Old 03-26-2013, 02:06 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
RFT Puncture
I think I have a puncture... one front tire pressure dropped to under 200psi this morning
Will get it fixed asap... a real pain
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 03-26-2013, 02:11 PM
///MyLittlePony's Avatar
///MyLittlePony ///MyLittlePony is offline
Outside looking in
Mein Auto: 2015 Mustang GT
Originally Posted by SilverX3 View Post
I think I have a puncture... one frotn tire pressure dropped to under 200psi this morning
It is an achievement to get the tire pressure that high in the first place without it bursting! Well done!
My Little Pony
Old 03-26-2013, 02:30 PM
SilverX3's Avatar
sorry I emant under 200 Minibar
Job - Captain
MY11.5 X1 Xdrive25i
Old 03-26-2013, 02:53 PM
laser's Avatar
laser laser is offline
now driving number eight!
Mein Auto: 2007 S2000
Ah ... hitting the mini bar again .... that could be the problem ....
Laser
"sometimes you're the windshield .... sometimes you're the bug"
___________________________
2014 328i Mojave Metallic
2009 328i Black Sapphire Metallic
2007 328i Black Sapphire Metallic
2007 Honda S2000 Berlina Black
(Hey Jim... am I diversified?)
Old 03-26-2013, 06:14 PM
SilverX3's Avatar
milibar
or whatever
Job - Captain
MY11.5 X1 Xdrive25i
Old 03-26-2013, 10:24 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
milibar
or whatever
For tire air pressure, we in the U.S. only understand "PSI." Everthing else is foreign.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 03-26-2013, 10:40 PM
pointandgo's Avatar
I can empathize...my tire dropped to 2.0 furlongs per fortnight yesterday (21 psi)...it's an excruciating "conversion" to "psi" - pounds per square inch...but this is payback for your attempt to confuse us with Australian "metric" systems.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 03-27-2013, 01:18 AM
jadatis jadatis is offline
Mein Auto: no BMW
Could also be that you hit a pavement side ( you see I am also not from America), wich opened the rimm tire contact a short while.
Yust pump it up and see if it stays at pressure.
Could be you have to reset the TPMS .
But its 2.0 bar/ about 29 psi/ 200 kPa ( kiloPascal).
In millibar it would bee 2000.
So now enaugh about the miswriting
I live in Holland and once got hold of the system the tire- and car manufacturers use to determine the advice-pressure for cars. Learned myself Excell to make spreadsheets for it.
Next link leads to map with spreadsheets to re-calculate advice pressures for non-OEM tires, or to check the original.
http://cid-a526e0eee092e6dc.office.l...0tyre-pressure
Old 03-27-2013, 03:00 AM
Banned
Mein Auto: 2007-335 HTC
well take the wheel off, and look at the tire and see if you find a nail or screw stuck in the tire, but get a tire puncture repair kit first, if you find a nail, pull it out and stick a plug in it, then spray the plug with some soapy water and if you see no bubbles, then you have fixed the puncture, then pump the tire up.
Easy
Old 03-27-2013, 11:57 AM
SilverX3's Avatar
Turned out to be a low pressure .... dropped under 220 Kpa while the other tire is at 280...., pumped up yesterday...... Overnight still good....
Job - Captain
MY11.5 X1 Xdrive25i
Old 03-27-2013, 04:12 PM
Red bull Red bull is offline
Mein Auto: BMW 3 328i.
My tires have 36psi. Nitro.
Old 03-27-2013, 04:32 PM
laser's Avatar
78% or did you go full pure?
Laser
Old 03-27-2013, 05:03 PM
Pure baby all the way.
Old 03-27-2013, 05:55 PM
SilverX3's Avatar
I fill my with Helium... makes the car float when driving
Job - Captain
MY11.5 X1 Xdrive25i
Old 03-28-2013, 05:58 AM
e92josh e92josh is offline
New Guy
Mein Auto: 2009 328i Coupe
my sensor literally fell off in the tire the other day, SMH.
Old 03-28-2013, 08:54 AM
gpburdell gpburdell is offline
Mein Auto: 2010 335i Cabrio
How do they get all the 78% mix *out* of the tire in order to ensure it's really filled with 100% N2?
Old 03-28-2013, 09:24 AM
Deflate tire , then fill with nitro.
Old 03-28-2013, 10:39 AM
ard ard is online now
Resident Curmudgeon
Brilliant replies on the N2...
it is a scam, and most knowledgeable folks know this. The nitrogen concentrators at the tire store actually only get to 94%..so 78 to 94. And all those 'benefits'? Utter fabrications and extensions. (Unless you are using bottled N2, 99.99 technical pure, and have filled and flushed 3x)
The 'why'? To sell people something at the brick and mortar store to counter the squeezing of profits due to internet tire sales.
Old 03-28-2013, 01:09 PM
Even deflated you're still looking at a tire filled with air.
*shrug* If you're happy with it, that's fine.
Old 03-28-2013, 02:29 PM
SilverX3's Avatar
Nitro particles are bigger than air ... it won't escape through small cracks / valves... hence it stays in your tires longer.... however it's not free .... tire shop charges $2 to inflate
Job - Captain
MY11.5 X1 Xdrive25i
Old 03-28-2013, 05:55 PM
Resident Curmudgeon
That is an oft-repeated factoid that means nothing...The covalent radius and van der Waals radius are marginally larger on nitrogen (71, vs 66pm and 155 vs 153pm)... and the permeability of rubber is marginally lower for N2. (not that is pure sheet rubber, not vulcanized tires.) Hence this factoid. But in actual practice this difference is small and is not material. Recognize that "pm" is Pico Meter, or 10E-12 or one BILLIONTH of a millimeter.
The truth is that engineers and physicists have debunked this, yet it persists due to vendors pumping this product... And dumb****s with $$ to spend thinking the green valve stems make them 'special'.
You need to check tire pressures anyway, no matter what you put in them. Does checking every 58 days instead of every two months make a difference?
Now someone needs to say "Nitrogen doesnt expand like regular air, which is why race cars use it" ...so we can debunk that nonsense.
And again, tire stores only sell 94% "pure" nitrogen
Old 03-28-2013, 06:54 PM
SilverX3's Avatar
Are you a scientist ?
Job - Captain
MY11.5 X1 Xdrive25i
