328i couple overheating again so frustrated! Please help - Bimmerfest - BMW Forums
Old 04-10-2013, 06:42 AM
kraz43series kraz43series is offline
Mein Auto: bmw 328i
Hey guys
So last week I'm driving home from work and the coolant light came on and the car shut down on me. Mines a 2007 by the way with 110K. So I get out of the car look underneathe and there's coolant everywhere on the ground and open the hood and it's smoking. Also it did that a few times before but never leaked where the light came on and I would just wait awhile add a little coolant and it would be fine. So I take it to my mechanic he replaced the water pump and electric fan. So the car seemed fine. Also before all that happened I failed to mention the car was driving like crap the last few months. I noticed loss of power while shifting through gears. Something just didnt feel right. So yesterday I'm driving home from work sitting in traffic it must've been our first 80 degree day this year and the coolant light comes on! I had the ac on also. So I pull over open the hood there was a little bit of white smoke comin out for about two seconds I saw and then nothing. Checked underneathe the car no coolant leaking. I waited about half hour started the car had a 30 minute drive home and got home fine. No warning lights temp gauge was at normal car ran good. But I hate when that light comes on. Something doesn't feel right. Do I bring it back to the mechanic today? I've had this car since jan 2010 and I've loved her ever since. I just want this mess to stop already
Thank you
Old 04-10-2013, 07:14 AM
GarySL's Avatar
GarySL GarySL is offline
Mein Auto: '08 335xi (E90)
Was the thermostat replaced?
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered: March 7, 2008
Built: March 17, 2008
At port: March 19, 2008
Shipped on Graceful Leader: March 21, 2008
Arrived Port Hueneme: April 11, 2008
At dealer's: April 19, 2008
Delivered: April 21, 2008
Old 04-10-2013, 09:35 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by kraz43series View Post
Hey guys
Thank you
Oh, yeah.
And when you do, ask what OBDII reader he uses, and get a printed readout of all codes.
Post image here!
Old 04-17-2013, 11:57 AM
BROOKSBC's Avatar
BROOKSBC BROOKSBC is offline
Mein Auto: 01 BMW 330i
Why did the mech replace the fan? Just curious because I have the same car with a similar issue. I was sitting a light and my yellow temp light came on and then the red one and I lost all power. Pushed the car to parking area got out and popped the hood. It appears I had some fluid loss from the purge valve area and a minor puddle under the car. And while I was or still am waiting for it too cool down I checked my fan and it don't come on. Fuse is good. Don't know what happened but it happened all at once with no indication.
Sent from my SAMSUNG-SGH-I747 using Bimmer App
Old 04-17-2013, 12:30 PM
3star 3star is offline
Mein Auto: 89 E30 Cabrio
Hey guys
Thank you
Couple things can cause this, the end tanks on the radiator are plastic, they sometimes crack and need to be replaced, there may also be a bad hose somewhere in the cooling system that can cause this. These can be ruled out quite easily by doing a cooling system pressure test, a good garage will have the tools to do this.
Another cause can be a cracked head gasket or cracked head.this will cause combustion pressures to enter the cooling system causing it to bubble over and the car release the pressure by dumping the coolant on the ground. This causes the engine to burn through coolant very quickly and if not topped up daily will lead to over heating. Depending on where the leak is the car may show other symptoms like white smoke or milky oil, but these symptoms usually show up when the head gasket has about had it.another symptom is the bloody engine bay symptom, where your entire engine looks covered with coolant.
You can test for a bad head gasket using a leak down test. The garage can do this.if its a cracked head the only way to test that is to remove the head and take it to a machine shop. Its very common for you to have a cracked head that only opens up when the engine is hot, then reseals itself thus passing the leakdown tests when the engine is cool or warm.leak down test should be done on a hot engine but from experience mechanics don't do that because working on a hot engine is dangerous and also the parts are very brittlle so its easier to break things.
Other possibilities include the head bolts stretching under load, this can happen if they weren't torqued properly, or you blew out a freeze plug. Very unlikely since that wouldn't make the car hold any coolant
Old 04-17-2013, 12:34 PM
Every electric fan has a relay. Relays fail fairly awesome
Old 04-17-2013, 12:57 PM
BROOKSBC's Avatar
I let the car cool and attempted to drive it again. The fan came on and it was blowing extremely loud and high but the temp lights came back on anyway and I had to stop and let it cool again. Getting a tow truck now but still wtf?
