Old 03-26-2013, 08:47 PM
robofig robofig is offline
Mein Auto: z3
help with z3 seats will not move
Just installed Doug w. bushings and now the seat will not slide forward or back.
There is a slight movement but then no go.
The seat will move up and down no problem.
Is there some type of seat reset or ?
Any help would be great
Old 03-27-2013, 05:34 AM
Mein Auto: z3
Any one ?
Old 03-27-2013, 08:28 AM
dadmog dadmog is offline
Mein Auto: 98 MZ3
possible that one of the worm-drive tracks is in backwards, so that they are turning in opposite directions?(and consequently, going nowhere)
Old 03-27-2013, 04:51 PM
Mein Auto: z3
NO chance of that. Did one track at a time.
Anyone else have any other ideas?
Old 03-27-2013, 08:20 PM
cohiba7777 cohiba7777 is offline
Mein Auto: 1999 BMW Z3 2.3
motor is engaging? If not did you check fuse? I blew a fuse on mine when reconnected after fixing mine a few weeks ago.
Old 03-27-2013, 08:38 PM
eurospec eurospec is offline
Mein Auto: '99 MCoupe
I'm assuming you sanded the bushings down? How snug were they installed in the carriers?
Old 03-27-2013, 08:52 PM
Mein Auto: z3
Yes I did sand them down but not enough. I found that they have to just about fall into the block. The factory rubber must of had alot of movement.
I have a happy customer now, (my 70 year old aunt) thanks for the help.
Old 03-30-2013, 07:43 PM
atopa2002 atopa2002 is offline
Mein Auto: 2009 e90 335i
You make sure everything is lined-up when putting those long screws in place and they were lithium greased?
Old 03-30-2013, 10:34 PM
Mein Auto: z3
what
Old 03-31-2013, 01:05 AM
I have you watch the you tube videos on this.
Here is the link,they are 3 parts video.
[/ame]
John
Old 03-31-2013, 01:16 AM
The part 2 video shows where you should make the bushings are the a same position on the long screws and lithium grease the screws.
