Old 03-31-2013, 12:21 PM
terryn terryn is offline
Mein Auto: 2016 M235xi
Roof Rack Question
My 328i will arrive in May sometime I expect. I want to get a roof rack sorted out so I can put my canoe on it soon after the car arrives.
I currently have a Yakima rack on my 1999 Audi A4. I don't know if the Q towers from the Yakima will fit the 328 or not, but I did notice that BMW sells a rack that looks like it might fit into factory mount points. Does anyone have experience with this rack?
BMW Base Support System 82712295099
The price on the BMW site is a modest $259. It is odd that when you add it to your cart it gives an "installed" price of $315.55. What "installation" is there? Is this just the dealer putting it on your roof for you?
If the BMW rack fits into factory mount points on the roof that is a plus since the Yakima Q towers have to hook under the roof inside the doors, deforming the rubber weatherseals at the top.
Old 03-31-2013, 01:00 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
the f30 has hardpoints under flip open covers on the roof-- the base supports bolt directly to the roof. as it comes in the box, you apply protective plastic to the mount points (to keep the feet from grinding into the roof, use a bolt they include to chase the threads, then bolt the towers to the roof. then you adjust and tighten the load bars. a security torque wrench is included.
you can get the base roof rack from bmw dealers on ebay for about 200 shipped. the rack bars are very similar to thule aero bars (some say the rack is oem'ed by thule for bmw). i use a thule snowboard mount without any issues with the bmw base rack
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 03-31-2013, 01:13 PM
Does the BMW roof mount go on and off the car pretty easily? I would only put it on when I needed it and then remove it when done.
Old 03-31-2013, 03:43 PM
I think so, i can do it by myself in a few minutes. takes me longer to bring the bars to the garage from my apt. flip open the covers, position feet over the bays created, tighten four bolts till the torque line on the wrench lines up. removal is even easier, just loosen the bolts and take the bars off, flip closed the covers.
Old 01-22-2015, 11:45 AM
Dukeenzo Dukeenzo is offline
Mein Auto: 08 535XI Sportwagon
I have the same bars and satisfied with everything except there is a 5mm gap between the plastic faring and the roof, with the bar firmly attached?
Old 01-22-2015, 11:47 AM
I bought Thule rack but had to replace the 30mm long bolts with SST 40mm. Works great.
Old 01-22-2015, 11:49 AM
I put these BMW bars on a 2008 328xi.
Old 01-23-2015, 08:56 AM
taint fair taint fair is offline
Mein Auto: 2014 535xd
Yakima makes a base that will work with your F30. I have been using the same Yakima bars and attachments for years now. I just need to change the towers from car to car. Going with the OEM isn't an option for me until I want to replace my bike mounts since they are made for round bars. I also think the OEM bars are too high off the roof.
2014 535 M-Sport | Carbon Black | Ivory Nappa | Premium | Lighting | Cold Weather | Driver Ass | HK Sound | Multi-contour Seats | SAT |
2014 328 M-Sport | Mineral Grey | Black Dakota | Premium | Lighting | Cold Weather | Driver Ass | Driver Ass Plus | HK Sound | Dynamic Handling | Tech Pkg | Alarm |
