Old 03-27-2013, 03:08 PM
mlvswoll mlvswoll is offline
Mein Auto: 08 535i
Steering noise on 08 535
I own a 08 535i and have noticed a "howling" or low pitch screeching noise while steering at low speeds. It is brief and happens intermittently without cutting the wheel fully. I have found info pertaining to noise in the steering on E60's and the existing bulletin for adding Lubrizol to the power steering fluid. However my car using the Pentosin fluid for power steering and this bulletin fix does not apply to my vehicle. Just wondering if anyone with the Pentosin fluid in power steering has had this corrected. I also found a strange thread suggesting you change the rear diff fluid to eliminate noise. Not sure how that would come into play with noise in the steering rack, but I'm open to suggestions. Thanks in advance for any info you guys can contribute.
Old 03-27-2013, 03:44 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
You are using the Pentosin CHF-11 (?) fluid? If so that isn't just for power steering, it is also for the ARS system. So no, you can't use that fix you mentioned. However, about the noise, I would go back to the old tried and true method of checking the belt tension. A belt that is too tight or too loose can cause noises like that.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 03-27-2013, 05:02 PM
hkninja hkninja is offline
Send a message via AIM to hkninja
Mein Auto: 2008 535i sport pkg
My 535 have the same noise for over a year and never got it fix. The noise is there only when I turn into a parking spot etc at low speed. I would like to know how to fix that as well.
08 535i 6MT - JB4 G5 ISO - BMS meth tank (100%) - Luke performance backend flash - AR design catless DP - ETS intercooler - BMS DCI - BMS OCC - ER chargepipe - HKS bov - K-sport coilovers - UUC evo3 ssk - CDV delete
Old 03-27-2013, 05:59 PM
Mein Auto: 08 535i
Hkninja, same thing for me. Parking spots and turning from a stop at low speeds. Pjinca, I considered tensioner or belts however the noise is accompanied by vibration or extra tension in steering column as well. Like something hitting a rough spot and not having adequate lubrication, then goes right back to smooth steering.
Old 03-27-2013, 06:00 PM
Mein Auto: 08 535i
Oh and yes Pentosin CHF-11
Old 03-27-2013, 06:11 PM
nickp3 nickp3 is offline
Mein Auto: 08 535i
+1 could never get it to do it at the dealer, mine still does it randomly pulling into a parking spot
Old 03-27-2013, 07:14 PM
Mein Auto: 08 535i
Yeah, it is intermittent but I'm noticing it more and more. My nearest dealer is an hours drive and I hate to drive two hours round trip to hear "oh we couldn't replicate the problem." I think a buddy of mine knows two of the techs at my dealer. Going to see if I can pick their brain on the issue. I'll let you guys know what I hear.
Old 03-27-2013, 07:33 PM
6ICEMAN9's Avatar
6ICEMAN9 6ICEMAN9 is offline
Mein Auto: 08 550i
Same here, and didn't know what it was.lol Figured someone would mention it sooner or later. PLEASE let us know what they say mlvswoll.lol
Old 03-28-2013, 05:48 AM
Mein Auto: 08 535i
Might be a few weeks guys. I got the name of the tech from my friend and he is booked up for a week. I like having someone I know in some fashion work on my car if at all possible. The following week I'm out of town for business. I will however update this thread as soon as its checked out.
Old 03-28-2013, 06:09 AM
redhotdave redhotdave is offline
There's another thread on this. One possibility is its not the steering at all, it's the brakes not having fully released, and if this is the cause o the noise then it's not a problem.
I've experienced the noise, but never any vibration.
Old 03-28-2013, 12:03 PM
There is a module in the steering column that has failed sometimes and can present the symptoms you're describing. I can't remember the module, nor could I find the threads (in another forum) during a quick search, but it might be a good idea to check it. Sorry I couldn't help more.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 03-28-2013, 09:45 PM
MSAMMY MSAMMY is offline
2007 550i & X3, 2002 X5
Mein Auto: BMW 550i, X5, X3
We've had this problem now for 6 years and 58K miles and no resolution! It must be the brake pads oscillating on the rotors while turning. Check out this thread I participated in starting in 2007.
