Old 03-30-2013, 06:00 PM
loso81 loso81 is offline
Mein Auto: 335i
LED installation, small headlight compartment
has anyone ever had a hard time installing after market LEDs?? the compartment space is super small I have tried twice installing mine but have not had luck and barely had luck putting factory ones back in, I ordered mine from burgertuning, after getting scrapes on my hands for the second time this week I'm getting fed up, lol
Old 03-30-2013, 06:29 PM
Sonic7 Sonic7 is offline
Mein Auto: 2007 328i
Which one you trying to change parking? Low beams? But the best you can go through the wheel well it's on my a few screws very easy to take off
Old 03-30-2013, 06:53 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
Coupe/Cabrio or Sedan?
The ingress to the headlight module is different for the coupe/cabrio than for the sedan. And yes, if it's a coupe it's a space designed for small elves that live in hollow trees. When I did the LED install on my E93 having small hands AND using tools was required.
Good luck!
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien| BMWCCA#445793
Old 03-30-2013, 08:14 PM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert/14JGC/ 13Outback
To amplify Kat I also marked my light so that when installing the bulb it positioned correctly. It matters and makes ALL the difference in the world since the tabs are different. I also used a plastic tool that is used to pop door panels off to keep pressure on the back side of the bulb structure (I am talking about LUX H8's version 3 by the way) because it needs pressure from the rear of the housing to push the bulb forward. Also I used a flat blade screw driver to help rotate the bulb to the correct position. On the LUX you have a built in heat sink which has air spaces which I used to rotate the bulb counter clock wise into the correct position.
It took me about 2 1/2 to 3 hours to get this done. My hands are way to big to fit into that space thus expect to use tools, mark the bulb (get your old H8 out and compare exactly where vertical is or whatever reference mark you wish to use) and patience patience patience. I have no patience just ask my SO but I did it and persistence pays off in this case. Worse case get someone with small hands and have then help you install the bulb. I hope since you are mentioning LED that you are using the LUX H8 because that is what this speaks too...
Old 03-31-2013, 07:00 AM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Wives and Girlfriends are good for this mod - small hands are needed - ask for help!
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
