E46 (1999 - 2006)
Old 04-06-2013, 05:15 PM
Shaman2002 Shaman2002 is offline
Mein Auto: 2002 330xi
Tapping @ cold start
What's up!! . Hey need a little info. I have an 02 330xi, at cold start and only on cold start I'm hearing this tapping noise at top of engine. After it warms the sound would go away. If any feedback as to what this may be I'd greatly appreciate it.. Thanks!
Old 04-06-2013, 05:45 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
What oil are you using? I experienced this using some oils, but not others.
Old 04-07-2013, 10:21 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
If it's like 3 taps per second then it's probably your valve lifters making noise until they get some warm oil. Not terribly unusual. If it's more like marbles in a can, you could either have a worn/broken DISA flap (plugs into drivers side of the intake manifold) or a rattling vanos (front of engine, pistons that control intake and exhaust cam variability). Depends on where it's coming from.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 04-07-2013, 11:19 AM
catso's Avatar
catso catso is offline
catso
I would start by changing the oil and filter.
![/I][/FONT]
