Old 03-28-2013, 04:01 PM
cohiba7777 cohiba7777 is offline
Mein Auto: 1999 BMW Z3 2.3
Let me Stump You - '99 Z3 2.3 Inst. Cluster Question
I haven't been able to find or source this part anywhere - let's see who the smart guy/gal is....
Part is referred to as Speedometer Upper and Speedometer Lower - its the black ring around the outside of the Inst. Cluster. Somehow my bottom half is missing & I want to replace as I stare at it every time I drive my rig. Problem is - I can't find this part even at realOEM. My guess it is part of the IC OEM assembly - but - holding out hope.
ANY input greatly appreciated - thanks!
Old 03-28-2013, 04:42 PM
Monolith Monolith is offline
Mein Auto: 1997 Z3 1.9L DASC Auto
Are you referring to the instrument cluster gauge rings? You might want to consider upgrading to the chrome set.
http://bmwz3diys.weebly.com/chrome-r...4-m50-m52.html
Old 03-28-2013, 06:07 PM
Negative - this is outside the speedometer/instrument housing ... a squat-oval ring that I think is actually a top and bottom half. Black in color, plastic and a bear to find.
Old 03-28-2013, 06:32 PM
Upload a photo.
Old 03-28-2013, 08:10 PM
Upload a photo.
here it is - the black trim -
Old 03-29-2013, 09:51 AM
Any Takers???? NO one has had to replace this - ever?
Old 03-29-2013, 12:28 PM
It is not apparent, at least to me, what is missing from the photo of the cluster you posted. If the bezel is broken, you'll need to find another cluster and insert your guts into the cluster housing.
Old 03-29-2013, 02:09 PM
You're kidding? I need the black ring - the trim piece around the protective glass if the cluster unit.
Old 03-29-2013, 03:26 PM
Still not 100% on what you're considering to be "trim" as the front black piece is one piece. Follow the pictures in this thread as the owner takes the cluster apart. I asked for your photo because I wanted to see how the "trim" was broken. I've never heard of this happening before. The back blue part comes away from the black front part. I'm assuming you need the entire front black part which includes the clear lens.
http://www.unitedbimmer.com/forums/b...rings-e36.html
Old 03-31-2013, 10:36 AM
Interesting - so it looks from your post and the description that the front glass piece on the cluster is where the trim is affixed & that it is not a separate piece - my 'bottom' of the bezel is missing - 5" I would guess right in the center bottom. So I am trying to find what I need to replace to get that visual off of my inst. cluster.
Old 03-31-2013, 02:23 PM
Any front bezel from an e36 cluster should fit. I'd just shop ebay for a non-working cluster and swap out the front.
