Old 04-06-2013, 07:45 AM
rlsa rlsa is offline
Mein Auto: BMW
Switch for opening window on backtail BMW E91 not working
Hi!
Anybody out there ever tried to dismount the switch on the tailgate?
I have been trying to dismount the panel on the tailgate, but it seems that I need to open the window to be able to do this. But now I have access to the motor for the windshield wiper. I am trying to loose it from the window, so that I can dismount the switch on the window.
But it is not easy, becuse of the panel!
Anybody have any tips for me before I rip off the panel :P
Old 04-07-2013, 06:08 AM
Mein Auto: BMW
This is the switch I am talking about...
Old 07-29-2013, 02:39 AM
paralichko paralichko is offline
Mein Auto: 330xd
Hi,
did You replace it ? I have the same problem, and i am stuck. I can not remove the old switch from the window ? Do You know how it is removed. I have searched the TIS without success.
BR
Gaby
Old 07-29-2013, 03:28 PM
BMW-bfd BMW-bfd is offline
Mein Auto: 328i E91, 2007 sportwagon
E91 tailgate window switch remove & replace
I replaced that exact part on my E91 about 2 weeks ago.
First photo, pop off the 2 round plastic covers that conceal the nuts that hold on the large cover and remove the 2 nuts and the cover. There is 1 additional nut that then holds on the backing plate. loosen and remove all three. Disconnect the wire switch connector.
Second Photo: lift the wiper arm away from the window to take the pressure off the wiper arm, and lift the plastic covering of the wiper arm cover that conceals 2 nuts on the shaft. Remove the first one (the silver one), and using a large flat screwdriver, position it under the arm where it sits on the shaft and pry the wiper arm off the shaft from under the arm. (There's probably a special tool, kinda like a "pickle fork" that's used to remove tie rod ends (but smaller) to remove the wiper arm, but I don't have one.) Then remove the larger nut that holds the switch tight against the window (the large black nut) don't loose the skinny washer that goes under the large nut.
Once you get all these removed, you can easily remove the switch & wire. The new switch includes the wire & connector, and a gasket to place between the glass and the new switch.
ID:	388994   Click image for larger version
Old 07-30-2013, 03:52 AM
Mein Auto: 330xd
I already tried it. I removed the wiper arm and the shaft ( the bug nut ), and the switch looks like glued to the window. When i get the new switch i will try with force..., may be i'll change the window too :-)
Old 11-04-2014, 05:21 AM
stevep0000 stevep0000 is offline
Mein Auto: 325i Touring
Did you manage to remove the "stuck" switch and replace it ?
If so, how ?
Old 11-04-2014, 05:57 AM
Mein Auto: 330xd
No - but i programmed the window to be opened by keyfob.
Old 11-04-2014, 08:46 AM
Having a new switch, I decided to remove the old one the hard way.
Used a Stanley Knife/Box Cutter to shave away the old plastic switch surround to leave just the metal sleeve, which was corroded/stuck to the threaded spindle shaft.
Still couldn't remove the spindle from the holding plate, but managed to slide it sideways enough to get at the metal sleeve with a broken junior hacksaw blade,
Had to start "sawing" at an angle until enough room to get the blade perpendicular to the shaft. Once the slot was all the way to the threads, used various sized flat head screwdrivers to open out the metal sleeve.
Once the sleeve came away, fitted new switch, stripped and cleaned spindle, as it was a bit stiff, and then refitted everything. So nice to have the glass opening again !
Picture attached...
ID:	474037   Click image for larger version
Old 04-05-2015, 05:16 PM
kuhbuh kuhbuh is offline
Mein Auto: 320d
Hi Paralichko,
Could you please explain how you programmed opening the touring glass window via FOB in NCS Expert? Thanks a lot!
Old 04-24-2015, 09:01 AM
bmwjc bmwjc is offline
Mein Auto: E91 325d
hi i have a similar issue with mine but i cant open mine to get the panel off. anyone have any ideas how i can open that rear window to get at the switch etc?
Old 09-22-2015, 07:38 AM
okticom okticom is offline
Mein Auto: E91
don't need new one
hi I had same problem. Solution remove switch from tailgate(don't close tailgate glass)
switch can be opened end clean
you need to clean rust between clear plastic u need separate it 2 layers and clean with alcohol
put back every thing remember top part need click with bottom u need hold small metal pin with screwdriver while closing
Old 12-08-2015, 01:09 AM
ferdican ferdican is offline
I was having the same trouble with my E91 rear glass button. Progressively got harder to press it, until it stopped working completely the other day.
Thanks to okticom, i tried his approach and managed to fix it in the end.
Levered open the top of the switch with a screwdriver (maybe use something plastic instead so it doesn't damage the switch housing.
Prised apart the 2 layes of plastic housing the circuitry for the botton. Stupidly used acetone (nail polish remover) to clean it and I think I removed a lot of the conductive padding by accident.
Ended up finding some aluminium tape I had from screwfix. Checked resistivity was 0 with a multimeter. Cut a little square of it, and stuck it on where the black conductive padding was.
Hey presto, works a treat!
Might have to keep an eye on it, for any battery drain, but after a day here, all seems good.
Old 03-03-2016, 07:28 AM
jensjakobthorse jensjakobthorse is offline
Mein Auto: E91 335ix JB4
Did you have to remove the switch and if yes, how did you open the glass?
Old 03-26-2016, 11:57 AM
szalamispizza szalamispizza is offline
Mein Auto: 2006 E91 325i
I have the same issue, and I found this video although its an E61 but it should be the same:
But I can not work this out with a screwdriver. Any help is appreciated, thanks..
