Old 04-11-2013, 09:03 PM
Emilio Parra Emilio Parra is offline
Mein Auto: 2006 330i
lowering advice 330i
Who's lowered their 330 and how does it ride . I want an inch and a half drop on a car with sport package.Coilovers , springs H&R / Eibach..whats your experience ?
Old 04-12-2013, 12:36 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
There are so many variables it's difficult to make a definitive statement on this. Generally lowering will almost always cause a deterioration in ride quality, unless you pay top money for really high quality dampers. Of the popular springs, comments on the forums suggest H&R give a harder ride than Eibach.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
Old 04-12-2013, 06:34 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Let's bear in mind that 1.5" drop yields a diff suspension geometry.
OP, you are warned!
Old 04-12-2013, 10:19 AM
PSPlunkett PSPlunkett is offline
Mein Auto: 2007 BMW E91 328i touring
I actually have been pondering the same thing...the H&R comp package or whatever (non-adjustable shocks and variable rate springs) is like $1000 and the H&R coil overs are like $1600. The comp package lowers about the exact amount you are looking for (and me too). I just want a slight change in appearance and stance, and a bit stiffer ride. Cal, have you messed with any suspension changes? Your response took the wind out of my sails a little bit, but I can't imagine that a $1000 suspension upgrade package from H&R would make the car perform worse. I don't think the coil overs would be worth it for me bc I really don't foresee myself adjusting them basically ever.
Old 04-12-2013, 06:20 PM
Touch. Though the spring/shock can be OK, the suspension'll be in a diff place. Couldn't predict ride quality or long term result - though I do run mine ~0.5" lower than stock - kit designed for that - 1.5" is a diff world.
Old 04-12-2013, 06:26 PM
I run Yellows/Eibach Sport and, gotta say, ride's only a little firmer; handling's light years better. They're adjustable and I left holes for that in the rear, yet have not felt the need to adjust at all....!
