Old 04-04-2013, 07:14 AM
vk535i vk535i is offline
Mein Auto: 535i
Question about M5 or M6 wheel style for E60
Hi all,
I am little bored on my original wheels (rims) that came with the vehicle. I think it's style 124 with 7 spokes. it shows the brake dirt so much. About 1 week to 10 days of driving these wheels turn into very much black .
I search around and found the M5 or M6 replica wheel looks very nice on the BMW but I don't know they are fit on my vehicle (E60)
My original 124 style has the offset 45mm, 8" for the front and 55mm, 9" for the rear since those replica wheels have +20mm offset,t 8.5" for the front, +20mm, 9.5" for the rear. Are these wheel fit my car without any modifications? if I can transfer all my tires over as well ( I just put on a set tires 2 months ago).
any recommendations?
thanks
2014 550i, Jet Black / Black Dakota Black, Bamboo Anthracite Wood Trim, M-Sport Package, Executive Package, LED Lighting Package, M Aerodynamics Package, HUD, Adaptive LED Headlight, Harman/kardon Surround Sound System. Surround/top View Camera, BMW Apps via SmartPhone, Split fold-down-rear seat ...
Old 04-04-2013, 08:26 AM
GOR777's Avatar
GOR777 GOR777 is offline
Mein Auto: 2007 BMW 550I
The dirt is from your cars brakes. Yes those replicas will fit but it needs to be the correct size for the tires you have on.
http://tinypic.com/r/23prax/5
Old 04-04-2013, 08:31 AM
Mein Auto: 535i
Here is the one I'd like to get and supposed the size the same as my original wheel (if I get 18"), only the offset are different
Old 04-04-2013, 08:39 AM
GOR777's Avatar
whats the offset?
Old 04-04-2013, 08:41 AM
Mein Auto: 535i
here is the spec. for the wheel 18"
Product Details:
Wheel Style - Model 325
Wheel Diameter (Inches) -18 "
Wheel Width (Inches) - 8"
PCD Bolt Pattern - 5x120MM
Offset - 37MM
Hub Bore - 72.6MM
Color -Gun Metal Machine Face
Spec for 19"
Wheel Description:
Name:BMW Wheels - Model #5064
Size 19X8.5" All Around
Bolt Pattern 5x 120 mm
Offset 37 mm
Color: Gun Metal W/Machine Lip
Hub Bore Size: 72.6 mm
Part # :I50641985512037726GMF
Old 04-04-2013, 08:52 AM
GOR777's Avatar
I think that size is for the xi, rwd should be around -20 offset
Old 04-04-2013, 08:57 AM
GOR777's Avatar
try here
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Old 04-04-2013, 09:36 AM
Mein Auto: 535i
The offset for those wheels are 37mm. How do I find out my current wheels offset? it's BMW style 124 .
Old 04-05-2013, 05:20 AM
stmoore01 stmoore01 is offline
Mein Auto: 2010 535xi sport
offsets
Here you go
BMW wheel rim style 124
5er E60+
All styles 1 3 5 6 7 X Z
Series Model Except Size Use ET Kg
5er E60+ M5, 4x4 8x18 front ET 20 11,23
5er E60+ M5, 4x4 9x18 back ET 32 11,30
5er E60+ 4x4 8x18 front ET 43 11,23
5er E60+ 9x18 back ET 55 11,23
So if your 535 is a rear wheel drive car the offsets are 20 in front 32 in back, if an xi then 43 in front and 55 in back.
Using the wheels your looking at on a rear wheel drive 535 your tire and wheel will sit farther out from the hub by about 1/2" in front and less than a 1/4 in the rear, so you shouldn't notice much difference.
Old 04-05-2013, 06:30 AM
Mein Auto: 535i
If I use those wheels that I am looking at with the tires installed, will tires touch the arc since it the wheel sit farther out about 1/2" ?
