E30 (1982 - 1993)
Old 03-31-2013, 04:54 PM
Wolfy Wolfy is offline
Mein Auto: 1988 BMW 325i
Exclamation Struts And Shocks General Question
Hello all,
I was curious to know if there is a difference with shocks and struts by there brand name or is there no difference.
I drive a 1988 BMW 325i convertible and its shocks and struts are due and in order to pass inspection which is next month I'll have to replace the rear shocks and the front struts.
Now I was wondering if it makes sense to go by budget or if it pays to pay for more.
I want better handling as its my main driver and I can't deal with crap for handling.
I also noticed that Monroe had a deal where if you bought a pair you'd get a mail in rebate offer
here there link for the premium
http://www.amazon.com/Monroe-72871-S...1&s=automotive
I might get them, but I'd rather get the best bang for my buck as well. I'd rather pay for the best then settle for something less.
Any input, thoughts or recommendations would be awesome
Old 03-31-2013, 05:01 PM
downhiller's Avatar
livin large
i was always happy with monroe shocks/struts on my cars. theyre not the best performance, but for dd and an occasional quick track runs theyre fine. bilsteins are one of the best to run for performance and dd.
Old 04-04-2013, 11:32 AM
Scartissue27 Scartissue27 is offline
Driving is everything
Mein Auto: 540i//E30//E36
It depends on what kind of drive and look you want to go for. I can say I'm happy with the performance of my bilstein struts and eibach springs pro setup. However, I regretted not going with coilovers for the look and being able to lower the vehicle a little more(hint STANCE it LOL). You should paying a little extra and go with the best, coilovers.
I Love Haters!
Old 04-04-2013, 08:48 PM
Best would that be a raceland kit?
Old 04-09-2013, 05:24 AM
E30 F34R's Avatar
E30 F34R E30 F34R is offline
Metric Mechanic
Mein Auto: Polly(My '87 track ****)
Hell no, does this place really sit in the dark on suspension setups? I am guessing you do not want coilovers, so my honest setup for you is Bilstein Sports with vert specific H&R sport springs.
I am only mentioning Bilstein because you will not be low enough to use the travel of Koni SA inserts. But you could always space out the Koni SA inserts inside the housing and use them. The Konis are much shorter than stock height inserts IE: Bilstein etc.
If you want coilovers go with Ground Control. Then grab a set of the Koni SA(400 shipped for the front pair). You pay to play, but the are WORLDS better.
Here is a thread where I show the housing mod and such.
http://www.r3vlimited.com/board/showthread.php?t=263094
~ Puch Cafe. ~ Instagram, follow me. ~ Do business? feedback ~ Check out my company ~
Originally Posted by MP330 View Post
they looks the same as other coilovers on ebay.....megan,cxracing,bc....one factory,many labels..
Old 05-25-2013, 09:46 PM
gingersnap gingersnap is offline
Mein Auto: 1990 325i
Hey you guys,
I'm hoping that someone can tell me or help me find out what size strut inserts I need for my 1990 325i. I've seen them for strut housings 2" and 1 3/4". When I measured the circumfrence of the housing and converted it. I came out with a diameter for 2.5". Now either my math is wrong(which wouldn't shock me) or its something else. And I'm looking at Monroe right now.
Anyone help me out?
Old 05-26-2013, 07:04 PM
woodenbmw's Avatar
woodenbmw woodenbmw is offline
Mein Auto: 1987 BMW 325
Re: Struts And Shocks General Question
I had the same question before I replaced mine. I used a set of calipers and got the diameter from that. I have the 2" sport suspension. You could always take them apart and carry the inserts to the parts store to ensure a proper fit. Don't forget to fill the tube with oil after installing the new inserts. I also went with the Monroe Oespectrum inserts and shock absorbers. All together I think it cost about $100 for all four corners. I've had them on the car for a couple of months now with no problems. I would recommend getting new mounts, stops, and bellows while they're off and apart. Good Luck
1987 325e automatic sedan
