Old 03-28-2013, 05:07 PM
Hemorrhage Hemorrhage is offline
Mein Auto: BMW 335xi
Correctly Testing A Component?
I'm trying to solve a misfire problem.
The misfire has no pattern. Every time it shoots an SES light, the cylinder(s) shown up on the scan tool differ.
It only "sputters" and misfires when it is above 160 degrees...meaning, the turbos put out more boost than when below 160 degrees.
...which makes me think something in the ignition system is failing due to high boost.
Either the HPFP can't keep up...the coils aren't firing, or the injectors or messed up.
How would you even diagnose this?
I don't want to throw money at it and hope it works...I want to correctly find the problem. However, I don't see how you could ohm check (or diagnose in general) a component that ONLY fails under high boost conditions.
The plugs were changed 5k miles ago, so...I don't think it's them...UNLESS NGK Platinums don't fit the vehicle's ignition system.
Old 03-29-2013, 03:45 AM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
Is the same cylinder misfiring every time?
Try swapping the coil with another cylinder and see if the problem follows it. Do the same with the spark plug. It's entirely possible you have a defective one.
Don't try this with the injectors.
Old 03-29-2013, 04:21 AM
It's not the same cylinder(s) every time, no.
Every time I pull the codes, the cylinder(s) that show up are always in a different pattern.
Old 03-29-2013, 05:30 AM
What do you mean by "pattern"? Are all cylinders misfiring but the codes are in a different order?
Old 03-29-2013, 05:47 AM
Sometimes it'll just say cyl 1.
Sometimes it'll say cyl 1, 6, 5.
Sometimes it'll say just cyl 2.
Sometimes it'll say cyl 1, 2, 3.
Old 03-29-2013, 06:31 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
What scan tool are you using?
What codes show?
Mileage?
Old 03-29-2013, 06:50 AM
Miles - 75k. The problem started around 69k when I put a tune on the car.
I'm using a BTech I bought off Terry.
As for the codes...I'll have to write them down next time I put the scan tool on it.
Old 03-29-2013, 07:19 AM
There's your problem.
Old 03-29-2013, 08:56 AM
Still acting up after removing the tune.
Old 03-29-2013, 12:17 PM
What, exactly, were the parts that were changed out?
Old 03-29-2013, 12:59 PM
All of the spark plugs, and one coil.
Old 03-29-2013, 01:14 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Those NGK plugs are probably your problem. Be absolutely certain they are the correct part number or buy them from BMW. The N54 is extremely sensitive to plug type and "almost" isn't close enough.
Old 03-29-2013, 03:20 PM
I kind of think it's them too. Not sure, though.
It still did it when I had the old, OEM plugs in it. However...those plugs had 70k miles on them. So, I don't know.
Old 03-29-2013, 04:40 PM
A sumptuous number of miles, it must be said.
Got Coke?
Old 03-29-2013, 04:42 PM
I just cleaned my valves last Sunday with carb cleaner and rags. The problem is still as bad as ever.
Old 03-29-2013, 07:51 PM
Dang, boy. First I've heard of any prob w/Terry's tunes....or are you using some kinda almost-Terry like Cobb or >GASP< Dinan?
'Course, Terry's tune prob just accentuated what was already happening.
Interested to see what codes show up!
Old 03-30-2013, 06:12 AM
DSXMachina's Avatar
Bimmerdex 7.4!
You had 70K on the original plugs?
It's Saturday, go buy the right plugs and install them before going further. Be sure to reattach any ground straps you disconnect to pull the coils.
Old 03-30-2013, 03:31 PM
I more than likely will change them.
Still would like to discuss some other possibilities, though.
A tech at my shop thinks it is a fuel issue.
If you push the throttle down far enough, it'll sputter. If you let off the gas and press the pedal again, it'll accelerate smoothly for a few sec. and then start sputtering again.
The tech at my shop thinks this is because it's not providing fuel fast enough. He said the reason it'll accelerate smoothly for a second or two is because you're allowing it to catch up.
Another thing...
If you put it in park and smash the throttle down, it won't do it. Only when moving the vehicle it'll do it.
So, I don't know what that could mean.
Old 03-30-2013, 03:34 PM
I don't blame his tune. I blame the higher boost causing a weak component to fail even further.
Old 03-31-2013, 04:38 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
how did you clean your valves with just rags and carb cleaner?
you didnt need to use brushes, etc?
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 03-31-2013, 04:40 PM
All I had was like...a paint brush.
So, I ended up wrapping a screwdriver inside of a rag to get the heavy stuff off.
Old 03-31-2013, 05:04 PM
were your injectors changed at any point?
Old 03-31-2013, 05:07 PM
Not that I know of.
I just wish I could figure out for sure it's them rather than just buy 6 injectors and hope it gets fixed.
Old 03-31-2013, 05:30 PM
can you try resetting the DME adaptations with your bav technic cable and see if you have the issue the first drive after you do the reset?
Old 03-31-2013, 05:31 PM
What would that do, exactly?
