Old 03-26-2013, 10:24 AM
X5bimmerguy X5bimmerguy is offline
Mein Auto: X5
HK subwoofer not working in 2011 328i
The driver sub works great, but the passenger sub does not. Upon removing the passenger seat and removing the speaker grate, it appears some liquid spilled under seat (don't know situation as I' m the second owner). The speaker connector has sticky goop all over it, perhaps disrupting the connection. Of course, warranty won't cover damage....
My plan is to clean the connector and see if this fixes the problem. If not, any ideas what I should try next? Does the HK amplifier have some build-in protection so that a speaker short will not ruin amp? If the driver side sub works, does that mean the amp should be OK?
Any thoughts/suggestions much appreciated!
Old 03-26-2013, 11:49 AM
ctuna ctuna is online now
Mein Auto: 325xi wagon
Measure the coil resistance with an ohmeter.
That will at least give you an idea if its electrically intact.
Should be 2 to 3 ohms.
Also for stereo questions go here
http://www.e90post.com/forums/forumdisplay.php?f=27
You may be able to find somebody who will sell you one at the above location.
You should identify which of the three system you have before trying to replace it.
Old 03-26-2013, 12:28 PM
Mein Auto: X5
Thanks for the input, Ctuna.
Old 03-26-2013, 03:09 PM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
Should be 3-4 ohms.
Fixed.
Old 03-26-2013, 06:48 PM
I measured my underseats in a Hi Fi system at 2.1 ohms.
Stock under seats measure 2.1 ohms at the amp tightening screws.
And I was using a Fluke 77 digital multimeter.
This was during my xd 600/6 install.
According to the BMW stereo pdf all speakers in the Hi Fi are 2 ohm . I don't
know all the details of the other systems but they are suppose to be correct
in this pdf.
http://www.e90post.com/forums/attach...2&d=1266451970
Old 03-27-2013, 07:28 AM
Mein Auto: X5
Update: Removed passenger seat and exposed subwoofer. Connection between wire from amp and subwoofer covered in dried sticky liquid (the hidden cost of buying a pre-owned vehicle). Disconnected and cleaned both ends thoroughly with isopropyl alcohol. Let dry. Checked resistance of subwoofer with ohm meter: 2.6 ohms. Reconnected sub to amplifier and still no sound. Recommendations? Thanks.
Old 03-27-2013, 07:36 AM
///M-Furby's Avatar
///M-Furby ///M-Furby is offline
IntarWeb Stalker
Mein Auto: 2016 M3 SO ZCP
This is the main thing I hate about the speaker - it's placed in an area that can get liquids easily spilled on it. It doesn't even take someone to spill a can of soda, just walk in from the rain. It would have been much better if the speakers were connected to the seats which would make them elevated off the floor by an inch or two. Or at least make these speakers water proof.
Why not take it in for service? Don't mention you took anything apart
"Tomato" ED 2016 M3 | B50 | ZCP | X3SW | ZDB | ZEC | ZLP | 2MK | 5DP | 6NS |
"Booberry" ED 2013 335xi | Returned
"Boo" CPO 2006 330xi | Sold
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
