Need Advice - Floor or Hydro jack - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 04-06-2013, 03:46 AM
Mavericc Mavericc is offline
Mein Auto: 316i M3
Hey all, just need to quickly ask, what would yall recommend? a floor jack or a hydro jack? Please keep in mind that my bimmer is pretty low to the ground. (unfortunately it did not have a jack or cross wrench include...whic I had the pleasure of finding out when I had a flat.)
Old 04-06-2013, 03:50 AM
damnboy37 damnboy37 is offline
Mein Auto: 99M3,95M3
You can get a low profile floor jack, but I would go with the latter.
99 M3 320whp @ 6psi
95 M3
Old 04-06-2013, 05:59 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
If you want to kill yourself get the hydraulic jack...Under the assumption that you're referring to a bottle jack as a hydraulic jack .
If you want to be safe get the floor jack and 2 jackstands. The floor jack is a hydraulic jack with the cylinder laying horizontally.
m
Old 04-06-2013, 01:53 PM
I assume he means a lift
99 M3 320whp @ 6psi
95 M3
Old 04-06-2013, 02:32 PM
George Allan George Allan is offline
Mein Auto: bmw 2007 x3
Depends what you want to do. Never get under a car with jacks alone of any type . But I like the hydro jack- it is low enough although you need to be careful where you start the lift-- no soft places , only the jack points for example.
George allan
Old 04-08-2013, 05:11 AM
Mein Auto: 316i M3
Thanks guys, I went with the floor jack and 2 jackstands. I actually tried the hydro jack (bottle type) before purchasing and the car freakin fell off it. Very unstable. So the choice was simple! hahahha
Old 04-12-2013, 06:57 AM
Nline6's Avatar
Nline6 Nline6 is offline
Slip slidin around town
Mein Auto: E36 M3
I drive my car up on some home made wood ramps and then lift the front / rear on the subframe and remove ramps, add jack stands. So far so good.
Old 04-13-2013, 02:26 AM
Mein Auto: 316i M3
yeah thats my long term plan. Just needed to get my jack and stands for now. Ill add some pics in a minute.
