Towing Photos with X5. - Page 2 - Bimmerfest - BMW Forums
Old 04-07-2013, 04:52 PM
kakalika's Avatar
kakalika kakalika is offline
Mein Auto: 12 X5 d, 10 535, 02 530i
Here are a few things I have towed with my X5 35D. Never had a problem. I used a hitch from Europe because I did not want to cut up the bumper. That diesel just loves to tow on the highway! I don't have the third row seat option, but the car came stock with the rear air suspension.
Run flat tires? Nein Danke!
Old 04-07-2013, 06:26 PM
BeamerandBimmer BeamerandBimmer is offline
Mein Auto: MG M4
I recently picked up this 7x12 tandem axle.
Sometimes I haul stuff for the wife......
Sometimes I haul stuff for me......
This thing hauls like a dream, only downside is 10mpg if you're anywhere near 70mph.
Current BMWs
2016 Azurite M5(Almost Here)
2015 Mineral Gray M4
2010 R1200GS Adventure 30th Anniversary Edition
2016 S1000XR
Past BMWs
2014 S1000R
2013 Carbon Black X5 50i M-Sport
2010 Alpine White 135i M-Sport
2010 Carbon Black M5
2007 Graphite K1200GT
2008 335ia
2005 545i
2004 R1150R
2003.5 M3 Cabrio
2000 540ia
1997 M3 sedan
1997 540ia
Old 04-07-2013, 08:33 PM
yogi799 yogi799 is offline
Mein Auto: '11 535i, '99 328i retd
Whoa, with what approximate weight? Damn...
I don't think it's a stretch to say that those 10 MPGs would covert to 15 MPGs if you had the 35d, is it?
Old 04-08-2013, 04:52 AM
Mein Auto: MG M4
Load has little influence on MPG. I think mostly its wind resistance and engine and transmission management software. If it had a "tow" mode it might get as good as 13mpg but that's about it, I can baby it to about 11mpg if I stay around 60mph. I didn't buy the X5 as a tow vehicle, I bought it mostly to "haul" a$$. The low mpg doesn't bother me as much except that it ends up with a 210 mile range just like the M5.
Current BMWs
2016 S1000XR
Past BMWs
2014 S1000R
2008 335ia
2005 545i
2004 R1150R
2003.5 M3 Cabrio
2000 540ia
1997 M3 sedan
1997 540ia
Old 04-08-2013, 05:30 AM
kakalika's Avatar
[QUOTE=BeamerandBimmer;7502031]I recently picked up this 7x12 tandem axle.
That is a really nice trailer. I am looking out for a similar one, but a little bit longer, 7 X 14. It will have to be black, just like my X.
Sucks that you get 10mpg. I believe the V nose of the trailer really helps with economy, especially if it is longer, like 5 feet.
Old 04-16-2013, 10:14 AM
digdesign digdesign is offline
Mein Auto: 2008 4.8i
Here's a quick pic of mine with the trailer.
- Mick D.
Old 04-16-2013, 11:25 AM
afshawnt's Avatar
afshawnt afshawnt is offline
Scheiße!!!
Mein Auto: E30 M3
2016 M3
2015 i3
2001 740i Sport
2013 X1 sDrive28i
2005 330i ZHP
1989 M3
Retired
2017 Porsche Macan S
2014 328d xDrive Sports Wagon
2013 X5 xDrive35d
2012 128i
2010 128i
2009 MINI Cooper
2006 330i
2004 325i
1999 323iC
1991 325i
Old 04-16-2013, 03:11 PM
kakalika's Avatar
Made a trip to Home Depot today. (Iphone pic)
Old 04-16-2013, 05:50 PM
philooo philooo is offline
Mein Auto: 2011 X5 5.0
Originally Posted by digdesign View Post
Can you comment bit on that picture ? is that a tongue weight distributor ?
Did you feel the need to add it ? did you try without it ?
Can you comment also on electric / hydraulic brake controller ? I've heard bmw can be finicky to deal with when it comes to electronics add-on.
I am planning to tow a car as well with my X5, not very often, but I'll be setting it up for that.
'11 X5 50i M-Sport
19" Black Saphire | Black | Alu | Lux Seat | Adaptive | Cold | Tech | Sound | Prem | Comf Acces | combox retrofit | Invisihitch oem harness
Old 04-16-2013, 06:42 PM
The trailer has surge brakes, not electric. What you're looking at is the mechanical brake actuator, which is essentially a master cylinder. As you brake and the weight of the trailer pushes forward against the ball, the coupler then slides along rails and puts pressure on the brake master cylinder.
FWIW: I prefer electric brakes with a controller over surge brakes for anything over a couple thousand pounds, but that's a whole different discussion.
I found the X towed ok without a weight distribution hitch. Not ideal. I still prefer a long wheelbase truck for towing. But as a dual-duty vehicle I'm very happy with it.
- Mick D.
Old 04-16-2013, 07:27 PM
Rickm5X3 Rickm5X3 is offline
Prefers bhp over mpg
Mein Auto: E70 X5M and 4.8i
Check out the prodigy wireless brake controller. I use it and it has been dependable and makes it easy to switch between tow vehicles.
2011 X5M Alpine White/Sakhir Orange, Eucalyptus, Spare tire!, Comfort, Soft Close, Tech, Climate Package, Individual dash, Individual Audio, HUD, DVD, USB, Cold, OEM hitch
2016 Sierra 2500HD 6.6l turbodiesel SLT All-Terrain
Gone:
2008 4.8i
2005 X5 4.8is
2004 X5 4.4i Sport
2004 X3 3.0i 6MT
2002 M5
Old 04-17-2013, 08:05 PM
troymi troymi is offline
Mein Auto: '14 650i X Coupe
I also see that you are using the hitch in the "up" extended position instead of the reduced position. Does that make sense? Anyway, words aside you are the first I have seen do this and I was considering doing this also after I just towed a heavy trailer. With the ball in the "down" side it seemed that the trailer dipped and the rear of the X5 was even lower. Did you try to use yours down also and switched it to the up position? Just wondering what others are doing.
