine its lighter than a Honda f20 engine from a s2000.
Old 03-27-2013, 07:55 PM
But then yould have to deal with a car that yould have to sort out. And it would have e a nisil engine. Plus finding a manual one is gonna be difficult. The insurance might also be more
Old 03-28-2013, 12:54 AM
This
mechanical issues are a lot better than the inevitable electrical gremlins that ALWAYS come with engine swaps. your M20 engined E34 was not sold alongside the M60, and usually the wiring adaptors are different.
and the nikisil "issue" you are talking about was a problem from almost 20 years ago when these cars were made. it might be on Wikipedia. but its hype. nothing to worry about. all affected engines were replaced under warrenty or would have well and truely died by now if they were going to at all.
E30 above Sold
Old 03-28-2013, 07:44 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
1JZ-GTE because it fits and because turbo
build
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 03-28-2013, 07:42 PM
manuelwindows manuelwindows is offline
Mein Auto: 1994 530i, 1977 320i
if your engine is still running and you have a nikasil block, you don't need to worry about it anymore. the problem would have showed up by 50,000 miles. the fuel is too clean in the US for it to be an issue at this point. it would have been the fuel from about 15 years ago that had a high enough lead content to eat through the nikasil components and cause damage. so if it hasn't happened by now, it won't happen. at least not with US fuel
the Nikasil block is the biggest boogeyman put out there on this series when they can't find anything else wrong with the engine.
The dealership told me that an engine hesitation and low idle I had in my e34 with 175k was from the Nikasil block. then I changed the spark plugs and the engine runs like brand new now.
Otherwise, I have to echo some of the sentiments here and just recommend getting a 540i for that kind of power instead of dealing the electrical gremlins that an engine swap is going to create, unless you enjoy the process of problem solving.
I have heard of one person putting a Chevy V-8s in 94 530i's but I cannot confirm that rumor. It's probably on some thread somewhere.
But on the broader view of things, why would you need a six speed for anything but track racing or driving 120 mph on the Autobahn?
Old 03-29-2013, 06:33 AM
The Ornery Old Man
Mein Auto: GTI
It isn't lead that is the problem, it was sulfer content that caused problems for the nikasil coatings. You are correct, it is no longer an issue in fact nikasil coatings are still used today, my sled has freshly re-coated cylinders, about $200 each to refinish.
I wish my 535 had a six speed. 1-5 for performance, 6 to get the rpm's down on the highway for economy. Or, like my six speed truck, 1 for low speed grunt work, 2-6 for road duty. Seems like a good balance for most vehicles. I do not understand the new 8 speed automatics though. That seems like it would be really busy.
Old 03-29-2013, 07:59 AM
I don't know, my 530i is at about 2000 RPM in 5th gear at about 60 mph and gets me about 28 mpg. Every once in a while, I'll juice it on a lonely highway but I frankly can't afford to get a ticket and even more, I can't afford to have my insurance jacked after that ticket.
I'm still recovering from the 100 mph ticket I got in my 1985 535i in Tennessee from years and years ago. I'm only lucky my radar detector went off all of a sudden and I was able to get down from 120 mph, before he got me.
"Do you know how fast you were runnin', boy?"
You don't wanna hear a cop say that.
Old 03-29-2013, 12:00 PM
You bring back some bad memories I heard that line only it was followed by "you have the right to remain silent..." I was going 100+ in a 40 zone in Florida that's jail.
Old 04-11-2013, 07:00 AM
Im just trying to put a new motor cause im at 230,000 miles and i don't wanna take a risk. Imjust looking for a motor i can by and just drop in the car really
Old 04-12-2013, 05:02 AM
The Ornery Old Man
Mein Auto: GTI
Just find another M20 and drop it in then That would be the easiest and cheapest route.
If there is nothing wrong with the engine in your car currently, I would keep driving it and not worry. If well cared for that engine could still last for years.
Old 04-12-2013, 05:59 AM
Cause i really wanna dual it with the m50 and surcharge it i week the m50 will breath better then the m20
Old 04-12-2013, 06:03 PM
M20 performance parts are cheaper than m50. And the m20 is a pretty good engine. IMHO though if I were doing a swap I'd go to a m62
Old 04-13-2013, 07:16 PM
RedNeckBimmer RedNeckBimmer is offline
Red Neck Bimmer
Mein Auto: 1990 BMW 525i
whoa, wait , time out !! ... are you saying M20 performance parts cheaper than M50? how much cheaper?
Old 04-13-2013, 09:15 PM
Red Neck Bimmer
By the way, aidagreat, what part of N.J. are you at?
Old 04-19-2013, 03:56 AM
cnj n you
Old 04-20-2013, 11:21 AM
Red Neck Bimmer
Northern N.J.
Old 04-20-2013, 07:26 PM
what is a good piston to put in my m20
