Old 04-05-2013, 07:07 AM
Schemin Schemin is offline
Mein Auto: 323i
springy noise at left rear wheel
hey guys im just wondering if i should get it checked at the dealership or not.
it started when the weather got colder and dropped to -12 then the springy noise got louder.
idk if it just needs some grease or lube. would the computer tell me if somethings wrong with my shocks or coilovers or whatevers making that noise.
Old 04-05-2013, 07:20 AM
b5rider b5rider is offline
Mein Auto: 535
If it only happens when you are parked,it's the parking brake and its totally normal
Old 04-05-2013, 07:30 AM
Mein Auto: 323i
it happens when i drive and hit pot holes on the road even with smallest bumps. it wasnt like that the other day when it wasnt this cold
Old 04-05-2013, 08:19 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
Probably one of the road springs sticking on its seat then freeing itself with a...'springy noise' as you put it. A little lubricant sprayed on the upper and lower mount areas might help.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 04-05-2013, 08:40 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Get kinda loud myself at -12 deg. Hey, YouTube that bad boy w/good audio!
Boi-yoi-yoi-ying?
Old 04-05-2013, 06:45 PM
Mein Auto: 323i
hey phil idk exactly where those are and what kind of lubricant i should buy at the store or if they are available at canadian tire or some store like that. thanks
Old 04-06-2013, 05:32 AM
Phil325i's Avatar
The part that needs lube is at the top and base of the spring and what they rest on. Sorry I have no knowledge of Canadian suppliers - but any light easing or penetrating oil will do.
Old 04-07-2013, 05:54 AM
Banned
Mein Auto: 2007-335 HTC
have you pulled the wheel off and visually inspect it yet? if not maybe you need to see if you can see what is going on
