Old 03-27-2013, 10:06 PM
lacrosse12 lacrosse12 is offline
Mein Auto: 545i
Bumpers and sideskirts upgrade
Hi,
This question may have been asked many times, but I just want to make sure before making a purchase.
I have a 545i with sport package and I want to upgrade my front, rear and side bumpers eventually. I was looking at Umnitza...
Front (mtech): http://www.umnitza.com/e60-5series-m...nt-p-5866.html
Rear (m5 style): http://www.umnitza.com/e60-5series-m...ar-p-1329.html
sideskirts: http://www.umnitza.com/e60-5series-m...ts-p-1325.html
Just to clarify, all of these bumpers (mtech front, m5 rear and mtech sideskirts) are all able to fit without any cutting (just screwing them in)? Again, I know it says they fit on the website, I just don't want to get any surprises. Sorry for the longer post.
Thanks_a_
Old 03-28-2013, 02:16 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
The front and sides are fine, howevevr, I hate the replica M5 rear bumpers. They have an annoying bow in the middle that is so visible, the front bumpers have it too, but since they are lower it's hardly visible. The rears have it and it sits right about eye level for the car behind you and it looks stupid. Best bet would be to find a used OEM M5 rear on eBay, I got a used OEM for my old 530.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 03-28-2013, 02:53 PM
Cattani Cattani is offline
New to BMW
Mein Auto: 2006 550i
How difficult is it to fit an OEM M5 to a pre-LCI 550i you think?
2006 BMW 550i Base
Old 03-28-2013, 03:10 PM
Front or rear? The M5 is 10 mm wider in the front than non-M cars, so it takes significantly more work to fit the M5 front without also fitting M5 front fenders. The rear of the M5 is identical to the non-M so it fits perfectly without any modification.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 03-28-2013, 06:33 PM
JFIVE JFIVE is offline
Mein Auto: 545i
You also would have to change the wheel well liners for the front, brake ducts, and foam bumper supports I believe they are called if using the oem mtech front bumper, not sure if you need the same for the after market replica
Total for extra parts around $250.00
Sent from my SPH-L710 using Bimmer App
Old 03-28-2013, 06:53 PM
Mein Auto: 545i
Thank you all for the information.
Old 03-29-2013, 08:09 PM
Mein Auto: 545i
In regards to the Mtech front bumper issue with the brake ducts and foam bumper supports, will these work?
(2 of them) http://www.ecstuning.com/Search/51117896591/ES74915/
(2 of them) http://www.ecstuning.com/Search/51117896587/ES74913/
And if they do work, are these an easy install?
Again, thanks.
Old 03-30-2013, 01:08 AM
Mein Auto: 545i
They should work, the wheel well liner is the only item you may or may not need depending on your choice of oem or replica bumper
Old 03-30-2013, 01:41 AM
roskinc roskinc is offline
Mein Auto: 525i
regarding the rear m5 style bumper, the middle part does have a warp/bow in the middle, i found the easiest solution to fix this is put a thing metal ruler size sheet metal between the plastics, keeps it straight and fixes that bow issue. simple and easy fix.
Old 03-30-2013, 04:08 PM
E60Brooks E60Brooks is offline
Mein Auto: 2004 545i
Do you know if the wheel well liner is needed for the replica? If so, will these work? http://www.ecstuning.com/Search/ES128632/ES128632/ http://www.ecstuning.com/Search/ES128633/ES128633/ Thanks
Old 03-30-2013, 05:50 PM
Mein Auto: 545i
Don't think so for the replica but the oem does need the liner or if your comfortable you can trim the original to fit
Old 03-31-2013, 12:12 PM
Alright, thank you for the help.
Old 04-04-2013, 02:20 AM
Mein Auto: 545i
How much does an installation of all four bumpers cost because I was quoted $800 JUST for install, which seems quite high considering people have done it by themselves. The shop said they never come perfect and will end up having to cut/modify them to have the screws aligned perfectly. I'll be calling more places for quotes so I can get a better idea. Thanks
Old 04-04-2013, 05:06 AM
Mein Auto: 545i
If that's including paint with the price quoted.
The usual cost is about $300 per bumper and side skirts about $200, the quality of the kit is where it can be expensive for the install if it needs modification
bumpers, sport package, umnitza
