Old 04-01-2013, 07:15 AM
pastman pastman is offline
Mein Auto: 2007 328xi
Timing chain replacement?
Hello Members:
I've owned a 2007 328xi coupe for a little over 2 years now. I'm just past 90K now. Except for brake rotors, this car has been trouble free. What's the scoop on the timing chain? Has anyone had any problems or needed to replace one? Any comments would be sincerely appreciated.
Later,
Alan
Old 04-01-2013, 07:24 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
I might be wrong, and I think BMW is too quick to claim 'lifetime' for many components, but with regular oil changes a timing chain really should be a 'fit for life' item.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 04-01-2013, 07:46 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Timing chains do stretch slightly over time but there is a tensioner to take up the slack. The tensioner will eventually reach its limit but it takes a loooong time. Absent a lot of high-RPM operation, I wouldn't give the chain much thought until at least 200,000 miles. If you tend to baby the engine, 250,000 or more. As noted, that assumes regular oil changes and proper warm-ups.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47° 35' 30.13" E11° 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 04-01-2013, 07:47 AM
tturedraider's Avatar
Freedom isn't free!!
^this -- timing chains do not require replacement.
www.bmwcca.org
Old 04-01-2013, 09:17 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
You seldon see a broken timing chain thread here.
In fact I have only see one which was the result of a redline shift.
(time frame a couple of years)
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
A yawning sinkhole in the performance market, I see no aftermarket BMW timing chains!
I, for one, am very concerned. Understand, I'm not one o'those love-'em-&-leave-'em lease guys....no. I'm an owner who had modified, and I have a "long term" view.
I lean toward having Rollmaster make a custom chain. Pre-stretched, it is an Aussie product. I figure: If it survives there, California's no problem at all. And let's not stop at chain - ya'll gonna need nitrided gears. Yo! Gears wear too!
I believe I've given you a good direction. What's your next move?
Old 04-01-2013, 09:34 AM
Zeichen311's Avatar
Well-l-l, I hate to say "never" but the point being, one often needs/wants to crack open & rebuild an engine for other reasons (ring/valve wear, main seals, etc.) by a quarter-million miles or so--at which time, check the chain while you're in there. Otherwise, yeah, effectively lifetime.
Old 04-01-2013, 09:43 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Properly lubed, the t-chain and tensioners/guides will last as long as the crank bearings. When the engine is eventually torn down for a rebuild, a chain kit (and crank and cam gears) is part of the job.
Until then, be happy we don't have timing belts!
Old 04-01-2013, 10:08 AM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
I also do not believe in "lifetime" for much of anything, especially fluids. But the BMW timing chain and gears seem to be really robust, and have very few problems.
Unfortunately, this does not apply to all other brands of cars. Some makes (which shall not be named here), have had notable failures with timing chains and tensioners. BMW seems to have done well in this area.
Alpinweiß
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 04-01-2013, 12:30 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Wide chain links and lots of direct oil spray.
Old 04-01-2013, 02:48 PM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Can I ask why the question? Has someone told you that a new chain is required? Timing belts generally get replaced at 110K miles but as was mentioned above the chain is a rebuild item.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 04-01-2013, 04:05 PM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
I can't imagine the sheer annoyance the gear whine would cause.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 04-01-2013, 06:15 PM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
Originally Posted by bear-avhistory View Post
Timing belts generally get replaced at 110K miles....
I've always heard (and followed) the 90k rules... but i guess it's whatever the manufacturer calls for...
Old 04-01-2013, 06:20 PM
This is one of the reasons I wanted a BMW over and Audi
This is one of the reasons I wanted a BMW over and Audi.
There are others of course.
About every other car you buy will need a new belt and the cost of changing
some of them can be quite high plus I have had two broken belts leave me stranded
with a valve job afterwards. (one a honda prelude(later a factory recall) the other and Acura Integra and the belt was only a year old on that one)
The research I did on the Audi A4 suggested the timing belt change would
be 2k plus because of the fact that just about the whole front end needed
to come off to change it.
Old 04-01-2013, 07:11 PM
galahad05's Avatar
Better with Butter
Why would Audi use timing belts?!? No manufacturer worth its salt would use timing belts over chains.
-- Irish Proverb
Old 04-01-2013, 07:19 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
*Looks over at post date of April 1st*.
Edit : HOLY CRAP!! Clicked on link - my bad.
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 04-01-2013, 07:50 PM
Acura TL was a 105K mile replacement item. It does vary by mfg.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 04-01-2013, 09:01 PM
So what percentage or auto makers uses timing chains.
Even BMW use to use belts in some of its cars.
Old 04-01-2013, 09:27 PM
galahad05's Avatar
Better with Butter
Without doubt belts are cheaper.
They also"wiggle" more at higher rpm, causing fluctuations in valve timing at these higher rpms.
Of course, pro engine builders say the same thing about chains.
-- Irish Proverb
Old 04-01-2013, 09:39 PM
Audi now mostly uses timing chains in their engines. The 2.0T engine for Volkswagen/Audi changed from timing belt to timing chain during the 2008 model year. This engine is now the mainstay in the Audi lineup in the US.
Why would a manufacturer use a timing belt instead of a timing chain? A timing belt reduces the complexity of an engine, as well as the weight. A timing belt typically makes less noise than a chain. Replacing the timing belt and tensioner will renew the entire drive system for the camshafts (wear on the timing gears is usually minimal).
A timing belt makes more sense in countries where engines accumulate a large number of miles (kilometers), and labor rates for auto repair and maintenance are low. Most customers in the US prefer engines with a timing chain.
Alpinweiß
F25
BMW CCA member
Old 04-01-2013, 09:56 PM
My guess is most people don't even consider this.
Old 04-01-2013, 10:19 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Had to replace the tensioner in my Altime SER at 110K but that was due to the guide rails (plastic) breaking and allowing the chain and tensioner to loosen all the way (known issue with QRD35 engines). Chain was fine. Just put in new tensioner, guide rails, and seals (also waterpump since it didn't have the external one). Runs like a champ but was a FRICKEN BEAR to tear into!!! Had a Mercedes up to 250K before I sold it. No Timing Chain issues. Waterpump was external. Easy to fix everything DIY. Road like a limo but had to peddle very fast!
Old 04-02-2013, 11:04 PM
marine24 marine24 is offline
Mein Auto: 2007 BMW 335i
My last car was a 96 VW Passat VR6, and they stated the timing chain was a 'lifetime' part, (meaning 100k miles). I replaced it at 156k and found that the chain was fine but the tension guide was completely worn out; had two grooves cut into it from the chain. Most of the 'lifetime' parts refer to what a manufacturer considers the expected life of the vehicle (apparently about 100k and they think it'll fall apart). I'm at 98k on my 2007 e92 335i and was considering the same thing; when do they expect it to need to be changed?
Leave it stock?!?!? Where's the fun in that?
Old 04-03-2013, 05:07 AM
fun2drive's Avatar
BMWCCA 149159
E30's had timing belts which should be changed every 50-60K miles or 5 years. They are quieter than a chain but a pain to change that often. My experience is that someplace north of 300K miles is a likely change mileage. M3 went 284K miles when I sold it and the timing chain showed no remarkable wear.
It the timing slips which is what happens to a timing change it will change the timing and on a zero clearance engine like we have will most likely make piston to valve contact.
Your timing chain is hardly broken in...
Old 04-03-2013, 06:12 AM
Banned
Mein Auto: 2007-335 HTC
what about the cam sprockets? I remember seeing in american V-8's back in the 80's they had a timing chain, but the sprockets had teeth coated in nylon, the chain didnt brake but the sprockets wore out
328xi timing chain
