Old 06-27-2013, 04:31 PM
AdamG13 AdamG13 is offline
Mein Auto: 2016 740Li
We'll probably see it released sooner than later. I think the 550i and the new X5 will be getting the same engine, so that'll increase the potential customer base. Personally I'm leaning towards the '14 650i and slapping it on that engine. Biggest tradeoff for me when moving to that from the 7 is that the sunroof only tilts and doesn't slide open :/
2016 740i Singapore Grey
2014 M6 Citrin Black
2013 750i Mineral White
2011 750i Jet Black
2007 750i Monaco Blue
Old 06-27-2013, 05:59 PM
PREDATOR 007's Avatar
PREDATOR 007 PREDATOR 007 is online now
Mein Auto: 2016 ///M5
As many of you know, I did the qtr mile runs stock and with Dinan. I just ordered a new car today (13') and will take it to the track to get some numbers. This time around, I may try the Burger tuners. Then hit the track to see how they perform compared to the Dinan. Burger $379 plug and play vs. Dinan dealer loaded software for $3,500. This should be interesting.
http://www.burgertuning.com/products.html
** Removed ** 19,000th, 22,000th, 22,222th, 26,000th, 35,000th, 45,000th 48,000th, 63,000th, Honorary 87,000th and 93,000 post in delete pls
WR 12.50 @ 112.05 MPH 9/18/14
Old 06-27-2013, 06:53 PM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: F02 (750Li)
Originally Posted by Richard109 View Post
As many of you know, I did the qtr mile runs stock and with Dinan. I just ordered a new car today (13') and will take it to the track to get some numbers. This time around, I may try the Burger tuners. Then hit the track to see how they perform compared to the Dinan. Burger $479 plug and play vs. Dinan dealer loaded software for $3,500. This should be interesting.
With the JB you can actually pull it off and reinstall in between runs to compare, as its that easy to remove .
Old 06-27-2013, 07:25 PM
ChrisF01's Avatar
ChrisF01 ChrisF01 is offline
Gib mir Feurschutz!
Mein Auto: 2016 750i xDrive
2012 750i Dinan Stage 4 vs 2013 750i
No power trunk either, stupid considering many many 6GCs are optioned about the same as our 7ers.
2016 750i xDrive M-Sport (Current)
2015 650i Coupe
2013 750i M-Sport
2012 740Li
Old 06-27-2013, 08:26 PM
Emilner Emilner is offline
Mein Auto: 2013 SL63
Do they make a tune for the new engine yet? I didn't see one on the site...
Edit- I see they mention it under description, they are just calling it the N63, not a tu...
$379??? Wow
2015 S550 Anthracite blue, Silk, loaded and doin just fine...
2013 SL63 AMG black....
2014 GL350 The kids chariot.
2012 750IL x drive, imperial blue/oyster, a finely loaded beater car... (gone)
2012 650 Cabriolet M sport (gone)
Old 06-27-2013, 09:19 PM
After seeing how fired up they get about the lack of a power trunk on the 6 series forum I try not to even bring it up Literally 25% of their threads seem to lead to power trunk discussions! I do see their point though - nobody wants to hear the sound of their license plate rattling as they slam the trunk on their 650 while some 328 parked nearby emits the smooth motorized sound of its trunk auto-closing.
$379??? Wow
It's the same module whether you have valvetronic or not. I talked to one of their reps earlier because I wanted to confirm if I could use it on my 7 and then transfer it to my intended 6 when the lease is up. Said that's fine, just may need a harness adapter.
2011 750i Jet Black
Old 06-27-2013, 11:38 PM
M4XBMW7's Avatar
TTurboFest
That's correct , your 11 uses type A harness. I tried using my type A JB stage 1 from my 750 on a 2013 550i and it wouldnt work as it has type B harness .
Old 06-28-2013, 01:18 PM
Were you able to get some type of adapter or did you just order a new unit?
2011 750i Jet Black
Old 06-28-2013, 08:38 PM
M4XBMW7's Avatar
TTurboFest
No never order since the 550 was a loaner
Old 06-29-2013, 03:46 AM
ajdoha234 ajdoha234 is offline
Mein Auto: 2013 740Li
Originally Posted by PapaFlEx View Post
Looked all over the burger tuning site. It doesn't have anything listed for the 2013 740LI, but it does for the engine. Shouldn't it list it by what model you can use these tunes on?
