Old 04-09-2013, 04:34 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
High Mileage 6'ers.
Any high mileage 6'ers out there? By high mileage, I'm talking at least a 100,000 miles or more. Even if you're not a high mileage 6'er, post up the current mileage and condition of your 6.
I'll go first. Bought this car in January 2013 with 55k miles on the clock. At 58.2k miles right now and have to do the vacuum pump soon. Had the Mechatronics sleeve replaced under CPO a few weeks ago.
Once a 6'er, always a 6'er.
Old 04-09-2013, 05:51 PM
IL_BMW_650 IL_BMW_650 is offline
Mein Auto: 2007 BMW 650i
2007 BMW 650 coupe just hit 50k. Only issue I had so far was replaced windshield washer pump.
Sent from my SGH-T999 using Bimmer App
2007 BMW 650i | monaco blue | sport package | cold weather package | comfort access | HUD | 6-speed manual
Old 04-09-2013, 06:14 PM
Maalco Maalco is offline
Mein Auto: 2010 650i Coupe
'10 650i -- 55k & no mechanical issues (knock on wood)
Old 04-09-2013, 08:06 PM
euhysh euhysh is offline
Mein Auto: 2008 e63
08 650i 6mt, 50k miles now...my radiator reservoir developed a leak, draining all the coolant, causing me to be stranded. Also the HVAC stopped working too about 5k miles back. Everything repaired under warranty. What else is in store for me hehe
Old 04-09-2013, 08:54 PM
ammobmw ammobmw is offline
Mein Auto: 2005 BMW 645ci
2005 645ci 90K. Parking senson module. Spend enough time working on preventive maintanance so I better reach 100K.
Semper Fi
Old 04-09-2013, 09:19 PM
bigdgpa's Avatar
bigdgpa bigdgpa is offline
Mein Auto: 08 M6
08 M6 30k No issues
08 M6: Cabrio, Sapphire Black, H&R Lowering Springs, InCurve 20" Wheels, Magnaflow Catback Exhaust, Calipers Painted Red with M-Logo
02 Ford Focus SVT: Run around car
04 Ford F-150: For pulling sea doos and quads
04 645i Cabrio, Titanium Silver ( SOLD )
00 Mercedes CLK Conv (SOLD)
94 Mustang GT (SOLD)
88 Mustang GT (SOLD)
87 Honda CRX (SOLD)
77 BMW 320i (SOLD)
74 Mecury Capri V6 (SOLD)
Old 04-10-2013, 12:24 AM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
ok so I have 129K and I just changed my alternator, and my valve covers are leaking but other than that I drive it to work 75 miles each way everyday and proud of it!!!!!!!!
Wouldn't change a thing after driving a 6er I don't want to drive anything else!!!!
Sent Via iPhone using BimmerApp
Old 04-10-2013, 01:43 AM
Patton63 Patton63 is offline
Mein Auto: '08 BMW 650i 'vert
'08 650 vertte! 40,000 miles. I have had it for just over one year and bought it with roughly 28,000 miles. I have done the normal oil change/maintenance and replaced the brakes (under warranty). I also had to replace the vacuum pump (also under warranty). So far, no other major problems.
Old 04-10-2013, 03:18 AM
reytran's Avatar
reytran reytran is offline
Nothing quite like a 6
Mein Auto: 09' 650i Cabrio
2009 650i cabrio with 72,000 miles. Running strong!
2009 BMW 650i Cabrio (daily drive)
2011 Audi A4 (groceries, bully, road trip, winter beater, family car)
BMW CCA ID: 473647
Old 04-10-2013, 06:17 AM
Tanktop Tanktop is offline
Mein Auto: 2008 650i Cabrio
2008 650i Cabrio with almost 70k. So far, nothing other than normal maintenance and battery replacement.
Old 04-10-2013, 07:53 AM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
The question is all wrong...you should also ask how long have you had the car. Some guys who answer have only had the car for 4 or 5 months! Let us know your list after 3 or 4 years of ownership.
