Old 04-10-2013, 03:48 PM
2 Turbos 1 Car 2 Turbos 1 Car is offline
Mein Auto: 08 335i Sedan
08 335i Start up inconsistencies
When I go out to start up my car after it has been sitting for a while, I notice sometimes that it starts up differently. Sometimes it starts up how I would assume a normal start up should sound, and then others sound as if its starts up weak and putters a little bit until I give it a touch of gas, as if to get the engine into rhythm. Also, I notice that my break is tightened at times when this happens, and its becomes much more difficult to depress the break pedal. Any ideas what these are symptoms of?
Old 04-10-2013, 05:27 PM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
It could be an earlier warning for the dreaded HPFP ( high pressure fuel pump) failure.
BMW CCA Member 454031
Save the manuals
Old 04-10-2013, 08:10 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
It's a known issue. If you are under warranty, take it in. My '09 had the same issue and they replaced the fuel injectors.
