Old 03-08-2014, 08:08 AM
Jaybeems Jaybeems is offline
Mein Auto: 335i e90
Exclamation Box fan code?
Whats up people?
I own a 2008 335i m sport and recently had taken it to the dealer for the "service engine soon" light. They read the code and it appeared as an issue with a box fan?
Does anyone know whats this means because the my cars cooling fan works great and the car itself runs great_the service advisor stated they would have to diagnose for a few hours $$$ and it may be a short of some kind.
Please help
Old 03-08-2014, 09:57 AM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
Originally Posted by Jaybeems View Post
Whats up people?
Please help
The first step is to take it to an indy vs the dealership for any out of warranty work. Do you know what the actual code is?
Old 03-08-2014, 01:47 PM
mr_bean mr_bean is offline
Mein Auto: 2000 328i
There is a small fan inside the plastic box that houses the DME and keeps it cool. I'm assuming this is what they found faulty.
Old 03-08-2014, 01:49 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Seriously!?
I have never seen a fan inside the dme housing
And surely, if that is the case. It would not take a couple hours to diagnosis it.
Only thing I can think off that is like a fan/will trip the SES light is the DMTL pump in the evaporative canister.
It's an emissions testing pump and pressurizes the Evap system a couple psi to test for leaks.
This could take a couple hours if there is a leak and they are trying to smoke the system to find it.
Ask your dealer what the fault code was and report back.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 03-09-2014, 06:29 AM
Originally Posted by fdriller9 View Post
Seriously!?
Item #5 in the diagram. And yes, a proper diagnosis will take some time. The tech should be testing the wiring for shorts and open circuits before throwing parts at the car.
http://www.realoem.com/bmw/showparts...12&fg=35&hl=29
Old 03-09-2014, 08:35 AM
So it's behind the housing. No wonder I've never seen it.
