Old 04-10-2013, 09:51 AM
bkc0508 bkc0508 is offline
Mein Auto: 2006 750LI / 2012 2500HD
Finally Smoking at the red lights are gone
Replaced the valve stem seals on the the 06 750 this weekend. It was a job and a half the hardest part was the keepers. I attempted to do it alone but quickly found you need a helper on it.
But you could see the old seals were in poor shape the rubber was really hard. Shame on BMW for this.
Old 04-11-2013, 02:16 AM
easymoney456 easymoney456 is offline
Mein Auto: 2007 750li
Hoe much is a job likr that if you go through bmw???
And is it covered under the cpo
Sent from my myTouch_4G_Slide using Bimmer App
Old 04-11-2013, 10:18 AM
jkess114 jkess114 is offline
Mein Auto: Motorcycle
Has anyone done a tutorial on this? Keif, you round??
Old 04-11-2013, 02:13 PM
mgokool mgokool is offline
Mein Auto: 2013 528iX Build 03/13
My 7 is at the dealer right now to have them replaced also...its covered under CPO. Dealer said its quite expensive if not for warranty because its like a 35+ hr job.
*** 2013 528i X-Drive ***
Old 04-12-2013, 10:28 AM
Keif had one in the DIY section that helped greatly. I got instruction from alldata as well. Got a print out from a buddy. It took 2 of us to do mine and it was 12hrs easy.
Old 04-12-2013, 04:24 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
I'm here =] ...as he said, I have one in the DIY section with a ton of pictures that I'll be cleaning up and labeling in the coming days. 12hrs??? You make me proud! Really glad to hear that any stuff of mine helped!
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 04-12-2013, 05:39 PM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2007 Audi A8
Keif,
I have to do valve cover gaskets at some point, how much more work would it be to do the valve stem seals?
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
'03 Acura TL-S (sold)
'15 Toyota Sienna Limited Premium w/Dynamic Cruise
'15 Infiniti Q50 Premium w/NAV & 19'' Wheels
www.balanceyourbodyph.com
Old 04-12-2013, 06:53 PM
Yeah it was around 12hr. Now I couldn't have done it in that time alone. It helped my buddy had just done one a few days before. We had air and lift. One thing we have found you can remove the cams with out taking the vanos off. Keif I assume you had as much fun with the keepers as we did. Did you figure out anything other than a small screw driver?
Old 04-15-2013, 08:54 AM
Master Tinkerer
I cussed up a storm dealing with those stupid little spring keeper things. A small magnetized flathead screwdriver and plugging all oil drain holes, with an extendable magnet on standby was what worked best for me, I'm definitely interested to hear about other ideas though! To keep the VANOS adjusters on the cams did you just de-tension the chain a lot to get it to hop over the teeth on the gears? That could possibly prevent having to remove the timing covers, and make you have to mess with the cam timings a little less, which would be great...do you recall if there was enough clearance to avoid removing those upper timing covers? Did you check the timing using the cam timing jigs when you were done? If so, do you know if you slipped any teeth on the crank, or did the chain stay in place pretty well?
Originally Posted by First_745Li View Post
Keif,
It's really a good bit more work; it's not a small job, although if you can avoid removing the upper timing covers, I suppose it would be a little smaller job, but still a pretty flippin big headache.
Old 04-15-2013, 09:22 AM
Yep they are a pain my buddy actually had to take over on that. We used the magnetized pocket screw driver with trans jelly on it. Yes if you back the adjuster out you should be able to walk the chain off the vanos make use you paint mark those cams and chain. Not still have to get the covers off or you dont have room in my opinion but I think I would try to do it with out taking off the covers next time. We are going to do a 5 sometime soon and we will try then. I did use the timing jigs and double checked both cams with them. The chain will stay in place on the crank but you dont want to drop it in the head so we zip tied it off to hold it up while working.
I have been trying to come up with a better idea than the screwdriver for the keepers. I am thinking tweezers modified on the end to cup the keeper that way you can load it and snap it on the valve. I might order a valve retainer next time and try to cut in and make this tool.
Sorry I didnt take pictures of the job but was under the gun since it is the wife's daily driver.
Old 04-15-2013, 10:32 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
Did you check timing or simply put the chains back where they were? I'll need to do this, possibly this summer.
EDIT: never mind, looks like you addressed my concerns above - paint marking the chain to the gears and zip ties. I presume TIS will give me specs on re-tensioning.
Old 04-15-2013, 11:14 AM
You will lock the crank down with the timing pin and lock the cams on the head you are not working on with the alignment tool while working on the other head.
The tensioner has no adjustment it is hydraulic you have one on the left side and one on the left. The drivers side is in the intake and the other pass is below the cam covers. You only need to remove the one on the side you are working at at the time.
I also put the cam tool on to check the head, i just worked on after i put the tensioner back in.
This job can be a complete pain in the rear.
Old 04-15-2013, 11:39 AM
MOPAULY's Avatar
Ah I see - where did you acquire the timing tool? generic or specific to BMW? I've just bumped up my viscosity a tad since I noticed the oil at long idle issue. Not looking forward to the job but it needs to be done, and I have other cars I can drive while this is down in the garage.
Old 04-15-2013, 11:47 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
I'm not trying to sell this nor do I work for them,heck don't even know if it will work on these valves.I did at one time have a TT Supra and ran across this tool.Sold the car before doing the job but never used it or bought it.Anyway thought I would share this.http://www.toyotool.com/
Old 04-15-2013, 12:19 PM
This is the tool
http://www.ebay.com/itm/271011482958...S:3160&vxp=mtr
You are lucky to have other cars to drive if I was in that boat I would have taking longer.
That is a good tool i have the snap on version but it will not work on these valves since it multi groove keepers.
Old 04-15-2013, 12:45 PM
Master Tinkerer
Originally Posted by bkc0508 View Post
...this job can be a complete pain in the rear.
+1!!!.
Old 04-20-2013, 07:29 AM
MOPAULY's Avatar
Wow not a cheap tool either. Still a DIY savings, but not like you'll use the tool again anytime soon.
Old 04-20-2013, 08:22 AM
Thanks Keif.
'11 328i (sold)
'07 Audi A8
'03 745Li (sold)
Old 04-22-2013, 04:36 AM
I have a little smoke coming out at red lights from time to time... My cpo is over in may, think the dealer will give me problems with doing the job under the warranty
Old 08-17-2013, 04:19 PM
dcoop9 dcoop9 is offline
Mein Auto: BMW 745i
Keif,
I need help! Valve stem seals! I'm in Houston. How do I get a hold of you?
Old 08-18-2013, 09:04 PM
jlombardi jlombardi is offline
Mein Auto: 2006 BMW 750i
cpo???
Old 08-18-2013, 09:07 PM
Mine was covered under the CPo, got the job done 2 weeks before my warranty ended
Old 08-18-2013, 09:26 PM
CPO covered mine without any problems, $50 deductible...
Old 08-20-2013, 08:06 AM
Hotcherrycoke Hotcherrycoke is offline
Mein Auto: 745Li
What is cpo.