Old 04-17-2013, 08:48 PM
Almost all ball mounts are designed to be mounted in either position depending if you need a drop or rise to get your trailer level. You'll see on the packaging that they're marked with both measurements. This one, for instance, is labeled "Ball Mount 3/4" Rise or 2" Drop" depending on how it's flipped.
http://www.etrailer.com/Ball-Mounts/Draw-Tite/2923.html
What you need to do is level the trailer then measure the distance between the bottom of the trailer coupler and top of the receiver. That will tell you the amount of drop/rise you need. When I do this I usually round up, or add in a little fudge factor, anticipating that the rear of the tow vehicle will sag a bit when the trailer is connected.
Here's a decent overview on how to take the measurement.
http://www.etrailer.com/faq-ballmount.aspx
It's really important to get your trailer level, especially if you're towing a dual axle trailer. When it's dropping too much in the front you put more of the load on the front wheels while the rear wheels are lifting a bit. It also shifts more weight onto the ball, which will be exaggerated when you go over bumps.
HTH
- Mick D.
Old 04-17-2013, 08:55 PM
Let's see more of the GS
- Mick D.
Old 04-19-2013, 09:42 PM
Has anyone noticed that when the trailer is connected their side mirrors don't auto dim? I was towing home from the track in the dark tonight and my mirrors weren't dimming. After I dropped off the trailer they were dimming gain. Fluke or by design?
- Mick D.
Old 04-19-2013, 09:44 PM
if it is true that would be great as this would mean the auto dimming could actually be controlled manually in one way or another... sometime I really like to remove the auto dimming to get more clarity.
'11 X5 50i M-Sport
Old 04-20-2013, 03:43 AM
Mein Auto: MG M4
I noticed this as well. I thought it was because the trailer blocked the interior rear view(sensor) mirror.
Current BMWs
2016 S1000XR
Past BMWs
2014 S1000R
2008 335ia
2005 545i
2004 R1150R
2003.5 M3 Cabrio
2000 540ia
1997 M3 sedan
1997 540ia
Old 04-20-2013, 07:36 AM
Good thinking. I bet you're right.
- Mick D.
Old 04-21-2013, 03:06 AM
dcharnet's Avatar
dcharnet dcharnet is offline
Mein Auto: BMW '15 X5 35d
I get 11-13 towing @70-75. The main factor is wind velocity and direction.My trailer is an 18' V-nose, and the total deadweight including race car is 4500 or so. This is 1-2 less than I got with my Tuareg diesel, which should be pretty close to the 35d. My X5 35i tows better than the VW did overall, though, mainly due to WB/ suspension differences. I like diesels, but the 35i is fine for towing and I feel no need for a diesel.
Old 04-21-2013, 11:11 AM
bimwad bimwad is offline
Mein Auto: '09 750i, '10 X5, '11 RR
I have towed various sizes of U-Haul trailers in the past with my 2010 X5 3.0, mostly when friends are moving and need help but don't have a truck with a hitch. No complaints since 2010..
TIA
Mohamed
'05 E53 X5 3.0 | Premium | Rear Climate | Xenons | Privacy Glass
'07 RR HSE Lux
'09 F01 750i sport | premium sound | CWP | Rear Wood Shelf | BT Audio
'10 E70 X5 xdrive30i sport | rear shades | rear climate | iPod/USB | Sat Radio | DVD in Motion activated
'13 328i drive | premium | heated| executive | privacy glass |HUD
'14 F10 550i M Sport | premium sound | CWP | Rear Shade | BT Audio |HUD
'16 K1600GTL Exclusiv
Old 04-21-2013, 10:45 PM
scotts10x5m scotts10x5m is offline
Mein Auto: 10' X5M, 14' 535d M-sport
My X5M tows like a dream; can't even tell I have ~6k pounds behind me while towing my race car. I'd like to add electric brakes, as the trailer is already equipped with it. Big dollar install of the hitch (and computer reset) from the dealer, but thankfully I was able to negotiate it in with the original purchase for cost. ~11mpg in efficiency mode while towing, and just under 10mpg in M mode while towing.
Old 04-22-2013, 08:28 AM
serge1's Avatar
serge1 serge1 is offline
Mein Auto: 2011 BMW X5 35D
While we are at it, what are 0-60 numbers with loaded trailer?
Old 04-22-2013, 08:33 AM
WannabeX5 WannabeX5 is offline
Bimmer Family
Mein Auto: '12 X5 35D, '07 550i
Probably about the same as my diesel X5 unloaded!
2012 X5 35d-Black Sapphire/Graphite - SAV, Premium, Cold Weather, Navigation, HiFi Sound
2009 328i Touring 6MT-Montego Blue/Oyster - Sport Package, Navigation, H/K Logic 7, Lighting Package
2007 550i-Mystic Blue/Graphite - Sport Package, Premium, H/K Logic 7, Cold Weather
Old 04-22-2013, 06:16 PM
Probably stronger and only limited by yanking the subframe apart on launch!
Gone:
2008 4.8i
2005 X5 4.8is
2004 X5 4.4i Sport
2004 X3 3.0i 6MT
2002 M5
Old 04-22-2013, 06:40 PM
serge1's Avatar
Due to AWD and rear wheel bias, the point of tear will be somewhere between rear wheels and the trailer.
