E46 M3 (2001-2006)
Old 03-30-2013, 06:35 AM
MikeBock56 MikeBock56 is offline
Mein Auto: BMW M3
2002 M3 oil leak under oil filter housing unit
Have oil leak under oil filter housing unit ! 2002 M3 - replaced gasket , cleaned engine , drove 30 miles to burn off cleaner, then put car back on lift only to find it was leaking again! Mechanic said to bring it back and will tear down; seems leak is somewhere between bottom of oil filter housing and alternator ! Help !
Old 04-03-2013, 05:59 PM
shadowless's Avatar
shadowless shadowless is offline
Send a message via AIM to shadowless
Mein Auto: '06 M3 coupe, '07 X3
unfortunately, finding the source of oil leak can be like diagnosing abdominal pain in a woman of child bearing age.
i would say try to clean up the area as best you can and have the car running at idle. see if you can find the source that way.
it is going to be tough for anyone on here to help w/o pics with good resolution.
'06 M3 with VF-Engineering stage 2 SC, LIGHTWERKZ TFX retrofit 4300k 55W, Kreis-sieg, 3.91 diff, BBS LMs wrapped in F1s, Alcon, and a few other goodies....
452whp/322.7wtq on mustang dyno using 93 oct
'07 X3 3.0si with tint on front side windows only
Old 05-27-2013, 07:46 PM
JayMac JayMac is offline
Mein Auto: 01 M3, 83 320is, 75 2002
What did you find out on this?