Old 06-29-2013, 09:19 AM
PapaFlEx PapaFlEx is offline
Back again
Mein Auto: 2012 750i M tuned
It should be listed not sure why its not. Reach out to terry via email. Hopefully he has something for you. Since the enine is the same for a 535 I would assume it would work on yours. Double check of coarse
2012 750i Msport JB Tuned, 22 inch rims, Chrome Delete, H8 Bulbs among others- current
2009 135 JB Tuned - retired
2008 535i JB Tuned FBO - retired
2006 650 vert dinan tune - retired
Old 06-29-2013, 09:41 AM
Just sent an email. Im curious how the whole burger tuning works. Do you literally just plug it in? Why the huge price difference between burger and the dinan?? How does it interact with the 8 speed transmission? Is the burger tune dangerous for the engine turbos?
Old 06-29-2013, 09:46 AM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
Have you tried to reset your adaptive transmission ?
And lol, your tires, it's because of that monstrous Torque!
Old 06-29-2013, 09:57 AM
M4XBMW7's Avatar
TTurboFest
It's as easy to install as taking candy from a baby's mouth , and to answer all your others questions and my honest opinion and so far experience with the JB stage 1, this tune is simply safe and yet conservative with the added 2psi which is quite noticeable, fuel is unchanged with the additional 2psi of boost bump which compensates the 1.1/2 degrees of timing removed .
Old 06-29-2013, 04:11 PM
lol. i like it
2011 750i Jet Black
Old 06-29-2013, 05:00 PM
wjhughes420384's Avatar
wjhughes420384 wjhughes420384 is offline
2009 F02
Mein Auto: 750li, XJ8
how long has anyone had this tune? any significant miles without problem?
2009 750Li - Space Grau Metallic, Camera pkg, Conv pkg, Driver Asst pkg, Lux Seat pkg, Lux rear seat pkg, Prem sound pkg, Sport pkg, HUD, Massaging rear seats, Smartphone integration, Sat radio, MTEC H8 4750K Halo lights
Old 06-30-2013, 12:06 AM
Snorlax Snorlax is offline
Mein Auto: _
I don't think you can use the burger tuner with the N63tu engine if I'm not mistaken due to it being some different valvetronic system. You should check with Burger before plunking down money.
Old 06-30-2013, 01:10 AM
M4XBMW7's Avatar
TTurboFest
I believe it works with no issues
Old 06-30-2013, 01:32 AM
Mein Auto: _
And so a battle commences!
Old 06-30-2013, 01:58 AM
M4XBMW7's Avatar
TTurboFest
Lol just emailed Terry to make sure
Old 06-30-2013, 02:08 PM
I just confirmed with Terry that all 2013's are N63 w/ type B harness. I downloaded the install guide from his site and it seems pretty easy and straight forward. Looks like I will be getting one.
Also, check this out... http://www.n54tech.com/forums/showthread.php?t=18035
Old 06-30-2013, 02:38 PM
M4XBMW7's Avatar
TTurboFest
That's the video I was telling you about Richard .
I'd be curious if anyone in the Atalnta area with a Dinan 7 series wants to line up vs my BMS tuned 750 eh ? Just curious to see the outcome .
Old 07-01-2013, 05:30 AM
I emailed them about the availability for a 2103 740li and this s the answer I got back:
Hi Anthony,
The N55 Stage 1 and Stage 2 units are compatible with the 740i. You can read more about each unit here:
http://burgertuning.com/N55_Jb_BMW_P...nce_Tuner.html
http://www.burgertuning.com/N55_Stage2_Jb4.html
For the stage 2 unit, you will need to make sure your vehicle has the CAN access wires in order to ensure compatibility. The 740i uses the same hardware as the F10/F30 installation so you can select that type when checking out. You can read more information about the CAN wires and general information about the F10/F30 installation here:
http://www.n54tech.com/forums/showthread.php?t=18588
http://www.n54tech.com/forums/showpo...16&postcount=3
Best,
Jon
BMS
end of email...
a yes or no would have sufficed, lol. But seriously, all I needed to know was whether they have a tune for the 2013 740LI and he doesnt specifically say yes or no to the 2013. The reason I would like an exact answer is because on their website they specifically say you cant use this or that for this model. They need to update their website as well and add a Model link..."If you have this /make/year/model then this is what you can buy" type setup KISS.
Old 07-01-2013, 07:41 AM
M4XBMW7's Avatar
TTurboFest
He clearly states that it works and shares with the F10 & F30 lol
Old 08-14-2013, 10:43 AM
mr-karim's Avatar
mr-karim mr-karim is offline
bimmerfest coolest Member
Mein Auto: Audi R8 v10 Spyder
http://www.bimmerfest.com/forums/sho....php?p=7772354