2006 car with 55k miles, I have owned it since 9/2009, bought it with 28k miles. I am not including oil changes, tires, or fluid flushes, only repairs or standard repairs that occur less than standard timeframe:
FIXED WHILE UNDER WARRANTY CPO:
mechatronics sleeve replaced
steering angle sensor
dash cluster failed
ARS block failure
convertible top-unlocked error, bracket fixed per TSB. Still occurs infrequently
REPAIRED MYSELF:
Vacuum Pump
Battery (2.5 year old battery)
REPAIRS NEEDED:
mechatronic sleeve or tranny pan - leaking
valve covers - leaking
Old 04-10-2013, 09:38 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
I bought my 2005 645ci at 18 months old with 16k on the clock. Sold last year April with 84k on the clock. Only real problem was squealing breaks, took a while to sort but fixed eventually. As for other faults, oil leaks, transmission etc absolutely nothing that caused me to payout any real money, small issues fixed by myself !!!!!!!! even had the original battery.
Always said I would go back to a 6 series
Old 04-10-2013, 11:25 AM
Peck Peck is offline
Mein Auto: 645 Coupe
2005 645, I got it in 9/2010 with 67k. Currently it has 93k.
Outside of normal maintenance the following has been replaced:
Radiator
Expansion tank
A couple PDC sensors
Just got the increased emissions error yesterday, its running fine so probably need a thermostat, goes in on Monday
Battery is weak, will need replaced soon.
Old 04-10-2013, 12:50 PM
ch650's Avatar
ch650 ch650 is offline
SVSCME
Mein Auto: 217 440i
2006 650 purchased new via European delivery 1/2006 Now has 92,125 miles and so far running strong with no mechanical problems......yet! Just regular p/m's... oil change every 5,000 miles, tranny,differential, and p/s fluid changed @ 60,000, brake fluid and coolant every 2 years etc. Just did brakes/rotors and looking to do spark plugs and coils soon.
2017 440i
2006 650i
2003 330i (wifes) sold 10/27/06 replaced with 530i (7/21/06 ED) 9/28/06 re-delivery
2001 540i (rear ended & totaled 8/17/05)
1986 535 e28 (beater, but working on restoration)
Old 04-10-2013, 04:14 PM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
I'm very surprised at the low mileage totals quoted by the US/Canadian members. You have a massive land mass with comparatively great roads, public transport doesn't seem to be as popular as it is in Europe (based on my visits to the US). I have done a few road trips through California, Nevada, Massachusetts, New York, Rhode Island, Pennsyvanlia, New Jersey, Conneticut, Maryland, Virginia & DC & clocked up lots of miles in a short period of time. How are you guys keeping your mileage so low? To add insult to injury your gas prices are 50% (maybe more) cheaper than what we can buy here in Europe, another excuse to jump in the car.
Me? I have owned my e63 for just shy of 2 years, had 65k miles when I bought it, 91k now, so that's 13k per year. Most of those were clocked up on one of our few Motorways between Cork & Dublin.
The failures in my ownership:
- VANOS soleniod, exhaust side (90)
- Track control arm (360, incl alignment)
- Puncture
- Thermostat (110)
- Cracked rear wheel, style 218 (330, 2nd hand unmarked)
Then usual service items & minor cosmetic upgrades
Old 04-10-2013, 09:22 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
Mine is an 07 650i 6MT purchased in 09 (2 year lease return) with 13k miles. It is my second car in the winter and third car in the summer so I don't put a ton of miles on it - it now has 37k miles.
Only repair has been a failed passenger side sill plate that would not light up takend care of under warranty.
Out of pocket expenses have been upgrades, wear items and old school maintenance.
Upgrades are clutch delay valve bypass and short shift kit.
I replaced the original Bridgestone tires at 18k miles with Conti DSW's which are holding up really well.
