Old 07-31-2014, 08:05 PM
blue dragon blue dragon is offline
Mein Auto: X5 35D
Thats a nice boat! What is it?
| '09 X5 35D - Work horse | '17 X1 MSport - Wife's daily | '17 - 340i MSport - My daily |
Old 07-31-2014, 11:07 PM
bossboy302 bossboy302 is offline
Mein Auto: 2013 Ford F150
Thanks. It's a vary rare 1964 Dunphy X-55. I tow the X-55 with an X5.
I measured twice, cut three times, and it's still too short!
2012 X5 35d
2013 Ford F150
1967 911S
Old 08-08-2014, 06:21 PM
sburke91 sburke91 is offline
Mein Auto: '11 X5 50i, '04 HD VRSCA
500 mile tow
I just finished towing my new (to us) 16.5' jet boat 500 miles from western Philadelphia to central Ohio. The X5 towed wonderfully. You could feel that the boat was there, but it was stable, and at no point did I feel like the boat was controlling the tow vehicle. I had plenty of passing power, and was able to sustain 75+ through the hills in western PA and WV.
Mileage, however was not such a rosy story. I averaged a bit over 21 on the way out (unladen), and a whopping 14 on the way back.
One interesting thing--prior to this trip, my front brake servcie indicator said front brakes wouldn't be needed for another 23k miles (the X5 turned 35K on the trip). Now the iDrive says 1300. On the upside, that would fall in the BMW-paid maintenance window, but I'm concerned as to why the sudden and drastic change. Looking through the wheel, the pads don't look worn to the level where they'd need replacement in 1800 miles.
Sean Burke
2011 X5 50i
2004 HD VRSCA
Old 08-10-2014, 09:57 PM
suss1173 suss1173 is offline
Mein Auto: E46 M3, JCW Mini S, X 3
Originally Posted by invisihitch View Post
I notice that many of you tow heavy with your X5. I have been asked before, and I was asked again today, about how much the rear of the X5 squats in response to tongue weights approaching the max of 600 lbs. I assume the answer is different for those who have the air suspension package from those who do not. I would be interested in hearing from both. What does your X5 look like when you attach a 500-to-600 lb tongue weight?
Daryl
daryl@invisihitch.com
640 and the total load was more than 10% of that number. The air suspension keep me level. The 35d had no problem pulling, however it was too much weight hooked to the back of the truck,
For the record, If I knew this load was as heavy as it was, I never would have hooked up. I was given a dry weight for the boat (from the manufacture) and the weight of the trailer from the trailer manufacture. I estimated another 500-750 for the limited gear (small danforth, 3 fenders, bimini top, cockpit cover, and splash of fuel (less than an 1/8 of a tank.
Needless to say, Sea Ray probably fudged the numbers on the boat's weight. Fortunately I was able to make the short distance w/o any issues. However, I did get it weighted, b/c it did not feel like the 6700-7200 that was estimated.
ID:	457820   Click image for larger version
2001 540ia sport, 05 JCW Mini, 06 X 3
Old 08-11-2014, 12:05 AM
serge1's Avatar
serge1 serge1 is offline
Mein Auto: 2011 BMW X5 35D
Wait, so the total weight towed was more than 7000 lbs? What was the weight?
Old 08-11-2014, 05:21 AM
Mein Auto: X5 35D
Its the stopping that counts, the 35D will definitely pull more than the rated 6000 lbs. Can you stop it though, have you done an emergency stop too see just how long the increased braking distance is?
Old 08-11-2014, 05:40 AM
PAX5 PAX5 is offline
Freude am Fahren
Mein Auto: X5 50i
What is the weight of the boat and the weight of the trailer?
I have a 25ft Cobalt (model 252 with a 454CI/7.4l V-P), dry weight 4530lbs and a dual axle Venture Aluminum trailer, weight 1,050 for a total of about 5,600lbs dry. With fuel probably about 6,000lbs. Tongue weight: 310lbs, or 5%
Your Sea Ray looks to be a closed bow series, about 26ft or so and a dual axle (galvanized?) trailer ... I suppose it could approach 7,000lbs ... But you shouldn't have tongue weight around 700lbs. Something is wrong. Boat is probably too far forward ...
Name:	Cobalt 252 tongue weight June 2014 - 310 lbs.JPG
ID:	457841   Click image for larger version
Name:	Sept 2013(5).jpg
PAX5
BMWCCA #20645
Old 08-13-2014, 10:19 AM
Blue Dragon-
I didn't do an emergency test stop. I was on a two lane road for most of the trip and the interstate for last few miles. The speed limit on the two lane road ranged from 35-50 mph and I did not go above the limit. I stayed in the right lane on the interstate and had no issues getting on or off the hwy.
