Old 08-23-2013, 05:35 PM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
Mine was set for Standard and I changed it to Wert_00. I don't think it makes a difference with a boot from a cold car, but when I restart the car it seemed to boot faster.
I don't know the other values you mention.
Old 08-24-2013, 11:50 AM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
Originally Posted by mattymetzger View Post
changed the value yesterday, don't see any faster boot time. My original setting was "standard" is that the default setting that you changed to wert_00 or was your setting wert_01
I also noticed that the setting for VA_ADAPTIVEHEADLIGHT is set to nicht_activ I do have the adaptive headlights and they do work, why would that setting be nicht_activ?
what does "par" and "fkt" stand for? both are followed by either frei (which means open) or gesperrt (which means locked)
Download NCS Dummy, that will help explain each parameter & also each available setting & what they do.
Old 09-04-2013, 07:02 PM
Bigrob52 Bigrob52 is offline
Mein Auto: 05 645CI
I will go and check it out ,but now I am replacing the fog lights.
Old 10-27-2013, 01:13 PM
bulletrs bulletrs is offline
Mein Auto: M235i & 225XE
Hope someone can help, i have a 2004 bmw 645ci (with ahl bixenon)and upgraded from lm1 to lm2. Now i have the following errors appear in the lma module:
ERROR E51D no message (steering angle), receiver lm, transmitter SZL/DSC
ERROR E51A no message (yaw rate), receiver lm, transmitter DSC
All modules are updatet to the latest version available. The lm2 is coded properly with vin and i added lm2a to the vo. I can not get the two errors deleted, any ideas? The car is operating properly btw, with thr lm1 module the errors are not present.
Old 10-27-2013, 03:01 PM
Mein Auto: 05 645CI
Just one question. I upgraded the angel eyes on my 05645CI, I used the resistors and everything , they work great, but from time to time when I start up the car the angel eyes flash!!! is this normal? They still work okay and no warning lights just the flashing angel eyes when starting??/
Old 10-27-2013, 03:11 PM
mattymetzger's Avatar
mattymetzger mattymetzger is offline
Mein Auto: BMW 645ci
I upgraded and they also do flash
20" wheels 245/35 - 285/30, black grill and blacked out side markers, 10W white LED angel eyes, Eibach lowering springs on Bilstein shocks,
AC Schnitzer pedals, Sprint Booster (what a waste of money), electronic exhaust cut-outs, red brake calipers (painted)
AFE air intake, door laser BMW logo projector lights, CSR front lip with carbon accents, carbon side skirts
Old 10-27-2013, 04:12 PM
roseng's Avatar
roseng roseng is online now
Mein Auto: 2016 528i + 2007 650 Vert
Yes it's normal while the car is doing it's initial scanning. It happens on the incandescent bulbs also but it's not very obvious on them.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 10-27-2013, 04:24 PM
Mein Auto: 05 645CI
Thanks at least I know now that it is normal I was thinking I had to go back to the old ones. Thanks again for the advice.
Old 10-28-2013, 09:37 AM
Yes it is normal, my car does it too with LED angel eyes.
Old 08-09-2014, 02:23 PM
benblaque645 benblaque645 is offline
Mein Auto: 645ci
Is there a part number for a specific lm2 for 05 645ci?
Old 08-11-2014, 05:46 AM
Yorgi's Avatar
Yorgi Yorgi is offline
There is a list of part numbers that will work in the .PDF attached to post #1. You need to know if your car has adaptive headlights before you order a new module.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 08-11-2014, 07:10 AM
Just also to note that there are tonnes of part numbers for the LM2 that will work in your car.
Really all you need to know as Yorgi says is if your car has AHL or not.
Old 08-11-2014, 07:46 AM
bigscore bigscore is offline
Mein Auto: 06 650i
Originally Posted by rebel.ranter View Post
i paid 70 for the module & i did the fitting & coding myself. It is easy to do. I'll do another update to include the specific parameters that need to be set to active. If your car has a build date after 09/2007 your car already has an lm2 module. Here's some quick videos of it in action:
(the car is filthy dirty in the video, the weather is terrible at the minute & i drove 300 miles today)
nice!!!!!!
No car is quite like a BMW....
Old 08-11-2014, 02:14 PM
Mein Auto: 645ci
is adaptive head light where they move with the steering wheel?? if so, then i have that
Old 08-11-2014, 04:10 PM
Yorgi's Avatar
Yes, if the headlights move when you steer then your car has adaptive headlights.
'04 M3 - track
Old 08-24-2014, 07:45 AM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
As mentioned it's the LM checking the bulbs with quick burts of power to measure current draw and see if the bulb is there.
To stop it code the "cold bulb check" to not active on the outputs you have swapped to LED and it stops it.
Code out the warm bulb check too and you can ditch any resistors you have had to fit.
Stuart
Old 01-13-2016, 11:20 AM
prekii prekii is offline
Mein Auto: E63
@rebel.ranter Hi! I see you coded the welcome lights. You also prefer to a fitting. Is their a topic where i can find how you install the LM2 module. I have a LM1 module and would like to upgrade to LM2.
Can u help me? Greetz Davy
Old 01-13-2016, 01:16 PM
There's a full PDF guide attached to post #1 of this thread. It covers everything.
Current cars
1996 e36 320iC (convertible)
2006 e63 630i Sport w/SMG
2007 e63 M6
Previous Cars: 2002 e39 525iA Sport, 1994 e36 318i, 1990 e34 520i, 1989 e30 325i, 1986 e30 316
Old 01-13-2016, 02:30 PM
Mein Auto: E63
@rebel.ranter , ah ok. There is no YouTube link, i guess? So i should follow the pdf file. Which unit do i need to buy and you got any preference that is trust worthy? I have an E63 2005 with xenon.
Old 03-20-2016, 12:55 PM
Mein Auto: E63
@rebel.ranter Im now looking for a LM2 module. Which one do you prefer.. Without adaptive xenons i guess. Part numbers?
Old 03-20-2016, 01:10 PM
There's so many part numbers that are suitable. The fact that you don't have adaptive headlights gives you more options. If you have a particular unit you are looking at you can post a link to it here or the part number and we'll do our best to ensure you get the right one!
Current cars
2007 e63 M6
angel eyes as drls, brake force distribution, coding e63\e64, coding light control module, follow me home lights, homelights, lm1 to lm2 upgrade, welcome lights
