Old 04-13-2013, 09:37 PM
Chico 6series Chico 6series is offline
Mein Auto: 645Ci
05 645Ci... I have a bad coolant leak that i just discovered... Any suggestions???
Anyone know what the problem could be???
Old 04-13-2013, 10:28 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
A coolant leak could have many different scenarios. First one I'd check for is the expansion tank for any leaks as these are prone to wear and tear. Also check the coolant hoses as well as the weep hole. These engines are known for the infamous coolant pipe issue.
Once a 6'er, always a 6'er.
Old 04-13-2013, 10:48 PM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
+1 on the tank, check easy stuff first as stated by E63650i worst case is the dreaded coolant pipe under the intake manifold, hope it's not that big job!!!
Sent Via iPhone using BimmerApp
Old 04-13-2013, 11:35 PM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
You need to get into your engine bay and see where it is coming from. If it is coming out of the engine itslef you could have the dreaded Coolant Pipe failure. Break out your wallet!
Other more common culprits are the expansion tank, it is a 20 minute repair from what I have read. Realoem has it listed at $79.
Other culprits are the small plastic hose that runs across the front of the engine along the top of the radiator. Then check the lower radiator hose, to check this jack the car up and remove the bottom shroud. The common failure here is the temperature sensor, the good news for this one is that it takes a $1 O-ring that you can get in Home Depot. I have listed the thread below that explains it.
http://www.bimmerfest.com/forums/sho...d.php?t=578644
Good luck!
Old 04-14-2013, 08:12 PM
HerbP HerbP is offline
As stated above, the 3 biggest leak opportunities are the expansion tank, the bleed line, & the o-ring on the temp sensor on the lower radiator hose. If you continue to let the car run hot, the expansion tanks will fail very fast. When you find the leak, it will be a time to change & flush the coolant system. Use BMW coolant, & demineralized water. If the coolant is leaking from the front center part of the engine, your coolant pipe o-ring might be starting to fail. This is a very expensive repair. There is an aftermarket repair kit available, to replace the coolant pipe. Inspect the engine bay very close for your leaking part. The coolant pipe usually starts to fail between 60 to 100k miles. It will happen eventually!
Good Luck!
Old 04-14-2013, 09:30 PM
Mein Auto: 645Ci
Thanks for all the information, I really appreciate it! Taking it to the shop in the morning.
Old 04-21-2013, 06:13 PM
645ciDream 645ciDream is offline
Mein Auto: 645 ci
Appears I now have a coolant leak. Based on comments above, i believe it's -- the small plastic hose that runs across the front of the engine along the top of the radiator. I've attached a photo of what my hose/engine area looked like this morning. I'm not a DIYer so what's this going to cost me?
Old 04-21-2013, 06:24 PM
Yorgi's Avatar
Yorgi Yorgi is offline
The part costs $40 at Tischer. See #10 in this diagram.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 04-23-2013, 12:07 PM
soldier-ina-6er soldier-ina-6er is offline
Mein Auto: 2005 645CI, sport package
WTF dude...What happened to your engine bay? I live on the coast of washington and my engine bay looks a thousand times better than that. I don't want to be a dick man but clean your engine bay every once and a while. It'll save you a lot of headaches and your car won't look like it has leprosy.
yeesh.
Old 04-23-2013, 08:47 PM
Yorgi's Avatar
yeesh.
His engine bay is fine. You are seeing white residue from dried coolant which is spraying around the area in the picture due to the leak.
'04 M3 - track
Old 04-24-2013, 12:46 PM
Mein Auto: 645 ci
Spouting off when you don't know your stuff doesn't help anyone. Yes, what you were seeing was from the coolant leak. Yorgi thanks for the part/cost info and having my back.
Old 04-25-2013, 02:03 AM
All-Or-Nothing's Avatar
All-Or-Nothing All-Or-Nothing is offline
Woo Hoo FREE Donuts
Mein Auto: 2004 645Ci Convertible
yeesh.
Old 04-25-2013, 08:04 AM
bimmerzone's Avatar
bimmerzone bimmerzone is offline
Supporting Vendor
Mein Auto: E63 650i, F13 M6
Thank goodness its not the weephole issue...
If you do need the Vent pipe, we have it for $43 shipped
http://www.bimmerzone.com/product/BMW-17127534917.html
| Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 831 Lincoln Ave, Suite 3, West Chester PA 19380 |
Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw
We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!!
Old 04-25-2013, 09:21 AM
I was talking about the rust and grim all over your pulley's. Your drive is caked bro.
Roads don't just have names. They have personalities.
Old 04-25-2013, 10:44 PM
Yorgi's Avatar
Seriously? Slamming a guy for having a rusty pulley bolt?
'04 M3 - track
Old 04-28-2013, 01:25 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
Outside of painting that pulley bolt it is impossible to stop it rusting, even using acf50 and the like will have no effect!!!! It is the same for most unprotected bolts on the car!!!!!
Always said I would go back to a 6 series
Old 04-29-2013, 05:56 PM
blakedanatural blakedanatural is offline
Mein Auto: 2005 645 ci convertible
Like everyone else mentions, check expansion tank, the hose that goes across the radiator and hopefully its not the coolant pipe. I had the same issue. Lucky for me it was the expansion tank and the mini hose that had a crack. I replaced both of them. I got the parts from bimmerzone.com.
Old 10-13-2013, 11:26 PM
Mein Auto: 645Ci
Haven't been on here in a while. It was my expansion tank and I ended up having another smaill leak coming from a hose so the "dealer mechanic" said.
Old 10-13-2013, 11:27 PM
Mein Auto: 645Ci
Just glad it wasn't the weep hole!
6 series, 6 series (e63), 6 series 645i 645ci coupe