I was keeping several hundred feet between any traffic in front and had plenty of room to stop for any yellow lights. When I needed to use the breaks they felt OK, but not confidence inspiring.
From a pulling standpoint, there were no issues. However when I went over bumps or uneven pavement, it felt like the trailer was pulling/ pushing the X5. Which makes me wonder if it could damage the unibody?
PAX5-
Sea Ray states the Pachanga 27 is 5,200 dry and Load Right states the trailer should be around 1,200 (give or take 100 pounds). It's a galvanized roller trailer.
The tongue weight is in the range of 7% of the total load, so I assume the weight is properly proportioned.
My assumption was 5,200 boat + 750 for contents (almost no gas) + 1,200 trailer and figured I would be around 7,000-7,300. Had I know I was going to be over the 7,700 (European rating). I never would have hooked up.
Prior to learning the actual weight of the boat I planed to use the X5 to launch it at the local ramp which is 1.7 miles away from where it's stored. Now I'm trying to figure out how to get it to the boat ramp- other wise, I may have to keep it in a slip. .
Old 08-13-2014, 10:45 AM
serge1's Avatar
Have you seen considerable improvement in stopping (while towing) since upgrading front brake rotors/pads to X5M?
P.S. Why upgraded just the fronts?
Old 08-13-2014, 10:52 AM
serge1's Avatar
I've been wondering about this for a while:
The X5 has some of largest disk rotors out of SUVs. A Suburban or a Tahoe has quite small rotors compared to X5, too small for vehicle of that size.
How is that Tahoe (a similar wheel base length) is allowed to (and considered to be able to ) tow more than X5? I can't imagine those puny brakes being able to hold the heavy Tahoe and the towed load.
Suburban may be a different topic, as it has longer wheel base - usually better for towing.
Old 08-14-2014, 10:39 AM
Mein Auto: X5 35D
Yes, the most noticeable difference was towing, around town with no tow, there is not much difference except for pedal feel.
The X5 M rear rotors have a different hub size, they cannot be directly bolted on.
Old 08-14-2014, 12:09 PM
serge1's Avatar
Isn't it not a good idea to have mismatched front/rear brakes? Bigger front brakes will grab more percentage wise. I thought manufacturers calibrate brake size to match vehicle weight on each axle..
Unless cars these days adjust automatically to load..
Old 08-15-2014, 07:03 AM
Mein Auto: X5 35D
As far as I could tell, the rear caliper on the X5M is still a single piston caliper with very similar diameter to the non X5. The X5 has the ability to move the braking force around, it can brake one wheel if necessary.
Old 08-16-2014, 07:52 PM
kakalika's Avatar
kakalika kakalika is offline
Mein Auto: 14 X5 35i, 02 530i
Just a few pics from my recent move to Houston from Minneapolis. Trailer weighed 7420 pounds as verified by a truck stop scale. That is just the weight of the trailer, not the vehicle plus trailer. I drove over the scale until only the trailer wheels were on the scale. Just under the Invisihitch total capacity. The trip was nice and uneventful. Could feel that you were towing a heavy load, but the X handled it well. There was never any feeling that the engine was straining or struggling. Averaged 15 mpg, and even got 20 on level roads at an average of 65mph. Definitely helps to shift manually and leave it in 6th once you reach cruising speed.
I have the rear air suspension, so the X was level all the time. No difference from if it was unladen.
Love my X. This one is a keeper for sure.
Run flat tires? Nein Danke!
Old 01-05-2015, 02:03 PM
MudyOvl MudyOvl is offline
Mein Auto: X5 xDrive35D
Originally Posted by Rickm5X3 View Post
It is a 2009 Heartland Edge M22 (introduced in 2008). It was Heartland's attempt at a Euro styled ultra light travel trailer and I think it would have been a success except for bad timing. It launched ahead of the Lehman failure and economic crisis. High price tag coupled with a terrible RV market (no consumer credit except for the qualified) killed it after 3 years of production.
But this market might have come around again. Google "Jayco Jay Smart" or Euro style campers and you will see the next generation of lightweight travel trailers. In particular, the Jayco is going to be 4,000 pounds dry for a 26 foot unit. For me, the combination of low tow weight, dual axle stability, and smart packaging is worth the cost premium and makes towing safer and more enjoyable.
