E36 (1991 - 1999)
Old 04-04-2013, 02:47 PM
Pat7762 Pat7762 is offline
Send a message via AIM to Pat7762
Mein Auto: 05 BMW x3 3.0 + 93 325is
Communicating with modules???
I have tried an autologic, carsoft, an old Launch, and Autel MaxiDAS with no luck. The car is a 93 325is using only the 20 pin of course because its pre obd2. Can anyone explain to me or point me in the right direction on how the modules communicate? I was told it is a primitive bus system. I was also told that if I have a bad module that it will bring down the whole bus system, and was told to start unplugging the modules till the system came back online but I haven't had any success. I don't have any lights on right now but I would like to take a look at some parameters. Any help would be greatly appreciated.
Old 04-04-2013, 04:26 PM
I tried hooking up the autel to my buddy's 95 325is and his worked so I checked his pin 20 pin and his showed 3.9volts mine had a ground that was on and off like Morris code. So I guess I do have a module that is grounding the communication line. Now I guess I need to unplug more module.
Old 04-04-2013, 08:38 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Morris code?
Do you mean Morse code?
That aside, what is the issue you are experiencing ?
I've a feeling that you are going into far too much detail for what ever the problem is.
Like Chad, I am far too lazy to double check Swype.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 04-04-2013, 11:17 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
The digital system in your E36 is a CAN BUS network. Pin 20 is the data line and it wouldn't be out of the ordinary to see it toggling between 0 volts and 4-5volts. The "Morse Code" you are seeing are the serial digital words on the data bus. It is possible that you have a module that is ignoring its address and not releasing control of the bus, but you want to unplug the modules one at a time and then plug them back in if it doesn't let your analyzer connect. If you unplug all of them the toggling will go away because all you'll be connected to is wire.....
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 04-05-2013, 01:42 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
The 20 pin, under-hood diagnostic connector on the OP's '93 carries the 12V, open collector, active low D-bus. This 1.3 MB PDF has some information about troubleshooting it, starting on page 13.
Old 04-05-2013, 03:03 AM
Thanks guys!! Any known Problematic modules?
Old 04-05-2013, 12:49 PM
Do you know if the 95 e36 would still use the d-bus system?
Old 04-05-2013, 12:53 PM
johnf's Avatar
John Firestone
Yes, the E36 used the D-bus with the 20-pin connector for its entire run.
Old 04-07-2013, 07:13 AM
Found the problem, it was the IHKA. I unplugged it and my bus was back online. Now I need to find a used one. Thanks for all the replys, the PDF info was really helpful!
Old 04-07-2013, 07:48 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
what's an ihka??
df
Old 04-08-2013, 01:03 AM
johnf's Avatar
John Firestone
IHKA = Integrierte Heiz- und Klimaautomatic = combined, automatic heater and air conditioner
An HVAC for them that like buttons and digital displays with a mind of their own. (Just kidding.)
Old 04-08-2013, 04:19 PM
ah....gotcha. thanks for the translation.
df
