Old 04-01-2013, 09:30 PM
craiginok craiginok is offline
Mein Auto: 2008 X3
Sunroof wind noise
I have only driven one other X3 (and it was only a test drive) so I don't know how much wind noise to expect from my sunroof. To me it is quite a bit, a lot more than around the doors or other windows. I can't find any water entering the car but it certainly seems like a lot of wind noise.
Any advice would be greatly appreciated.
Craig
2008 X3
1999 328is
Old 04-02-2013, 02:11 AM
Silwer Silwer is offline
Mein Auto: BMW E83 X3 3.0sd, 210kw
My car sunroof makes the noise only at the highway speeds, howver, you can reduce the noise by closing the sunroof lining.
Old 04-02-2013, 11:12 AM
fhopper's Avatar
fhopper fhopper is offline
Mein Auto: '04 X3 3.0i
I think mine is way too loud; 2004.
Old 04-02-2013, 11:52 AM
camaroguy camaroguy is offline
Mein Auto: '07 550i Sport, '07 X3
Make sure the panels are adjusted correctly. All other BMW's I have owned recommended that the front of the glass be 1mm below the roofline and the rear be 1mm above. This is supposed to help with wind noise due to changing the airflow over the roof a touch. My 2007 looks to be adjusted the same way and there isn't much more wind noise than any other car I have ever owned with a sunroof. You can also check if the seal is going bad and letting air get by more than it should.
Old 04-02-2013, 03:00 PM
fhopper's Avatar
Mine is too loud when open. Anything over 20 miles per is intolerable.
Old 04-02-2013, 04:54 PM
rmerkushen rmerkushen is offline
Mein Auto: E90 330i, E83 X3si
Mine is loud also.. It is hardly audible when sunroof liner is closed..
Old 04-02-2013, 06:08 PM
maxeaus maxeaus is offline
Mein Auto: x3
Yes, its actually not recommended you travel over 0km/h with your sunroof open if you value your sanity as the sound will send you nuts.
Not one of BMW's best features the ..............."stationary sunroof "
2006 X3 3.0D
Old 04-03-2013, 10:10 AM
ghpup's Avatar
ghpup ghpup is offline
Glfbggy
Mein Auto: 07 X3si, 14 535xd, 00 MZ3
+1 here. If I'm over 50mph the noise is noticeable, but not unbearable without the liner closed too. It is representative of other vehicles I've owned with a sunroof.
I get a lot more noise when I have the sunroof open on my //M
GLFBGGY
'00 MRoadster, '00 528 now in other hands, '07X3si, '14 535d XDrive
Old 04-20-2013, 03:05 PM
JustJoan JustJoan is offline
Mein Auto: 328i
Does a deflector help at all? I have a 328i and have the same problem.
Old 04-23-2013, 04:52 AM
There is also BMW solution for the wind noise: http://www.m5board.com/vbulletin/att...b-54-04-09.pdf
*Just replace the moonroof seal with new upgraded one. It is quite a simple one hour DIY operation.
Old 04-23-2013, 09:32 AM
can0n4 can0n4 is offline
Mein Auto: '04 BMW X3, '04 330xi
crack the back windows a bit. Solves the problem for me. Nevermind, realized you were talking about it being closed.
Old 05-03-2013, 01:25 PM
DBU's Avatar
DBU DBU is offline
Mein Auto: Glacier Silver X4 M40i
Craig
2008 X3
1999 328is
Wind noise and water tightness are too different and unrelated things.
For the wind noise, I have had good luck with applying a strip of black athletic tape on top of the seal on the window. Or, you can of course replace the seal with the "new and improved" version from the dealer. That also works.
His: 2017 X4 M40i with all the options (except cold weather stuff - not needed in SoCal
Hers: 2007 X3 3.0Si
sunroof noise
