E36 (1991 - 1999)
Old 05-02-2013, 09:42 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Originally Posted by drivinfaster View Post
that being said, if you continue to have a white smoke issue, use a block tester kit to check for the presence of co2 in the cooling system. the fluid will turn from blue to yellow. it's practically simpleton proof.
df
I would do exactly what DF says. I have this kit myself. It was fairly inexpensive on Amazon, and very easy to use. This will confirm whether you have a head gasket (or cracked block) issue or not.
Stay away from the metallic crap that goes in your coolant. It's basically glitter for your engine.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 05-02-2013, 10:18 AM
94oklahoma 94oklahoma is offline
94 525i
Mein Auto: 1998 bmw 740il e38 m62
I need to stop the leak I dint need a tester to tell me that I have a leak somewhere it's obvious I have a leak in the block...I have a new head and gasket obviously it's the block and I don't have the funds to buy a motor from the salvage ...just need a temporary stop
Old 05-02-2013, 10:28 AM
petriej's Avatar
Could you give us more detail on why it's obviously the block?
Go ahead and use the product that will ruin your car. Just know that it will never work right.
GGC BMW CCA #443004
Join the BMW CCA!
Old 05-02-2013, 11:17 AM
94 525i
Because the head and gasket is new Ii never let it get hot just only where it's hotter than normal and continues to use coolant there are no mixtures in oil or Wat so it has to be leaking internally from the block to the cylinder the hoses connecting to the heater core and the throttle body have been by passed to ensure no coolant is goin thru the intake
Old 05-07-2013, 06:31 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
I'm bumping this for my own benefit. Sorry OP. But shouldn't his white smoke have the sweet smell indicating coolant as well if it were a cracked head or head gasket? This is for my educational purposes only.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
