Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E60 M5 (2006 - 2010)
Old 04-04-2013, 07:34 PM
gtwhale gtwhale is offline
Mein Auto: M35
Red cog-Clutch Adaptation Active
Hi there I am looking at buying an 06 M5 e60 smg with known clutch issues. It has 43K miles. They are discounting the price for the need of repairs.
The car runs a little rough in low gears but not terrible. In up gears and higher rpms seems to really pull nicely.. It has the red cog and beeping constantly with "Clutch! adaptation active" on the screen.
They took it to an indy mechanic that apperently tried to reset everything or adapt- not sure that he had the corrrect software, but said the adaptation would not take.. not sure what the codes there were. He saaid he tested the pump pressure and that it seem fine.
They would not let me try the 2 paddle reset while I was driving it... but with red cog not sure that would would anyhow...
Any thoughts...The indy mechanic said it looked like someone had been in the tranny recently and may have replaced the clutch and fly wheel but didnt know unless he takes it back apart...
So long story short, are there any suggestions has anyone seen this "clutch! adaptation active". posibble fixes or worst case scenarios..
Is there any amatuer type scanner software that I could try out prior to spending the big bucks on new clutch-flywheel?
I'd appreciate any input.
Old 04-05-2013, 04:30 PM
MarkieM5 MarkieM5 is offline
Mein Auto: M5
Other than bringing it to BMW I think you are wasting your time. So much on these cars are proprietary to BMW that without the factory diagnostic tools and software for issues like this, no one other than BMW can fix it. I believe an SMG pump replacement is 4K. I think the entire tranny is $6700. Point is, this could be a very expensive fix. In My opinion, I would not touch this car.
Old 04-05-2013, 07:23 PM
Mein Auto: M35
If all else looks good with the car, I could offer them $10K off the going price for a low mileage '06...Which is about what I have discussed with them.
Old 04-06-2013, 02:48 AM
Mein Auto: M5
I think if you can get the car with a 10K 'cushion' let's say under the appraised value, you should be OK. I would still run all this by a service manager at your local BMW dealer. Even better, if the seller lets you bring it to them for a repair estimate. It's well worth the few hundred bucks they would charge you to go over the car even if you don't buy it. These cars are very expensive to fix. Good Luck! keep us posted.
Old 04-09-2013, 05:20 PM
Db750's Avatar
Db750 Db750 is offline
David
Mein Auto: M3 - M6 - 911
Is there anything you can try out before spending the big bucks??? The car isn't even yours! Why would you even consider spending money?
I would let this one go. The seller sounds like he's full of ****. There are plenty of M5's on the market.
When you find one have it inspected. I would recommend having it inspected at an Indy found through bimrs.org. Join up at BMWCCA while your at it.
Don't buy someone else's problem. If they don't want to fully disclose the problems and have the car fixed IMO it's not worth it.
Good luck.
2014 Carrera 2S - White/2 Tone Espresso/Cognac - Aerokit - PSE - PDCC - SPASM - PDK - Sport Chrono - 20" wheels w/OEM Spacers - Glass Roof - Leather Dash - way too much more to list
2013 F12 M6 - Alpine White/Black Merino - Executive - LEDs - B&O - DA - Lots more
2013 E92 M3 - LeMans Blue/Black Novillo -(Lease ended need new signature pic)
