E30 (1982 - 1993)
Old 03-30-2013, 08:52 PM
skinzochud skinzochud is offline
Mein Auto: 1984 BMW 318i
82 m20 into 84 318.
Is this swap just as explanitory as any m20 swap in an e30? My m10 is crap so i got a m20 6cly from a e21 i just wanna know if it will just be plug and play like most of the m20.
Old 03-30-2013, 09:17 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Originally Posted by skinzochud View Post
Is this swap just as explanitory as any m20 swap in an e30? My m10 is crap so i got a m20 6cly from a e21 i just wanna know if it will just be plug and play like most of the m20 swaps. and dont say they are not "plug and play" its just an expression because the swap is apparently so "easy."
How about you tone it down a bit before you start demanding info?
I Timothy 2:1-2
Old 03-30-2013, 10:47 PM
I am calm. i just know how some fellows are. I do not like when other people make others out to be dumb.
Old 03-31-2013, 06:27 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
If both are carb'd i dont see any major issues other than swaping entire drivetrains.
If both are fuel injected (which im guessing they are L-jetronic) then it should be easily done also.
The only thing that concerns me that I am not very familar with is if either is carb'd or fuel injected and trying to mix both together. Someone else might chime in here to help clear that up.
Old 03-31-2013, 07:46 PM
They are both fuel injected. I have a drivetrain, starter, alternater and a ecu for the inline 6. i was just worried because the motor is out of an 82 going into an 84. i didnt know if there would be some major issues i would run in to because im going old into new.
Old 03-31-2013, 09:03 PM
First time's Avatar
No I think you will be golden, the M20 was used for years relativly untouched throughout its production. Most notable changes are the switch between jetronic and motronic.
Old 04-03-2013, 06:29 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
You are swaping a 6 cyl into a 4 cyl space ?
On the EFi side, I know that you need a 6 cyl ECU.
I would not know if the gearbox need not be moved back either, if it mates up ??
As with any conversion, you need to talk to somebody who has done this succesfully...
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 04-03-2013, 10:52 AM
First time's Avatar
^ 6 cylinder motors were available in the 3 series (he said his motor is from a e21 (3 series) nothing needs to be moved back just a different set of mounting arms is all.
If people are installed LS/M60 motors i think the M20 is fine.
