E36 (1991 - 1999)
Old 04-03-2013, 02:24 PM
jricky74 jricky74 is offline
Mein Auto: 1995 BMW 325i
Bad idle/stalling no codes
HAVE A BEAD IDLE WHEN STOPPED AT A LIGHT OR IN REVERSE. DID THE STOMP TEST AND HAS NO CODES STORED. THE COMPUTER KEEPS SAYING CHECK COOLANT LEVEL BUT LEVEL IS FINE, COULD THE COOLANT LEVEL SENSOR BE CAUSING THIS????????
Old 04-03-2013, 03:02 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I thought the forum auto-decapitalized posts like this?
Anyway, no the coolant sensor wouldn't cause this. My bet is the Idle Control Valve. Have you searched the forum at all?
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 04-03-2013, 03:09 PM
Oh yeah, since this problem has been there I am on here everyday trying to pin point the problem but there aren't any codes. wouldn't it throw a code for that?
Old 04-03-2013, 03:14 PM
petriej's Avatar
Yea it should if the idle is bad enough. I'm not sure for a '95, though (OBD1).
How handy are you with simple tools? You might want to start poking around in there.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-03-2013, 03:29 PM
I tried cleaning the icv last month and that did't work is there a way to check it before replacing it
Old 04-03-2013, 06:20 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Vacuum leak(s). Trace hoses and replace all of them that are spongy or cracked. Check your pleated intake boot for cracks.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