What you guys suggestion should I go with the 19" or stay with the 18" ? I don't want the rough drive , bouncing too much. if The 19" is smooth drive and not too much of bouncing, bumping I may consider for it
Old 04-05-2013, 11:33 AM
No danger of hitting the lip
Old 04-05-2013, 12:15 PM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
RWD E60 stock offsets are: 15 front/ 20 rear. The higher offsets are for AWD models only.
All wheels have a range of offsets that work, depending on how "flush" you want fitment to be. For RWDD models the range is typically 15-22 front, and 20-25 rear. M6 OEM offset is: 18 front and 22 rear
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 04-05-2013, 07:24 PM
Mein Auto: 535i
I am thinking to get those wheels, what do you think bro ? I haven't seen on in real life but look cool at the pictures
Old 04-05-2013, 07:48 PM
M6 or M6 "style" wheels look badass on the E60. Plus they're fairly easy to clean. Just try to find a replica set that are hubcentric or ones that come with hubcentric rings and make sure the tire shop you use installs them or you will have vibration issues.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 04-05-2013, 08:03 PM
Mein Auto: 535i
I am either go with discount tires or Goodyear. I use those 2 places for my G37 and my wife Lesux. I think they expert on installation thanks bro-
Old 04-05-2013, 08:27 PM
Cool bro, whoever you trust. I have found that shops I use regularly, it doesn't hurt to give the guy a $20 if he does a good job, they tend to remember that and take a little extra care the next time.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 04-06-2013, 11:37 AM
gmnmsclM540i's Avatar
gmnmsclM540i gmnmsclM540i is offline
545i pilot
Mein Auto: e60 545i e34 540 e32 740
^+1
Sent from my DROID RAZR using Bimmer App
Old 04-07-2013, 09:18 AM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
will these M 6 style wheels work for my 2010 550i as a second set ?
ET is highest , will it rub or not ?
My current wheels are
19" M double spoke 172
Tires Continental
Front axle 245/35R 93Y 81/2JX19 ET:18
Rear axle 275/30R19 96Y 91/2JX19 ET:32
replacement
20" LAW V Spoke 356
Tire Dunlop SP Sport Maxx DSST ROF
Front axle 245/35R20 95Y 81/2JX20 ET:33
Rear axle 275/30R20 97Y 9JX20 ET:44
Old 04-07-2013, 09:40 AM
Mein Auto: 535i
So when I call to order the wheel set, I need to ask those wheel are hubcentric? or does it come with the hubcentric rings? If they don't have one, can I just buy those ring to install ?
cuz on their website did not mention anything about hubcentric. They do mention this "Hub Bore Size: 72.6 mm"
Old 04-08-2013, 11:32 AM
the only E39 has Hub Bore Size: 71.5 MM
all the rest BMW including your 535i have Hub Bore Size: 72.6 mm
I just bought M6 wheels/tires BMW V-Spoke Style 356 Liquid Black 20" for my 550i
Not much info about these wheels for 550i E60 but i assume i should be fine
with less gaps between tires and fenders ...
we will see ;
Old 04-08-2013, 12:00 PM
Mein Auto: 535i
Hubcenteic Rings
we will see ;
So did you get or need a hubcentric rings for those wheels?
Old 04-08-2013, 12:23 PM
dude
no need any hubcentric rings between M6/M5/e60 wheels
All have the same Hub Bore Size:72.6 mm , read above
Old 04-09-2013, 09:10 PM
runk1855 runk1855 is offline
Mein Auto: Tahoe
Got the same ones
Got the same ones Avant Garde for my 2007 530 Sport. They are a game changer looks wise. I love them. Will try and post a pic when I can
Old 04-09-2013, 09:43 PM
etnav382 etnav382 is offline
Mein Auto: 06 550i
This is mine and the bottom one is another members pic.
Old 04-10-2013, 11:51 AM
Mein Auto: 535i
the one you have is 19" or 18" ?
