Old 04-14-2013, 06:09 AM
Anduz Anduz is offline
Mein Auto: 1 serie 118d
Question Help - Cigarette lighter no work - fuses are ok
Cigarette lighter isn't work. I have checked fuses, where all is ok.
I was going to come off cigarette lighter and check what is wrong in it, maybe repair or replace. But the question is where to begin to take away the parts that cigarette lighter socket sits in - Is it just 'cigarette tray'? or the middle - (to remove plastic parts)
- If it would have been burn broken in the socket in hint of cigarette lighter. How will I repair and exchange cable and so...
Anyone know? And explain...?
Thank you.
Old 04-14-2013, 06:57 AM
threeOh threeOh is offline
Mein Auto: cars & bikes
Try another cig lighter in it or check w/multimeter. Over the years I've been through a few lighters.
Old 04-14-2013, 07:28 AM
Trunk where has one ubs contact too, but it is not working either.
Old 04-15-2013, 08:31 AM
gordonzhao gordonzhao is offline
Mein Auto: 128I
I had a similar issue, different vehicle. Cigarette lighter didn't work but other accessories did. So outlet was fine. What I figured out was the 2 metal pieces that hold down the actual lighter if that's what you're referring to, got loose so it wouldn't hold the lighter tight enough. This was due to consistent use of other accessories wider than the original cigarette lighter. Try pushing those back toward the center a little.
Sent from my GT-N8000 using Bimmer App
Old 05-09-2013, 03:00 PM
Geekapoo Geekapoo is offline
Mein Auto: 2013 135i convertible
If you are using the cigarette lighter to light cigarettes then the car is doing you a favor!!!!!
Geekapoo ( a cancer doc)
