CD/Audio issues!!!!!! - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 04-13-2013, 10:10 AM
fitreddog fitreddog is offline
Mein Auto: X5 E53
Exclamation CD/Audio issues!!!!!!
Hi everyone, I'm looking for some help with my 2003 E53 3.0D Auto. When I bought it I never noticed a problem with the CD player (6 stacker in boot). The probel is that although its working, and recognising CD even appears to be playing them there is no sound.
I looked about a visited some forums, though I'd track down the problem to either being in the amp or in the radio module. Here come the other problem, most post about the radio say the radio module should be in the boot just in from of the battery on the left hand side but there is not one there on mine!!!!
I htink the only things in there are ABS, PDC and another module but nothing that looks like the radio in other pictures I've seen. Also should there be an amp on the left hand side under the multi disc player?Click image for larger version
Name:	BMW X5 E53 battery.jpg
I think I've managed to attatch some pictures.
I think at some point in the past there has been a sub fitted?
any thoughts
thanks for any help...
Old 04-16-2013, 07:57 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
If you have the CD Business player underneath the lid in the dash that is where your radio is. The radio in the boot is for the NAV people. Does the radio play? If the radio play it's not the amp. Do you have DSP? If you do the coaxial cable between the CD Chnager and the rear amp might have become dislodged. If you don't have DSP the 6-pin connector at the CD Changer might have become dislodge. Or you have a bad CD Changer.
Old 04-18-2013, 07:02 AM
Mein Auto: X5 E53
thanks!
Thinks upallnight.
the CD player has a 6 pin in it.
I have a Tape player under the lid in the dash.
I don't think there is an ampin the boot.
this weekend I'll take the radio and tape player out fron the dash and check the connections there
thanks again for your help
Old 04-18-2013, 07:05 AM
The amp is located underneath the CD Changer. You need to remove the CD changer to get to the amp.
amplifier, audio install, cd player help, radio help
