Old 03-30-2013, 05:52 PM
Jonjo Jonjo is offline
Mein Auto: 740i
Misfire
Hello my car has started to misfire and after putting new spark plugs in its got worse now it don't want to tick over and stalls could this be a problem with auto choke
Old 07-15-2013, 04:04 PM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
What model and year BMW do you have? You need to provide more info for people to help you.
Tim
Old 07-15-2013, 05:58 PM
Mein Auto: 740i
Hi tim it's 1995 740i thx john
Old 07-15-2013, 06:00 PM
tim330i's Avatar
I moved both your threads (this one and the one about the air con) over to the E38 7 series forum. You should get help from our other E38 owners but also search around in this forum for existing questions that might help you.
Good luck,
Tim
Old 07-15-2013, 09:01 PM
Mayorchuck Mayorchuck is offline
Mein Auto: '96 740iL
When you say 'it won't tick over', you mean it's not turning over? If it stalls when coming to a stop/low rpm's, this is often a sign of a failing MAF.
As you have a '95, you will not have a testing port (OBD II) in the car. Do you have a Check Engine Light on? Either way, try a Stomp Test to check for codes.
http://forums.bimmerforums.com/forum...%28M60-only%29
Try unplugging the MAF and then taking it for a drive to see if there is any improvement. If there is, MAF is bad.
Edit: Also make sure you battery is in good shape. These cars are VERY sensitive to low voltage.
Old 07-16-2013, 08:13 AM
Mein Auto: 740i
Sorry mate the stalling problem was on my sons 328i all sorted and yes it was the maf sensor once again thank you
HTML code is Off
