Headlights blink when first turn on - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-04-2013, 04:39 PM
Toner Cartridge Toner Cartridge is offline
Mein Auto: 323i 1996
Hi all, first post
Bit of background, my E36 (Australian version) been sitting for 4 years not registered. Decided to get her going. Had a fuel problem but fixed now. Replaced the windscreen water tank pump and petrol filler cover solenoid (both faulty).
NOW when I turn on the headlights, there is a slight delay (maybe a second) and the lights come on for 2 secs, momentarily go off, stay on for maybe 2 secs, momentarily go off, comes on & then it settles down & they stay on.
Any ideas where to start looking?
Also got a couple of other problems (maybe connected to this, I don't know, maybe start a separate thread?)
- dashboard display showing kms travelled, sometimes, at turn on only shows the bottom half of the number segment i.e. instead of displaying an 8 just shows the bottom 'o' of the 8 . When this happens the bar graph and 'inspection' data below are VERY dimly lit. After couple of seconds when the bar graph goes out, the kms travelled display lights up as normal & everything is fine.
- driver door window, when it is closing (going up) it stops about 1" from the top & comes back down maybe 1/2" and then stops. I have to try a couple of times before it closes completely. Its like it hits a limit switch too early
Old 04-04-2013, 04:45 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
That's a weird one, I'd start with the relay. That's the only thing that comes to mind that would allow blinking like that with such regularity.
Your window is binding in the tracks. The motor senses that its taking too much effort to roll the window up so it reverses, thinking something is caught in the frame. You'll want to pull the door panel and make sure the tracks and rollers are in good shape.
Any errors in this post are purely Swype's fault, not mine.
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 04-04-2013, 06:40 PM
WOW quick reply
thanks for the info, will have a look
Old 04-05-2013, 12:56 AM
johnf's Avatar
johnf johnf is offline
John Firestone
Mein Auto: 1996 318is
I might also suspect a dirty or disintegrating headlight switch.
Old 04-06-2013, 04:22 PM
Turned out to be problem with the relay. When I put my finger on it & moved it side to side, the headlights went off/on. So I removed the relay, closed the relay socket contacts a bit, sprayed some WD40 in there. Now the lights come on the instant I turn the headlight switch I'll see how it performs over time.
Old 04-06-2013, 09:52 PM
I Am The Machine
Great! Glad it was just a relay. May as well replace the thing, they're only 10 bucks or so.
// Chad //
You're a derbanana
