Old 04-09-2013, 11:51 AM
ohno50 ohno50 is offline
Mein Auto: 2009 750LI
Bluetooth audio 2009 750LI
I have no idea if it is possible to make my stereo play music from my iPhone 45 through Bluetooth. my headphone jack sounds awful and it buzzes
Anyone have any advice for me?
Old 04-09-2013, 11:54 AM
coco135's Avatar
coco135 coco135 is offline
Mein Auto: 750i
yes, but it will cost you around $600 you will need to retrofit combox which many people here did and about to do it my self as well.
look here...
http://bimmerretrofit.com/store/inde...&product_id=66
there are many other improvements with this retrofit
Old 04-11-2013, 07:34 PM
bimwad bimwad is offline
Mein Auto: '09 750i, '10 X5, '11 RR
There is a cheap fix for bluetooth audio. It will cost you $15..
Order this part from Amazon http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Plug it into the ipod y cable in your armrest instead of your iPod
Sync your iphone with this unit and voila! You have bluetooth audio!
The beauty of it is that your iphone will still sync with the car for bluetooth phone use!
I have already done this in my 09 750 and it works beautifully!
TIA
Mohamed
'05 E53 X5 3.0 | Premium | Rear Climate | Xenons | Privacy Glass
'09 F01 750i sport | premium sound | CWP | Rear Wood Shelf | BT Audio
'10 E70 X5 xdrive30i sport | rear shades | rear climate | iPod/USB | Sat Radio | DVD in Motion activated
'13 328i drive | premium | heated| executive | privacy glass |HUD
'14 F10 550i M Sport | premium sound | CWP | Rear Shade | BT Audio |HUD
Old 04-11-2013, 09:19 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Hmmmm... $600 or $15?
Awesome! Question is... Will it with for Android???
BigMarcus ~ EVO 4G LTE
Old 04-11-2013, 11:57 PM
Just bought the Bluetooth adapter for 15 bucks. Thanks for the responses guys
Old 04-12-2013, 03:12 PM
Hi TX,
I am not sure if it will work with Android. It maybe worth a try for the $15 though.. Good luck!
TIA
Mohamed
Old 04-13-2013, 12:56 PM
BaranE BaranE is offline
Mein Auto: '10 740Li
This one works with my android.
http://www.amazon.com/Logitech-Wirel.../dp/B004VM1T5S
Old 05-22-2013, 03:11 PM
mrg0612 mrg0612 is offline
Mein Auto: 750Li
2010 750Li - streaming issue
I bought the Bluetooth adaptor and the y cable. I plugged into the USB port in arm rest and connected the Bluetooth device to my iPhone4. I put the iDrive system on Aux but nothing would play. The phone did pair up with the Bluetooth device. Am I missing a step? I really want to be able to play Pandora through the cars audio.
Old 05-22-2013, 04:24 PM
coole65i coole65i is offline
Mein Auto: 2009 F01 SPORT
2 words. Tunelink Audio. I used it in my E60 and works great with Android.
Old 05-22-2013, 04:53 PM
Mein Auto: 750Li
I think the Tune Link uses an FM frequency which I'm trying to avoid as those are a pain to deal with.
Old 05-22-2013, 05:35 PM
azbimmer's Avatar
azbimmer azbimmer is offline
Mein Auto: 2009 750i 2006 330ci
You need to use Airplay on your iPhone and select the Bluetooth adapter. I am not sure if Pandora supports Airplay, but iTunes does.
2012 Lexus LS460, 09 750i (sold), 06 BMW 330Ci, 03 MDX, 08 535i (Sold), 73 Piper Cherokee (sold), 82 Yamaha 750 (sold) Too many Audis, Mercedes-Benzes, and other Lexuses to mention.
Old 05-22-2013, 06:47 PM
mjolley9 mjolley9 is offline
Mein Auto: 2010 750LI - A total POS
The cheap amazon module worked for my iPhone. Can finally listen to pandora.
Old 05-23-2013, 04:52 AM
Mein Auto: 750Li
mjolley.....would you mind giving me a step by step on how you accomplished this? Also, if able to provide pics of device and cable along with how you have them connected would help also. Thanks for the assist!
Old 05-23-2013, 05:49 AM
Sure. Will try to take a few pictures after work.
All that I needed to do was attach the bluetooth module I purchased from Amazon directly to the Y iphone cable (the one in the center console which connects to USB and Aux). Afterwards, I set up the bluetooth connection between my phone and the module.
You can either use pandora or music saved to your phone by clicking on the Airplay logo in the bottom right corner of the phone. Just make sure you have your car set to play audio from the Aux input (and not USB).
2010 BMW 750LI
Old 05-23-2013, 06:49 AM
Mein Auto: 750Li
Got it!! I had only connected the USB portion of the y cable and once I plugged in both it worked fine.
Thanks for the assistance!!!
Old 05-23-2013, 08:54 PM
M4XBMW7's Avatar
M4XBMW7 M4XBMW7 is offline
TTurboFest
Mein Auto: F02 (750Li)
That's great guys , will it display the pandora playlist image on the screen as well ?
Old 05-24-2013, 04:07 AM
Mein Auto: 750Li
No it does not. You have to control everything through the phone except volume.
Old 05-25-2013, 12:14 AM
Tb750 Tb750 is offline
Mein Auto: 750li
Which one did you buy ?
Old 05-25-2013, 06:58 AM
Mein Auto: 750Li
I bought the cheap one on Amazon and it works perfect!
Old 06-17-2013, 08:46 PM
M4XBMW7's Avatar
TTurboFest
Have to say , best $12 i have ever spent
http://www.amazon.com/gp/product/B00...=5336612388-20
Old 06-17-2013, 09:46 PM
kly725 kly725 is offline
Mein Auto: 2010 750ix
Will it work with android?
Old 06-17-2013, 09:57 PM
M4XBMW7's Avatar
TTurboFest
Here are the above questions related to android, followed by a answer at the very bottom , But not exactly the same unit .
Hi TX,
Originally Posted by BaranE View Post
Old 06-19-2013, 11:02 AM
ras31 ras31 is offline
Mein Auto: 2009 750Li
Yes, it does. I have an android phone (Motorola RAZR HD Maxx)
Old 06-19-2013, 12:20 PM
AstroZ AstroZ is offline
Mein Auto: VW touareg
I just ordered one of these, but just a thought...
Bluetooth devices can only be connected to one thing at a time right? So if I am using this for bluetooth audio, I can't use the bluetooth phone function at the same time, and would have to switch it on my phone if I wanted to accept a phone call over the bluetooth system?
Old 06-19-2013, 12:50 PM
M4XBMW7's Avatar
TTurboFest
Yes it will do whatever you want , won't even notice you have it in the car