Rick,
I have finally found an Edge, but it is an M18. It is smaller than the M22, but not a "house on wheels" which SWMBO has refused to approve the purchase of. What size rise do you use on your ball mount? (Alright, I know it sounds funny, but it's the correct terminology) I have noticed the X5 OEM hitch sits lower than most tow vehicles and am curious how much higher the Edge's ball hitch sits above the X5's hitch. Also, what size tow ball does the Edge require, 2" or 2-1/2"? Thanks!
-Chris
Chris D.
2009 X5 xDrive 35d (Alpine White, Tobacco leather, Bamboo Trim) Me Happy!
2005 Porsche Cayenne Base (Black with a pretty red-head interior)
1995 Land Rover Discovery (Dirty and dented, but loved)-SOLD
1962 Apache Eagle Pop-up Tent Trailer.-SOLD
2015 Flagstaff Micro Lite 23LB (Our new HoW, "House on Wheels")
Old 01-05-2015, 06:01 PM
These trucks pull very well!
Old 01-06-2015, 05:56 PM
Rickm5X3 Rickm5X3 is offline
Prefers bhp over mpg
Mein Auto: E70 X5M and 4.8i
Originally Posted by MudyOvl View Post
Rick,
-Chris
Great! I think you will really like the Edge. 2 5/16 inch ball and I use a 4 inch rise hitch to get to roughly 21 inches to top of ball on my X5M. For our 4.8i that same setup is 22 inches to top of ball. Either is in range for my Edge M22. so I say shoot for 21-22.
2011 X5M Alpine White/Sakhir Orange, Eucalyptus, Spare tire!, Comfort, Soft Close, Tech, Climate Package, Individual dash, Individual Audio, HUD, DVD, USB, Cold, OEM hitch
2016 Sierra 2500HD 6.6l turbodiesel SLT All-Terrain
Gone:
2008 4.8i
2005 X5 4.8is
2004 X5 4.4i Sport
2004 X3 3.0i 6MT
2002 M5
Old 01-06-2015, 06:22 PM
eyelise eyelise is offline
Mein Auto: S7
ant wt. distribution equipment or do you have air rear suspension?
Old 01-06-2015, 07:02 PM
No WDH, no anti-sway. I'm at 450 pounds give or take for tongue weight and that is within the 600 pound limit. BMW does not recommend "weight distribution equipment" (see link).
And yes, air suspension. One of the great things about the X5M is that every last one of them came with rear air. As did every 4.8i from 2007-2010 that had Sport Package (or maybe all 4.8i; losing memory here).
https://www.bavauto.com/Assets/inst_pages/ins370.pdf
Gone:
2008 4.8i
2005 X5 4.8is
2004 X5 4.4i Sport
2004 X3 3.0i 6MT
2002 M5
Old 01-07-2015, 05:24 AM
Michael47 Michael47 is offline
Mein Auto: '12 X5 35d
Um, I would say only that it's not a case of BMW not recommending WDH, but stating categorically don't do it. I quote from the linked instructions:
"Do not use weight distribution equipment."
This not in the form of a recommendation. _I_ recommend folks follow this injunction. BMW does not recommend here, they command.
Old 01-07-2015, 07:40 AM
Mein Auto: S7
I did hear WDH places a lot of additional strain on the hitch. If the tongue wt. is limited to 600lbs then the trailer weight really shouldn't be more than 6000lbs. Did I see a trailer wt. of 7400 being towed earlier in this thread?. I wonder how much the rear end would sag and affect the ride if one attempted to tow with the X5 without the rear air suspension?
Old 01-07-2015, 08:30 AM
Rick,
Thanks. Great information.
-Chris D.
Chris D.
Old 01-07-2015, 08:47 AM
Did you buy the edge yet or just close to purchase? There's a couple things I'd want you to check. In particular the stamped steel frame rails close to the the axle(s). Some had cracking problems, which can be fixed, but important to keep an eye on it.
Gone:
2008 4.8i
2005 X5 4.8is
2004 X5 4.4i Sport
2004 X3 3.0i 6MT
2002 M5
Old 01-07-2015, 08:49 AM
Also, consider immediately replacing the original tires with the higher quality Maxxis tires. A fresh set of quality trailer tires is one of the cheapest ways to reduce risk of trailering in in my book!
Gone:
2008 4.8i
2005 X5 4.8is
2004 X5 4.4i Sport
2004 X3 3.0i 6MT
2002 M5
Old 01-07-2015, 02:22 PM
Rick,
I haven't bought the Edge yet, but am close. Thanks for the heads up on the possible occurrence of frame cracks near the axles. I will be sure to inspect those areas closely. I will also look into getting new Maxxis tires if the originals are still mounted. Thanks for the information and feel free to PM me anything else you can think of.
Regards,
Chris D.
Chris D.
