Turning off Daytime Running Lamps?? - Bimmerfest - BMW Forums
Old 03-30-2013, 06:55 PM
Chop362's Avatar
Chop362 Chop362 is offline
Mein Auto: 2013 335Is
2013 335Is is this possible?? My 2010 335 never ran them so just a little confused as I really don't care for it..Help??
Old 03-30-2013, 06:58 PM
vstM3's Avatar
vstM3 vstM3 is offline
Mein Auto: F80 M3
You can disable them thru idrive, check the settings menu
Current: 2015 BMW F80 M3
Retired: 2012 BMW 335is
Other: 2014 Mini Cooper
Old 03-30-2013, 07:05 PM
Chop362's Avatar
All options just no IDrive (SUV has it so no need) Possible without?? Are yours activated??Thanks
Old 03-30-2013, 07:08 PM
vstM3's Avatar
Mein Auto: F80 M3
I keep mine on...like the bright white look don't know any other way to disable them but thru idrive. Maybe coding?
How do you like the car so far? Still stock?
Old 03-30-2013, 07:18 PM
Chop362's Avatar
Yeah still stock just had delivery yesterday afternoon so really kind of getting to know it unlike others I kind of wait on the driving but so far I'm really happy with the choice. Reflectors coming off within the next couple weeks but that's an obvious any suggestions??
Old 03-30-2013, 08:22 PM
vstM3's Avatar
Mein Auto: F80 M3
That's what I did too and had it for about 8 months. So far I enjoy it as is I am thinking at doing some things in the summer, upgrade FMIC, intake and Downpipes but at this point don't know what brand...still looking around. Maybe others who have tune their "is" can guide us? good luck!
Old 03-30-2013, 08:32 PM
Chop362's Avatar
Thanks & good luck to you too...Have to admit keeping stock on this thing isn't exactly painful!!Tell me did you go 18' or 19' on the 313's?? N.East here so my brain won out..18's
Old 03-30-2013, 08:35 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
Yes, my car does not have the iDrive, and I disabled the the daytime running lights. Use the switches on your turn signal lever. Use the up and down switch on the front of your signal lever to get into the settings area. And then use the button on the end of the lever to set it. It is late now, but I will go through the steps on my car, and then post them tomorrow, if you haven't been able to set the DRL's.
Alpinwei▀
E46, E83, E90 (all with three pedals)
F25 (missing third pedal)
BMW CCA member
Old 03-30-2013, 08:38 PM
vstM3's Avatar
Mein Auto: F80 M3
I did go with the 19", so far no issues. I did buy a winter setup with 18" though
Old 03-30-2013, 08:44 PM
Chop362's Avatar
Hey if you could that would be awesome..Thanks for the help here
Old 03-30-2013, 08:46 PM
Chop362's Avatar
Love the look of the 19's and would have gotten them had the wheel/tire insurance not been 1,600!! Back in 2010 it was $600. Have a good one P.S. Hows the ride smooth enough??
Old 03-30-2013, 09:31 PM
vstM3's Avatar
Mein Auto: F80 M3
No complaints on the ride, I wouldn't say it's very smooth because of the RFT...I suspect if you put regular tires the ride will be perfect I'm ok though, I like the ride and the RFT overall
Old 03-31-2013, 03:39 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
The setting follows the remote (so you can have one set up each way). To do it on a 2009:
The manual is your friend.
Old 03-31-2013, 08:44 AM
Chop362's Avatar
Thanks Zooks but my manual is not being my friend....I'm a pretty crafty dude but seems lock can not be removed for some reason on a 2013 plus there are 2 lamp locks with one being open but the one above refuses to play ball any answers??This is my 5th Bimmer and know these cars inside and out so maybe a dealer code,sucks. Thanks anyways
Old 03-31-2013, 02:06 PM
Hmmmm, maybe there was a change for 2013. My car is a 2011, and the procedure in the above post worked on my car. I just went out and re-checked it.
I have heard that the DRL's cannot be shut off on the Canadian models, but I thought we had the option on US models.
Alpinwei▀
BMW CCA member
Old 03-31-2013, 02:57 PM
Joe in Dublin Joe in Dublin is offline
Mein Auto: 335ic
yes,,,,look in your manual
Old 03-31-2013, 07:12 PM
Chop362's Avatar
A little bit different than my other Bimmers but finally got em off..Maybe it's me?? Thanks Alpin and file this one under case solved
Old 03-31-2013, 07:13 PM
Chop362's Avatar
Got it thanks
