Old 04-05-2013, 02:51 PM
jomaa09-128i jomaa09-128i is offline
Mein Auto: 2009 BMW 128i convertible
Help!!!!!
Just got my 2009 128i . And when i start it , it starts beautifully but there is a pretty medium sounding tick noise from the back of the car. Same for when i shut the car off. Please help itd be great to put me at ease?
Galaxy Note II
Old 04-09-2013, 02:17 PM
mr29 mr29 is offline
Mein Auto: bmw
Galaxy Note II
wrong type of gas put into it many times. heard it will run on unleaded but develops a tick after awhile or something is loose
Old 04-09-2013, 04:13 PM
Gosh darnit if thats the case how do i fix.that?
Galaxy Note II
Old 04-09-2013, 06:56 PM
Mein Auto: bmw
it's just a guess i am not sure.here is a thread to check out that talks about the ping sound.
http://www.bimmerfest.com/forums/sho...d.php?t=674509
1 series fuel questions
Old 04-10-2013, 05:21 AM
drcollie drcollie is offline
Mein Auto: 135i
Fuel Octane has nothing to do with a ticking sound in the rear of the car. Most likely its just your Catalytic Convertor heating up at startup and cooling down at shut off. If it concerns you have your dealer check it out. Cats are covered under the emissions warranty for 8 years, 80K miles.
Old 04-10-2013, 07:03 PM
gordonzhao gordonzhao is offline
Mein Auto: 128I
I've heard of the ticking on a lot of cars after it's been turned off which is normal, but in most cases with the engine on I probably haven't heard it at start up, if you want to be safe bring it to a mechanic you trust.
It's sad that anyone would put anything but premium in a BMW. I, myself am very picky with gas, only Shell or Mobil premium, most of the time it's Shell as there aren't as many Mobils around. None of that BP, marathon, or Citgo crap.
Sent from my GT-N8000 using Bimmer App
Old 04-10-2013, 08:33 PM
Norm37 Norm37 is offline
Mein Auto: Chevy half ton pickup
This article is a good read on gasoline.
http://www.vettenet.org/octane.html
Be sure and read the paragraph (Insider's trick on gasoline additives.)
Old 04-10-2013, 08:52 PM
Mein Auto: 128I
http://www.toptiergas.com
http://www.epa.gov/otaq/fuels/boutiq...utiquelist.htm
I see the authors point, but let's just use calcium or rust deposits as an example, if one 'cleaner' (fuel) works well to clean it, switching to another may or may not have a negative effect, I've seen plenty of cleaners that don't work as well as others, you switch back and forth and eventually the cleaner that didn't work as well will have left a lot of deposit build up which the regular cleaner won't be able to keep up and remove the now saturated deposits.
I've had no problems with Shell and Mobil, I use Mobil maybe once a month of not 2 months. And Shell mainly, my vehicle is now at 106k, no issues yet, brought it into my mechanic last year and he's impressed that a 2004 was so clean.
I'm not saying don't try it, but sticking to one company that I've used for so long works, and for a company like Shell, I believe they have certain critiques which must be met for their gas. At least having done a bit of research online in the past people have actually gone and tested the grade of gas at their local stations, randomly. BP definitely does not fall under top tier gas.
Old 04-11-2013, 11:20 AM
Thanks a lot guys. I'm going to take it in to have them look at it. I have a 4 year 50k warranty.
Galaxy Note II
Old 04-15-2013, 07:27 AM
Mein Auto: 128I
On a '09?