Maintenance has been yearly oil change, trans and diff fluid change at 30k miles, brake fluid changes at 2 year intervals, coolant change at 4 year mark.
Battery is hooked to BMW tender when the car sits so it's still the original (as is the battery in my 02 330 convertible which is also on a tender during winter slumber.)
It still has low miles but so far the ownership experience has been fantastic. Loving this car, and the styling is so unique I'm thinking of keeping long term. I get more compliments on it now than when I first bought it.
Old 04-10-2013, 09:41 PM
Nitrogen's Avatar
I think I have won this challenge!!!! No one more than 129,000 yet. By the time I finish typing this it will be 130,000.
Do I get a prize?
Old 04-10-2013, 11:05 PM
coug60's Avatar
coug60 coug60 is offline
06 BMW 650i Sprt/Prem Pkg
Mein Auto: 2006 BMW 650i e64
06 650i 53K miles....
2006 BMW 650i Sport/Premium Package
+ Various Mods & Upgrades
Old 04-11-2013, 12:50 AM
msa9167's Avatar
msa9167 msa9167 is offline
Mein Auto: 2009 BMW 650I
2009 BMW 650I sports package, purchase on 5-10-12 with 2,619 miles current miles is 6,500. Replace under warranty CCC aka Nav unit, passenger seat sensor, 1 set of wiper blades and 1 oil change.
2005 BMW 650ci sports package purchase on 2-28-08 with 16,819 miles, died on 8-28-11 with 50.195 miles. Cause of death got caught in a flooded street. Was resurrected sometime in January 2012 after car was exported to the country of Lebanon.
Under warranty fixes
Engine Torsion brace
A pillar clips - had a squeak
A pillar - still had squeak
Retighten Engine Torsion brace - still had squeak
Replace windshield and seal - still had squeak
Replace dash - no more squeak
All of those above at about 43,000 miles
Replace driver seat back cover plastic screws 35,000 miles
Replace driver seat back cover 38,000 miles
Replace driver seat frame 40,150 miles
CCC aka Nav - BMW pick up the bill, I had to pay $200 my Nav went out 2 months after my warranty end, 45,000 miles
Replace rear wheel bearing 40,150 miles
Out of pocket
I replaced my thermostat after getting an increase emission warning light came on and flush my coolant. 48,000 miles
Old 04-11-2013, 04:44 PM
stevelee203 stevelee203 is offline
Mein Auto: 2006 BMW 650I CONV. Sold
2006 86000 miles
[/SIGPIC][/SIGPIC]2006 BMW 650I Convertible Black Saphire Metallic / Black
SMG
Premium Sound
Sport / Cold / Comfort Access
19" OEM
Logic 7 Premium
Sound HD Radio
Heads Up Display
Park Distance Control
K&N air filter
Aluminum Racing Pedals
6000k headlight upgrade
fog light upgarde
2010 MV AGUSTA F4 titanium/RED frame
2010 Audi Q5 S Line
Old 04-11-2013, 05:29 PM
07 E63650i's Avatar
Freude am Fahren
Keep 'em coming! Seems like many of us are satisfied with the quality of our 6s.
Old 04-12-2013, 12:48 AM
ferny ferny is offline
Mein Auto: 06' BMW 650i
Do I get a prize?
Congrats, this car is amazing and you should push it to it's limits.
Old 04-12-2013, 01:57 AM
reytran's Avatar
Do I get a prize?
What year is your car? It also depends on year too.
BMW CCA ID: 473647
Old 04-12-2013, 08:02 AM
07 E63650i's Avatar
Freude am Fahren
I believe that Nitrogen's car is a 2006 model.
Old 04-12-2013, 08:13 AM
reytran's Avatar
If I still have my car for another 3 years probably break the record haha.
Btw, I saw a 07 M6 on sale has 130,000 miles. So I think our 6 series can easily hit 200,000 without burning our wallet.
BMW CCA ID: 473647