http://www.bimmerfest.com/forums/sho...ighlight=wooow
2007 550i, Sport Premium, Silver Gray Metallic, Gray Dakota, Navigation, Cold Weather Package, Comfort Access, Heated Rear Seats, HD Radio, Xenon
2007 X3, 3.0si ///M Sport Premium, Monaco Blue, Gray Dakota, Navigation, Cold Weather Package, Xenon
2002 X5, 3.0i Sport Premium, Titanium Silver, Gray Dakota, Cold Weather Package, Xenon, just a winter vehicle
Old 03-31-2013, 09:13 AM
rrj rrj is offline
Mein Auto: 545
I also have the same problem. I took the car to BMW Friday. The dealer said that it's my struts and that it will be $2,500 to replace them...
Old 03-31-2013, 10:06 AM
Munich77 Munich77 is offline
Mein Auto: 2014 E550 4matic
Nice time to take it to another dealer....
2008 535 xi, space grey, black dakota leather, premium package, sport package, cold weather package, nav, folding seats, PDC
BMW CCA Member
Old 03-31-2013, 12:36 PM
2chill's Avatar
2chill 2chill is offline
Mein Auto: 2008 528XI
I hear the noise every now and then also when pulling into a parking spot. I've learned to live with it. I've come to realize there is no such thing as the PERFECT car...
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats.
Old 03-31-2013, 05:38 PM
rrj rrj is offline
Mein Auto: 545
I'm taking mine to an Indy tomorrow morning... He disagree with the dealership...
Old 03-31-2013, 06:57 PM
Mein Auto: 08 535i
rrj, I would do that as well. If you are experiencing the same thing I am then I don't believe the struts have anything to do with it.
Old 04-01-2013, 08:20 AM
not the strut for sure because I have coilovers on my car and it is doing the same.
Old 04-03-2013, 02:59 PM
bankerdave bankerdave is offline
Mein Auto: 2010 550i
Yeah, this happened on my previous 535i and current 550i. Took the current 550i to the dealer twice and replacated the sound. They technicians thought it was the brakes, changed the pads, flushed the fluid and cleaned the rotors. Sound is still there. Told me that if it doesn't impact performance, there's not much they can do. But added that if the sound gets more frequent and louder, bring it back.
2010 550i | Space Gray Metallic | Black Dakota Leather |
Bamboo Anthracite | M-Sport | SAT | Navigation | Preimum Audio (Logic 7) | Satalite Radio | Comfort Access | Rear Sunshades | Cold Weather package | PDC
Old 04-04-2013, 09:29 AM
Clarkbb704 Clarkbb704 is offline
04 545i
Mein Auto: 2004 545i
2500 for struts?!?!
Had mine done for 500 and thought that was a bad deal... The part is only $50 dollars after all.
My advice, don't go to the stealership
Old 04-16-2013, 02:41 PM
beethoveen beethoveen is offline
About 1 to 1.5 yrs ago I noticed a very subtle crackling sound at low speed steering actions (e.g., pulling in/out of driveway) but not the "howling" noted in this thread. It was more like knuckles cracking. Anyway, took it to the dealership and they said they needed to replace the whole steering mechanism and knock on wood, no problems since. All covered under warranty fortunately.
Old 04-20-2013, 09:55 AM
NYBIMMER91 NYBIMMER91 is offline
Mein Auto: 2014 335i M-Sport
I have an 06 530i with active steering and have had a noise when turning for months. Its like a grinding sound when making a left turn only even at high speeds. Its so irritating that I feel like getting rid of the car sometimes.
I have brought it numerous times to my indy to fix, he cant find any issue except the power steering pump or active stabilizer bar are possibilities but those both are easily $1500 + each. I even brought it to the dealer. Said it was thrust arms, belt, and sway bar. Replaced the thrust arms, and belt, noise is still there.
Everything is fine. Bearings, pulleys, suspension, drivetrain. No one has a clue and still not fixed.
Old 12-20-2013, 06:30 AM
Mein Auto: 08 535i
Sorry for the delay in response, been slammed at work. I have been to the dealer twice and they could not get the car to do it while in their possession. Topped off the pentosin fluid. Noise is still there. I will changing the serpentine belt soon and checking the pulleys to see if anything needs replacing. My tech said a I could be briefly losing power steering if there is a tensioner issue. We shall see.
