E46 (1999 - 2006)
View Poll Results: Has your gas gauge ever had a false reading?
Yes, but it never happened again, under warranty? 0 0%
Yes,, happened once not under warranty. Fixed DIY ! 0 0%
Yes, has happened on several occasions 1 20.00%
No, has never happened. 4 80.00%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Old 04-05-2013, 05:59 PM
CyndyB CyndyB is offline
Mein Auto: 2004 325ci E46
Question Fuel Gage is always reading empty !!!!
My 2004 325ci has been really good to me, however, recently my fuel reading is never on point. I have replaced fuel filter, fuel pump/sender, and left sender unit. I am still getting this bad fuel reading. I read somewhere that the circuit board that is attached to the left sender unit slips out of place and sometimes causes this problem. Has anyone had this problem and actually fixed it in a DIY situation? Please help as the BMW dealerships are not as kind when your vehicle is out of warranty and paid for!
Old 04-06-2013, 12:23 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
http://www.passatworld.com/forums/56...uge-issue.html
Old 04-06-2013, 08:33 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
I'm not seeing how that thread helps her out much. But I would try the gauge cluster sweep test if I were her.
Then I'd also add using the OBC hidden functions to pull up the individual sender readings to see what that produced. If you get that far, report back here with each sender reading.
empty, filter, fuel consumption gauge, pump relay, reading, sender
