Resetting service due date - Bimmerfest - BMW Forums
Old 04-02-2013, 03:29 AM
EmmaLove EmmaLove is offline
Mein Auto: 07 BMW 328i
Hi again, all! =)
Many many thank you to all for helpful advises! Sorry, couldn't thank each of you for replies =) Wow, I learned a lot from oil changes from all those replies! thank you =)
I just got my oil changed yesterday by local shop like you all recommended even though I only drove like 3000miles since the last oil change, 18 months ago. Haha! But, I think it will be a great idea to watch for a promotion offered by a dealer around me.
My another question is, I got the oil changed but the reminder service date is not updated. The guy at the shop said, it's not a good idea to manually change the date outside the dealer, it might mess up the other due dates. Is it true?
If not, how could I reset the date?
Thank you in advance! =)
Old 04-02-2013, 03:43 AM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
Originally Posted by EmmaLove View Post
Hi again, all! =)
What year is your car?
On LCI models to reset the next service mileage and date:
1. Insert your key fob.
2. Press the Start button but don't turn the ignition on (foot off the brake for auto or clutch for 6MT)
3. Once the xmas light show and dongs are done, press on the brake and hold the trip odometer reset for a few seconds until you will see the service menu on the dash
4. Use your stalk to navigate the service menu, use BC button to select an item you want to reset - press and hold BC button once you see the RESET option for a service item you selected.
BMW CCA Member 454031
Save the manuals
Old 04-02-2013, 11:02 AM
2007 328i but would it mess up other due dates if i reset it myself?
Old 04-02-2013, 11:28 AM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
No. Whoever told you that is a moron and is spewing typical "Only do maintenance here or your car will explode when you turn it on" crap.
If it's an iDrive based car, just push the knob in when on the main menu, then go to Service Interval, and reset it.
Hell, you even get to PICK THE DATE for this particular reset. I like to reset mine to my birthday every year, as that's when I go over the car with a fine-tooth comb and make sure everything's ready for the inspection.
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 04-02-2013, 11:48 AM
lqaddict's Avatar
Salz und Pfeffer
The service menu has submenues for different items that fall under the service - oil, brakes, etc.
It's just a matter of navigating to the proper submenu to reset that particular item.
Save the manuals
Old 04-02-2013, 12:37 PM
Wihelm G Wihelm G is offline
California ber Alles
Mein Auto: 328CiC and 328iT
Mostly not true. Ok, it's possible you could mess up the other service reminders. It's possible you could put too much air in your tires or put gasoline in your crankcase, too, I suppose. If you're reasonably attentive, you shouldn't have a problem. If you're worried about it, write down the existing service reminders before you attempt the reset. The oil service reminder reset should have been included in the oil service.
Old 04-04-2013, 06:00 PM
Thank you again for the video! Was so easy! =)
Old 04-04-2013, 06:03 PM
Thanks you for the info! Well, clear that the knowledge is a power, I totally believed him and thanked him. =) Haha I know better.
Old 04-04-2013, 06:04 PM
Thank you for the instruction! =)
Old 04-04-2013, 06:39 PM
Skyward Skyward is offline
Mein Auto: 2007 3 series
That was great. I had only driven 10,000 on my brake fluid Had the oil changed at the dealer. Said no thanks to the brake fluid job. He said fine but he wouldn't reset the service light. What a jerk. BMW This might be my one and only BMW Porsche next. I will try and reset the date. My RED service light comes on when I drive the car.
Old 04-05-2013, 05:48 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Well, doing the brake fluid every 2 years is a good idea regardless of mileage. The fluid is hygroscopic, and the change is time based unless you have been really hard on the fluid (by tracking it, as an example).
Old 07-04-2014, 05:09 PM
valerio valerio is offline
Mein Auto: 2011 BMW 328 I Coupe
Vehicle Check Reset Date
I have a 2011 328IX and I changed my oil and that was fine but when I went to change the
vehicle check reset in jumped to 07,2016. Would this be normal that this service is req'd
only two years.
I have 32,000Km and it went up to 48,000km.
Based on this can the system increase setting beyond a year and if so how to you backdate?
Old 07-19-2014, 08:22 PM
Guyto Guyto is offline
Mein Auto: 328 xdrive BMW
I am in the same situation with my 2011 328 Xdrive. Just had it services and now it says the next one will be in 2016. The dealer told me is not a problem... Anyway, I am planning to have a service every 6 months (10 000Kms).
Old 07-19-2014, 08:53 PM
What oil are you using that you require to change it that soon?
Old 07-20-2014, 09:54 AM
I am using BMW' ol, the service is zone by a dealer. The Association of car's owners where I live recommends to change the oil/filter every 6 months even if BMW says 1 year. Just playing safe ...
Old 06-13-2015, 11:29 PM
bugdoctor bugdoctor is offline
Mein Auto: 328i (F30)
Hi, any leads on how to reset service reminder on F30? I got my oil change done from a local workshop and he couldn't fix it. How can I do it manually?
Old 06-15-2015, 01:24 PM
It is pretty simple on the 328 model (2011). I don't know if it is the same on others.
Maybe this video can help.
Old 06-15-2015, 11:30 PM
Can you please share the link again
Old 06-16-2015, 06:25 AM
Here it is.
Hope that will help.
